Integración domótica Saunier Duval, gratuita y de código abierto
Integración Saunier Duval para Gladys Assistant
Control your Saunier Duval boiler through your MiGo / MiGo Link account.
This integration connects your Saunier Duval boiler to Gladys Assistant: temperatures, setpoints, heating modes and domestic hot water become Gladys devices, usable in your scenes and your charts. It also brings a dashboard widget, scene triggers (fault, gateway offline) and scene actions (temporary override of a zone).
It goes through the Saunier Duval cloud, the one behind the MiGo / MiGo Link mobile application. These boilers have no local API: everything travels over the Internet, so your gateway has to be online.
What you need​
  • A Saunier Duval boiler connected through a MiGo or MiGo Link gateway (or a MiPro Sense / Exacontrol connected control behind a gateway).
  • The account you already use in the mobile application: same email address, same password.
  • The country the account was created in.
  • Gladys Assistant 5.1.0 or newer: the widget and the scene triggers and actions do not exist in earlier versions.
Nothing to install on the boiler, no API key to request.
Setup​
  1. In Gladys, open Integrations → Install an integration and install Saunier Duval.
  2. Open the integration configuration screen and fill in:
    • Email: the address of your MiGo / MiGo Link account;
    • Password: of the same account. Gladys stores it encrypted and never sends it back to the browser;
    • Country of the account: the country the account was created in. This matters: an account created in France cannot log in through another country, and the login would be refused without further explanation;
    • Refresh interval: how often, in seconds, the boiler is read. 300 s (5 minutes) is a good setting — a boiler is a slow system, and the Saunier Duval platform limits the number of calls;
    • Default override duration: the duration every zone starts from. You then set it per zone, see "Changing a temperature" below.
  3. Click Test the connection. The message tells you how many installations were found on your account.
  4. Open the Devices tab of the integration: your devices are already listed. Pick the ones you want to create in Gladys.
The devices created​
For each installation, the integration creates:
DeviceWhat it exposes
BoilerOutdoor temperature (current and 24 h average), heating water pressure, current activity (heating, hot water, standby), number of fault codes and their detail, a Ventilation boost button
Zone (one per heating zone)Room temperature, humidity (if your thermostat measures it), target temperature, mode, override duration, and whether it is heating right now
Circuit (one per hydraulic circuit)Flow temperature actually produced, flow setpoint computed by the heating curve, circuit state
Hot waterWater temperature, setpoint, mode, a Boost button, and whether the boiler is heating the water
Zones carry the name you gave them in the boiler ("Living room", "Upstairs"…). A zone declared inactive in the boiler is skipped: it reports nothing.
Water pressure is the value worth watching: below ~1 bar the installation needs a top-up. A Gladys scene can warn you.
Changing a temperature​
The value shown in the "Target temperature" field is the one you edit: the manual temperature, the one the Saunier Duval application displays — or the temporary override temperature while an override is running.
Deliberately not the boiler's "demand of the moment": that one drops to 0 as soon as the heating has nothing to do (a scheduled zone outside its slots, summer mode), and an input box pre-filled with 0 would be of no use.
The boiler has no single setpoint register: what gets written depends on the mode the zone runs in.
  • Zone on a schedule ("Auto"): changing the temperature starts a temporary override. The new setpoint applies for the duration you chose, then the schedule takes over again. This is exactly what the mobile application does when you turn the dial on a scheduled zone: your schedule is never overwritten.
  • Zone in manual mode: the setpoint is written for good, until you change it again.
  • Zone switched off: the command is refused with a clear message. Change the mode of the zone first.
Override duration​
Every zone carries an "Override duration" control, adjustable from 30 minutes to 24 hours, like the application. Set it before changing the temperature: that is the duration the next override will use.
It is expressed in minutes rather than hours, for a precise reason: the Gladys slider steps by one unit, so hours would put every half-hour out of reach. In minutes, every value of the application stays reachable. A value that does not fall on a step is brought back to the nearest half-hour (100 minutes → 1 h 30), exactly as the boiler does.
This control does not talk to the boiler: the platform only accepts the duration when the override starts, alongside the temperature. It is therefore a setting of the integration, which Gladys stores and which is read back after a restart. A zone starts from the value of the configuration screen.
Mode mapping​
Gladys modeHeating zoneHot water
OffOffOff
HeatingManual (or "Day" on MiPro / Exacontrol controls)Manual / "Day"
AutoScheduledScheduled
These are the only three modes offered, on the heating zone as on the hot water: the same ones the Saunier Duval application shows, in the same order. Gladys knows other values — "Cooling" for a thermostat, "Eco", "Away", "Boost" for a water heater — but the integration declares to it the modes your boiler actually accepts, so those buttons do not appear.
The wording differs between the two, though, and that is not up to the integration: each category has its own vocabulary in Gladys. They are the same three notions.
Saunier Duval applicationHeating zone (Gladys)Hot water (Gladys)
ManualHeatingManual
ScheduleAutoSchedule
Heating offOffOff
On older controls the "Set back" mode (permanent heating at the reduced temperature) reads as "Heating" too — Gladys has no value that matches it exactly.
Hot water boost​
The Boost asks the boiler to heat the tank right now, outside of the schedule. The boiler clears it by itself once the tank is hot: Gladys will show it back as off at the next refresh.
On Gladys versions older than the #2815 fix, the greyed button of the pair shows the opposite of the real state ("Boost active" while the boost is off). The clickable one is correct. This is a display bug of the Gladys core, not of the integration: updating Gladys fixes it.
