Integración domótica Z-Wave JS UI, gratuita y de código abierto
Control your Z-Wave network in Gladys through Z-Wave JS UI and MQTT.
Control your Z-Wave network from Gladys, through Z-Wave JS UI and an MQTT broker.
This integration does not talk to your Z-Wave stick directly. Z-Wave JS UI owns the radio and the network management (inclusion, exclusion, healing, firmware updates); this integration turns the nodes it publishes into Gladys devices, and Gladys commands into Z-Wave commands.
What you need
- Z-Wave JS UI, running and already paired with your Z-Wave controller.
- An MQTT broker (Mosquitto, EMQX…) reachable from both Z-Wave JS UI and Gladys.
Setting up Z-Wave JS UI
The integration expects MQTT topics named in a specific way. These are not configurable on the Gladys side: Z-Wave JS UI is the one that must match.
In Settings, MQTT section:
- Name:
zwave-js-ui— otherwise the prefix of some topics will be wrong; - Prefix:
zwave; - Host url / Port: your broker, plus the username and password if it requires them.
Then, in the Gateway section, exactly these settings:
- Topic type:
Named topics; - Payload type:
Entire Z-Wave value Object; - Send Z-Wave events: enabled;
- Include Node info: enabled;
- Publish node details: enabled;
- Ignore location and Ignore status updates: disabled.
Without the payload type and the Z-Wave events, no device state ever reaches Gladys.
Configuring the integration
In Gladys, open the integration's Configuration tab:
- MQTT broker URL — for example
mqtt://192.168.1.10:1883. - MQTT username / password — leave empty for an anonymous broker.
- Save.
Use Test the connection to check the link: it reports the broker it reached and how many Z-Wave nodes it can see.
Adding your devices
Open the Discovery tab: every non-virtual Z-Wave node appears there, with the features this integration understands. Pick a room, adjust the name, and create the devices you want. Scan asks Z-Wave JS UI for a fresh node list — useful right after including a new device.
A device you create is populated immediately from the last known values, so it is not blank while waiting for a battery sensor to wake up.
Supported devices
Features are derived from the Z-Wave command classes a node exposes:
| Command class | What you get in Gladys |
| Binary Switch | on/off switch |
| Multilevel Switch (dimmer) | brightness, on/off, "restore previous" |
| Multilevel Switch (window covering) | shutter position, open/close/stop |
| Multilevel Switch (pilot wire) | heater mode: off, frost protection, eco, comfort… |
| Binary Sensor / Alarm Sensor | motion, smoke, CO, CO₂, leak, opening, temperature |
| Notification | door/window opening, smoke alarm, CO alarm |
| Multilevel Sensor | temperature, illuminance, power |
| Meter | energy, power, voltage, current |
| Central Scene | button clicks (single, double, triple, hold, release) |
| Battery | level and low-battery flag |
| Thermostat Mode | mode: off, heat, cool, auto |
| Thermostat Setpoint | heating, cooling and energy-save setpoints |
| Thermostat Operating State | what it is really doing: idle, heating, cooling |
Thermostats
A Z-Wave thermostat exposes up to three distinct setpoints — heating, cooling and energy save — and each becomes its own temperature feature in Gladys. The mode is what the device is asked to do; the operating state is what it is actually doing: a thermostat set to Heat goes idle once the room is warm enough.
One limitation worth knowing: the Z-Wave "Energy Save Heat" mode has no Gladys equivalent. It is therefore reported as Heating — which is what the device is doing — but selecting Heating from Gladys switches the thermostat from energy-save to plain heating. The energy-save temperature itself stays adjustable through its own setpoint.
The modes offered in the UI are Off, Heat, Cool and Auto. Z-Wave does not reliably advertise which modes a device supports, so a heat-only thermostat still shows Cool and Auto, and ignores them.
Pilot wire modules
The Qubino Flush Pilot (ZMNHJA, ZMNHJD and its DIN rail version ZMNHUD) drives an electric radiator through its pilot wire. On the Z-Wave side it pretends to be a dimmer, each range of its level standing for one order; in Gladys it is a single pilot wire mode feature: off, frost protection, eco, comfort -2 °C, comfort -1 °C, comfort. A module set from elsewhere — its own buttons, Z-Wave JS UI — shows the matching mode.
