Integración domótica Visual Crossing, gratuita y de código abierto
Integración Visual Crossing para Gladys Assistant
Unofficial connector: Visual Crossing weather, 15-day forecasts and alerts, with your API key.
Unofficial connector, not affiliated with Visual Crossing Corporation. It makes Visual Crossing the weather provider of Gladys: current conditions, 24-hour and 8-day forecasts (Visual Crossing gives 15 days, Gladys keeps 8), and the active alerts of the location. The weather widget, the assistant and the weather-alert scene triggers of Gladys use it directly.
This integration was never tested with a real account: it is written from the official documentation of the Visual Crossing Timeline Weather API. Feedback is welcome.
What you need​
  • A Visual Crossing account of your own and its API key (sign up at visualcrossing.com, the key is on the Account page).
  • Gladys 5.1 or later.
Costs​
Visual Crossing counts records. A forecast query (what this integration sends) costs 1 record, whatever its days, hours and alerts; the integration reads the queryCost of each answer and counts it.
  • Free plan: 1,000 records a day. Above that, Visual Crossing answers 429 until the next day.
  • Pay-as-you-go plan: the records beyond the free ones are billed by Visual Crossing (0.0001 USD per record at the time of writing, see the plans).
  • Other plans: see your account.
The integration has its own daily cap (500 records by default), counted before each call and kept in /data across restarts: once reached, nothing is sent before midnight UTC. A call that may have been billed is not retried: after a timeout, a network error or a 5xx, the location waits 15 minutes; after a 401, the key is no longer used. With the default refresh of 60 minutes, one location costs at most 24 records a day.
FieldPurpose
API keyKept by Gladys in its database, never shown again, sent only to Visual Crossing. It never appears in the logs, the status, the error messages or /data.
Weather alertsOn by default. Same cost (the alerts come in the same answer).
Refresh interval60 minutes by default (60 to 180). A location is read from Visual Crossing at most once per interval; Gladys gets the kept copy in between.
Daily cap500 records by default (10 to 100,000), per day in UTC. Visual Crossing counts all the uses of your key in the same account: keep room for your other uses.
Test Visual Crossing makes one call (the current conditions at Greenwich, 1 record, no personal data): it says whether the key is accepted and the records counted today. It runs at most once a minute, and not during a pause (after a 429, an error or a timeout) nor once the daily cap is reached.
Pacing, pauses and errors​
  • Gladys asks for the weather when a dashboard shows it, when the assistant answers, and every 30 minutes for the alerts when a scene uses the weather-alert trigger. The integration answers from its kept copy while it is younger than the interval.
  • One call at a time to Visual Crossing, whatever the number of locations.
  • HTTP 429: paused as long as Retry-After says (compared with the server's Date header), between 60 s and 6 hours; without the header, 60 s then doubled up to 6 hours.
  • Timeout (10 s), network error, server error, 403, unreadable or oversized (over 1 MB) answer: a 60 s pause for every location (or the Retry-After of the answer, 60 s to 1 hour), doubled at each failure up to 1 hour (the step survives a restart and is reset by a success), and this location is not asked again for 15 minutes (the failed call may have been billed).
  • HTTP 400 or 404: the location is not served; only that location is held back for one refresh interval.
  • Gladys waits 15 s for an answer: a call that cannot end in time does not leave.
  • A clock that jumps forward then back never freezes the cap: a count filed under a day further than tomorrow is kept, on the safe side, but filed under today and reset at the next midnight UTC.
  • A request that could not even be prepared (a local error before it leaves) counts no record, holds nothing and pauses nothing.
  • If the count of a call cannot be written to /data within 1 s, the call does not leave (the cap must survive a restart).
  • During a pause or an outage, Gladys gets the last copy if it is under 4 hours old, with its own date (never presented as new); otherwise an error, and Gladys moves on to its next provider.
  • The pause, the holds, the counter and the copies are kept in /data: a restart or a reconnection does not trigger a call. A saved configuration asks Gladys to read the weather again, answered from the copy while it is younger than the interval.
Refused key​
An HTTP 401 is a refusal of the key (Visual Crossing: key, account or subscription problem): no request leaves with it any more, and it is not retried. /data keeps only one byte of a salted hash of the key: nothing a reader could check a guess against (one guess in 256 matches). Saving another key while the integration runs lifts the refusal at once. After a restart only that byte is known: a new key whose byte happens to be the same (1 chance in 256) stays held back until a success of Test Visual Crossing, which tries even a refused key. A 403 is not taken as a refusal (it can come from a proxy or a firewall): it pauses.
