Integración domótica STIEBEL ELTRON, gratuita y de código abierto
STIEBEL ELTRON heat pumps via the ISG, local Modbus: temperatures, energy, optional commands.
Shows your STIEBEL ELTRON heat pump in Gladys through the ISG (Internet Service Gateway, "ISG web") and its Modbus TCP interface: no cloud, no account, straight on your network.
Never tested with a real ISG. Not affiliated with STIEBEL ELTRON. It reads the Modbus registers of the ISG as the pystiebeleltron library (used by Home Assistant) does.
Security: Modbus has neither password nor encryption. Any machine on your network can read the ISG and change the settings of the heat pump. Keep the ISG on a trusted network (never exposed to the Internet, ideally on a separate network for connected devices).
Supported controllers
The integration reads the controller identification and picks its registers:
- WPM: WPM 3, WPM 3i, WPMsystem (WPL, WPF, WPE heat pumps…);
- LWZ / LWA: integral units LWZ 304/404/504, LWZ x04 SOL;
- LWZ R290 (THZ with ISG Connect): it serves the WPM registers and is read as a WPM (WPM modes, setpoints and addresses).
Another controller is named in the configuration screen ("Unknown controller") and read again every 30 minutes.
One device, "STIEBEL ELTRON heat pump". Each feature appears only once the ISG gives its value:
| Feature | Content |
| Operating mode | List (commands allowed only), see below |
| Operating mode (read) | Text: the real mode, emergency and manual included |
| Heating setpoint (comfort) | Thermostat, heating circuit 1, in °C (command) |
| Heating setpoint (eco) | In °C, read only (WPM: eco; LWZ: night) |
| Hot water setpoint (comfort) | Water heater, in °C (command, capped) |
| Hot water setpoint (eco) | In °C, read only (WPM: eco; LWZ: night) |
| Hot water target now | In °C, the setpoint the controller applies now |
| Temperatures | Outside, flow, return, hot water, room (FE7, FEK, FET or LWZ), in °C |
| Room humidity | In % (FEK remote control, LWZ) |
| Compressor running | 0 or 1 |
| Electric booster running | 0 or 1 (electric heater, "NHZ") |
| Fault | 0 or 1 |
| Electricity used, heat produced | In kWh, today and total, heating and hot water; heat from the booster |
Water temperatures, the outside temperature and the setpoints are "probes": they do not count as the room temperature in Gladys. Read every 30 seconds by default (10 s to 10 min, configurable).
Energy: plain values, not a billed meter
For heating and hot water, the ISG gives a counter of the day and a total. According to the documentation, the total does not include the day and moves around midnight; nothing guarantees it never jumps or goes back. Gladys would count every rise of an index as billed consumption: the values are therefore published as plain sensors (the unit is in their name), never as an energy index. They do not show in the energy monitoring of Gladys.
- Have the Modbus module of your ISG enabled (STIEBEL ELTRON support does it, often for free).
- Give the ISG a fixed IP address in your router.
- In its configuration, enter the IP address of the ISG (port 502 by
default; add
:portwhen it differs). - Save, then add the heat pump from the Discovery tab.
The Test the connection button reads the ISG once (at most every 10 seconds).
Commands (off by default)
While Allow the commands is off, every command is refused. Once on, Gladys may change:
- the operating mode: WPM: program (automatic), comfort, eco, hot water only, standby; LWZ: automatic, day, setback (night), hot water only, standby;
- the heating setpoint (comfort) of heating circuit 1: 5 to 30 °C (WPM) or 10 to 30 °C (LWZ), to a tenth of a degree;
- the hot water setpoint (comfort): whole degrees, from 10 °C up to the ceiling.
Hot water ceiling: 65 °C by default
Water at 60 °C already scalds in a few seconds: Gladys never sets the hot water above 65 °C, and you can lower this ceiling. The Hot water ceiling setting lowers it, from 40 to 65 °C (65 °C by default); going above 65 °C is never possible, whatever is typed. The range of the controller still applies when lower: 60 °C at most on a WPM (its manual), 65 °C on an LWZ. A setpoint above the ceiling is refused unsent, and the ceiling is checked again right before sending (a ceiling lowered during a command stops it). The eco setpoint and the anti-legionella program of the controller are never changed.
What Gladys never does
- Select the emergency mode (set by the installer when the compressor is out of order) or the manual mode of the LWZ (a service mode).