If you had already added one as a dimmer, accept the update offered in Discovery: the brightness, on/off and "restore previous" features give way to the mode, and their history goes with them. The temperature feature only receives values once a probe is wired to the module. The module's wired input shows as an on/off input: what it means depends on what you wired to it.
A node exposing something else still appears in Discovery — only the features above are created.
Nothing appears in Discovery. Check the Configuration tab status. If it
says the broker is unreachable, the URL or the credentials are wrong. If it is
connected but no node shows up, go back over "Setting up Z-Wave JS UI": Name
must be zwave-js-ui and Prefix zwave, or the integration listens on
topics nobody publishes to.
A device stopped updating. Look at the badge on its card first. Unreachable means Z-Wave JS UI declared the node dead, or removed it from the network; an orange dot means its interview is not finished, so some features may be missing until it completes. A sleeping battery device is normal and shows as local. Z-Wave JS UI remains the source of truth for the details.
"State budget exhausted" in the logs. Gladys accepts 300 states per minute per integration. A very chatty network (energy meters reporting every few seconds) can exceed it: the integration then keeps the first and last value of each feature and drops the intermediate ones. Reducing the report frequency of the noisiest devices in Z-Wave JS UI is the real fix.
Set LOG_LEVEL=debug for verbose logs, readable from the integration's Logs
tab.
Migrating from the built-in Z-Wave JS UI integration
Gladys ships a built-in zwavejs-ui service. This external integration
replaces it and produces the same devices, features, categories, units and
names, so your history, scenes and dashboards can follow.
Install and configure this integration.
In the Discovery tab, create the devices matching the ones you already have.
Migrate each device, which moves its history and rewrites the references in your scenes and dashboards. Until the built-in integration is flagged as deprecated in Gladys, the migration has no button yet — call the API directly, once per device:
POST /api/v1/device/<internal-device-selector>/migrate{"destination_device_selector": "<new-device-selector>","features_mapping": {"<source-feature-selector>": "<destination-feature-selector>"}}Both devices expose the same feature list in the same order, so the mapping is one-to-one.
Once every device is migrated, disable the built-in integration.
Migrating deletes the source device: do it once you are satisfied with the new one.
Estos son los parámetros que Z-Wave JS UI te pide en su pantalla de configuración en Gladys.
| Before you start | section | No | This integration does not talk to your Z-Wave controller directly: it connects to a running Z-Wave JS UI through your MQTT broker. Install Z-Wave JS UI first, enable its MQTT gateway, and make sure both are reachable from Gladys. |
| Configure Z-Wave JS UI | section | No | In the Z-Wave JS UI settings, MQTT section: set "Name" to zwave-js-ui and leave "Prefix" at zwave — the integration expects those exact values to build its topics. Then, in the Gateway section, set "Topic type" to Named topics and "Payload type" to Entire Z-Wave value Object, and enable Send Z-Wave events, Include Node info and Publish node details. Without these, no device state ever reaches Gladys. The two screenshots below show the expected settings. |
| MQTT broker URL | string | Sí | Address of the broker Z-Wave JS UI publishes to, protocol included. |
| MQTT username | string | No | Leave empty if your broker accepts anonymous connections. |
| MQTT password | secret | No |
Cómo instalar Z-Wave JS UI en Gladys
- En Gladys, abre Integraciones: Z-Wave JS UI aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
ghcr.io/sescandell/gladys-zwavejs:1.9.0), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración). - Abre la pantalla de Configuración de la integración, rellena los parámetros y guarda.
- También puedes instalarla directamente desde la URL de su repositorio: https://github.com/sescandell/gladys-zwavejs.
Z-Wave JS UI requiere Gladys >=4.85.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Guías relacionadas
- Z-Wave JS UI sin Home Assistant: tu red Z-Wave con una interfaz sencilla.
Z-Wave JS UI es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene sescandell, no el equipo principal de Gladys.
