Integración domótica Thermorossi WiNET, gratuita y de código abierto
Integración Thermorossi WiNET para Gladys Assistant
Control Thermorossi (and other WiNET/NetSoftware) pellet stoves in Gladys Assistant.
The integration talks directly to the stove's WiNET module (configurable LAN IP): full state, fire level 0-5, fan speed 1-6, flue temperature, pellets low, weekly program, alarms with explicit messages. Automatic cloud fallback when the module is unreachable. This integration brings WiNET Wi-Fi pellet stoves (Thermorossi, and other brands on the thermorossi.cloudwinet.it / cloudwinet.it portal) into Gladys Assistant.
What it does​
One device per stove, with the features the stove has: on/off (thermostat mode), air setpoint (5 to 40 °C), heating state, room temperature sensor, state in words (standby, ignition, working, cleaning, alarm…), an alarm binary sensor and the power level select (1 to 5). Scenes can also trigger on the stove_alarm event, once per alarm.
Prerequisites​
Setup​
  1. Install the integration from Integrations in Gladys.
  2. In the Configuration tab, enter the WiNET portal e-mail and password, then click Test the connection: the stove state is shown.
  3. Open the Discovery tab and create the stove.
The integration talks to the WiNET cloud over the Internet, never to the stove directly: the stove must be online in the app. Credentials stay in the Gladys configuration (secret field); the device API key, scraped from the portal like the app does, is kept in the integration data volume and re-scraped automatically when the cloud refuses it.
  • “WiNET portal login failed”: check the credentials; a new attempt is retried automatically every 15 minutes.
  • The cloud returns 0 °C temperatures while the stove is off: the integration then publishes the mode and state only, never a fake temperature.
  • The WiNET module keeps a single active session: if the official app is open at the same time, command conflicts are possible.
Unofficial community integration, not affiliated with Thermorossi or NetSoftware.
Estos son los parámetros que Thermorossi WiNET te pide en su pantalla de configuración en Gladys.
Getting startedsectionNoUse the e-mail and password of the Thermorossi WiNET portal (the same account as the Thermorossi Connector app). The integration reads your device's API key from the portal, exactly like the app does, then talks to the WiNET cloud. Unofficial integration, no affiliation with Thermorossi or NetSoftware.
Portal e-mailstringSí
Portal passwordsecretSí
Stove name (optional)stringNoName shown in Gladys. Leave empty to use the name declared on the portal.
Stove WiNET module IP (LAN)stringNoDirect local read/write on the stove's WiNET module — exposes everything (fan speed, flame level, flue temperature, detailed alarms). Leave empty to use only the WiNET cloud (reduced data).
Labels languageselectNo
Refresh interval (s)numberNoHow often the stove is read, in seconds (one minute minimum, to stay courteous with the cloud).
Cómo instalar Thermorossi WiNET en Gladys​
  1. En Gladys, abre Integraciones: Thermorossi WiNET aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/tchoinard38/gladys-winet:1.2.2), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/tchoinard38/gladys-winet.
Thermorossi WiNET requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Thermorossi WiNET es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene tchoinard38, no el equipo principal de Gladys.