- Leave one of these modes, or an unknown mode: the command is refused, the controller keeps control.
- Offer a switch: the mode is a list, the setpoints are thermostats; a "turn everything off" (Gladys, Google Home, Alexa, HomeKit) does not reach the heat pump. A scene may change the mode or a setpoint, only through an explicit action and when the commands are allowed. Beware: the AI chat of Gladys (MCP) can create and run such a scene.
When the heat pump is in emergency, manual or an unknown mode, the list keeps its last value (those modes are not in it): look at "Operating mode (read)", which always shows the real mode.
How a command leaves
Before each command, the integration reads the settings of the heat pump again and decides on that read only; no other request runs between that read and the write, and the option (and the ceiling) is checked again right before sending. A value already in place is not sent again. A command that cannot leave within 3.5 seconds is refused unsent; Gladys gets the answer within its 5 seconds. The ISG confirms a write by echoing it; without that confirmation (silence, a dropped connection, another answer, a Modbus error that does not say the write was rejected), Gladys shows "Command sent, without confirmation": check the value, read again 5 and 20 seconds later (the ISG takes a few seconds to show it). Only a clear Modbus error (function, address or value refused, ISG busy) gives "The ISG refused the command". One command at a time, and at least 3 seconds between two writes (otherwise "still running").
Errors and limits
- ISG unreachable: "Operating mode (read)" shows "ISG unreachable", the device turns unreachable, the other values keep their last one. Tried again after 30 s, 1, 2, then 5 minutes, never faster than the interval.
- Missing registers: a block the controller does not serve (energy on some models, for example) is not asked again until a restart; a block failing now and then is reported in the configuration screen, the other values are still published.
- One ISG per integration; the device is keyed by the controller family (WPM or LWZ): Modbus gives neither a serial number nor a MAC address.
- Modbus requests go one at a time; every answer is checked (transaction id, unit, function, size).
- Not yet: heating circuits 2 to 5, cooling, LWZ ventilation, SG Ready, the individual heat pumps of a WPMsystem.
- The logs never carry register values.
Credits
Ported from pystiebeleltron (Martin Fuchs and contributors, MIT, version 0.9.2), the library of Home Assistant's STIEBEL ELTRON integration. Apache-2.0 license.
Estos son los parámetros que STIEBEL ELTRON te pide en su pantalla de configuración en Gladys.
| Your ISG | section | No | Shows your STIEBEL ELTRON heat pump (WPM 3, WPM 3i, WPMsystem or LWZ/LWA controller) in Gladys through the Modbus TCP interface of its ISG (Internet Service Gateway), without any cloud: temperatures, setpoints, operating mode, compressor and booster, energy. The Modbus module of the ISG must be enabled (ask STIEBEL ELTRON support). Enter the IP address of the ISG (give it a fixed address in your router), save, then add the heat pump from the Discovery tab. Modbus has no password: keep the ISG on a trusted network. Never tested with a real ISG. Not affiliated with STIEBEL ELTRON. |
| IP address of the ISG | string | Sí | An IPv4 address or a host name (Modbus port 502 unless you add one, for example 192.168.1.70:5020). |
| Allow the commands | boolean | No | Off by default. On: Gladys may change the operating mode, the heating setpoint (comfort, heating circuit 1) and the hot water setpoint (comfort), up to the ceiling below. Off: every command is refused. |
| Hot water ceiling (°C) | number | No | Scalding risk: Gladys never sets the hot water above this temperature. 65 °C by default, from 40 to 65 °C (never more than 65 °C, whatever is typed; 60 °C at most on a WPM). |
| Refresh interval (s) | number | No | How often the ISG is read, in seconds. |
| Language of the feature names | select | No | Used for the names of the device and features added from now on, for the mode texts and for the command errors. |
Cómo instalar STIEBEL ELTRON en Gladys
- En Gladys, abre Integraciones: STIEBEL ELTRON aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
ghcr.io/lm1lc3n7/gladys-stiebel-eltron:0.1.3), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración). - Abre la pantalla de Configuración de la integración, rellena los parámetros y guarda.
- También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LM1LC3N7/gladys-stiebel-eltron.
STIEBEL ELTRON requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
STIEBEL ELTRON es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LM1LC3N7, no el equipo principal de Gladys.