What is sent to Visual Crossing​
The coordinates of the house rounded to 3 decimals (about 100 m) and the API key (in the address of the request, as Visual Crossing asks; this address is never logged). Neither the language nor the unit system is sent: the answer is asked in metric and converted here, so one call serves every user. /data/state.json holds the day counter, the pause, the holds, one byte marking a refused key, and the last answers. The answers carry no coordinates, but each is filed under a salted hash of the rounded location: with the salt beside it, the location can be found back by brute force. /data stays on your Gladys.
Mappings​
Visual Crossing icon (icons2 set)Gladys
clear-day, clear-nightclear
partly-cloudy-day/night / cloudypartly-cloudy / cloud
fog / windfog / wind
rain, showers-day/nightrain; pouring from 7.6 mm in an hour; freezing-rain or sleet by the type
snow, snow-showers-day/nightsnow; sleet when rain or ice is mixed in
thunder-rain, thunder-showers-day/nightthunderstorm (snow-thunderstorm with snow only)
any other iconunknown
Day or night comes from the sunrise and sunset times, else from the icon (-day/-night). Units: metric is converted to m/s (wind) and km, or to °F, mph, inches and miles (US); pressure stays in hPa; humidity, cloud cover and precipitation chance in percent. A missing value stays missing, never 0.
Alerts: Visual Crossing gives no level. It is read from the title: a "watch", yellow or moderate → moderate (even an "Extreme ... Watch"); red, extreme, emergency, tornado or hurricane warning → extreme; orange, severe or "warning" → severe; anything else → minor (the alert is kept). The phenomenon (storm, wind, snow...) is read from the title in English, French, German or Spanish. Alerts ended by the server's clock are removed.
Attribution​
Weather data provided by Visual Crossing (https://www.visualcrossing.com/). The Gladys weather widget cannot show an attribution yet: it is on the configuration screen and here.
Statuses​
  • "Enter the API key...": nothing configured.
  • "Invalid configuration: ...": names the wrong fields (never their value); nothing is sent.
  • "Ready", then "Visual Crossing answers".
  • "Visual Crossing refused this API key...", "asked to slow down...", "did not answer properly...", "Daily cap reached...".
  • "/data/state.json is unreadable": read again every 10 s, nothing is sent meanwhile (an unreadable file is not taken as empty).
  • "The configuration could not be read": new try after 5 s, then doubled up to 5 minutes.
Estos son los parámetros que Visual Crossing te pide en su pantalla de configuración en Gladys.
Visual Crossing in GladyssectionNoUnofficial connector, not affiliated with Visual Crossing. It makes Visual Crossing the weather provider of Gladys: current conditions, 24 hours, 8 days and the alerts given for your area. It needs your own Visual Crossing account and API key. The free plan includes 1,000 records a day; a forecast costs 1 record. On the pay-as-you-go plan, records beyond the free ones are billed by Visual Crossing (0.0001 USD each at the time of writing): the daily cap below stops the calls first. Each location is read at most once per refresh interval (one hour by default). Weather data provided by Visual Crossing.
API keysecretSíThe key of your Visual Crossing account (Account page). Kept by Gladys in its database, never shown again, sent only to Visual Crossing.
Weather alertsbooleanNoAsks Visual Crossing for the active alerts of the location (same cost), shown by the weather widget and used by the weather-alert scene triggers of Gladys.
Refresh interval (minutes)numberNoA location is read from Visual Crossing at most once per interval; Gladys gets the kept copy in between. 60 minutes is at most 24 records a day per location.
Daily cap (records)numberNoRecords allowed per day (UTC), counted by this integration before each call and kept across restarts. Reached: no call until midnight UTC. Visual Crossing counts the records of all your uses of the key in the same account.
Cómo instalar Visual Crossing en Gladys​
  1. En Gladys, abre Integraciones: Visual Crossing aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/lm1lc3n7/gladys-visual-crossing:0.1.1), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LM1LC3N7/gladys-visual-crossing.
Visual Crossing requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Visual Crossing es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LM1LC3N7, no el equipo principal de Gladys.