Ventilation boost​
The Boiler device carries a Ventilation boost switch: the button of the same name in the Saunier Duval application. It addresses the whole installation, not one zone — hence its place on the boiler.
It is the "airing" function of the control: according to the documentation of the Vaillant Group controls, the heating of the zones is paused for about thirty minutes, long enough to open the windows without heating for nothing, and a ventilation unit wired to the control, if there is one, runs at full speed. The function ends by itself; the switch also stops it early.
The button is offered on every installation, with or without a ventilation unit, like in the application. If your control does not know the function, the platform refuses the command, or accepts it without effect: the switch then goes back to off a few seconds later.
Dashboard widget​
On a dashboard, add the Saunier Duval boiler widget (it shows up in the list of widgets once the integration is installed). One card gathers:
  • the temperatures that matter: up to two zones, the hot water, the outdoor temperature, and the water pressure, which turns orange below 1 bar and red below 0.6 bar;
  • the activity of the boiler, the mode and setpoint of each zone — in the words of the application: Manual, Schedule, Off — and the word "override" while a temporary override is running;
  • the state of the gateway and the active fault codes;
  • three buttons: Hot water boost, Ventilation boost (each offers the opposite of the current state) and Refresh.
If your account holds several installations, the Installation setting of the widget picks the one shown; without it, the first one.
Displaying the widget never calls the Saunier Duval platform: it shows the last reading, and updates on every new cycle. Only the Refresh button triggers a reading — one request.
Scenes​
Every value of the boiler is a device feature: a scene watches it with the standard Gladys trigger ("when the pressure drops below 1 bar…") and drives it with the standard "Control a device" action. The integration adds what those two cannot express.
Triggers​
TriggerWhen it firesAvailable variables
Boiler fault detectedA new fault or maintenance code appearsCode, title, description, kind of code, number of active codes
Boiler faults clearedThe boiler no longer reports any code—
Gateway offlineThe MiGo gateway no longer answers the platform—
Gateway back onlineThe gateway answers again after an interruption—
Each takes a Boiler filter, useful when your account holds several installations. The variables of the first one fit in a message: "The boiler reports F.28 — Ignition failure".
Three things to know:
  • A trigger reports a change. A fault already there when the integration starts fires nothing, and a lasting fault fires once. If it clears and comes back, it is a new fault.
  • Fault codes and the gateway state are read every 30 minutes (see "Rate limiting"): a scene can therefore react up to half an hour late. The Refresh now button of the integration forces a new reading.
  • If the boiler reports a burst of codes at once, five events at most are sent; the "number of active codes" variable gives the total.
Actions​
ActionWhat it doesResult usable later in the scene
Override a zone temperatureApplies a temperature (5 to 30 °C) for a duration on a scheduled zone, then the schedule resumesOverride started: false if the zone follows no schedule
Cancel a zone overrideEnds the running override: the zone goes back to its scheduleOverride cancelled: false if no override was running
The first one exists because a device command carries a single value: here the temperature and the duration travel together, without touching the "Override duration" control of the zone. The duration is in minutes, from 30 to 1440; left empty, the one of the zone applies. If an override is already running, it is replaced and its duration starts over.
"Nothing to do" is not an error: on a zone in manual mode or switched off, the action answers "false" and the scene goes on. A condition placed after it can test that result.
In the zone selector, Gladys lists every device of the integration: make sure you pick a zone. On any other device, the action fails with an explicit message.
Things to know​
  • Command confirmation. After a command, Gladys shows the requested value right away; a few seconds later the integration reads the boiler again (one request) and publishes what it actually kept. A value that goes back therefore means the boiler did not take it into account.
  • Rate limiting. The Saunier Duval platform limits the number of requests, and you share it with the mobile application. A refresh cycle costs one single request per installation: every published value comes from the same answer. The list of installations, the gateway state and the fault codes are read separately, every 30 minutes only — which is why a gateway that just went offline can take up to half an hour to be reported as such. Do not lower the interval without a reason: 60 seconds is the allowed minimum, 300 seconds the recommended setting.
  • One account. The integration reads every installation attached to the account. If you have several, each one produces its own set of devices, prefixed with its name.
  • Unofficial API. Saunier Duval neither documents nor supports this API: it is the one its mobile application uses, and it can change without notice. This integration is not affiliated with, nor endorsed by, Saunier Duval or the Vaillant Group.
After an update of the integration​
An already-created device does not change by itself. The Discovery tab shows an Update button on the devices whose structure moved, and that button is what re-applies everything: new features, units, and the list of offered modes. That is the case of the Boiler device after the update that brings the Ventilation boost.
One case to know about: Gladys detects a "changed structure" by comparing the features, their units and their bounds — not the list of modes. If an update of the integration only changes the offered modes, no Update button appears and the device keeps its old list. Delete the device and create it again from the Discovery tab: there is no other way.
  • "Login refused": check the email, the password and above all the country of the account. Check as well that these credentials work in the mobile application.
  • No installation found: the account has no boiler attached, or the gateway was paired with another account.
  • Frozen values: the gateway is probably offline. Check it in the mobile application; the integration can only read what the platform knows.
  • Detailed diagnosis: set the LOG_LEVEL environment variable of the integration to debug to see every call in the container logs.
Estos son los parámetros que Saunier Duval te pide en su pantalla de configuración en Gladys.
Getting startedsectionNoUse the email and password of the MiGo or MiGo Link account you already use in the mobile application. Your boiler must be connected through a MiGo or MiGo Link gateway: everything goes through the Saunier Duval cloud, there is no local access.
EmailstringSíEmail address of your MiGo / MiGo Link account.
PasswordsecretSíPassword of your MiGo / MiGo Link account. Stored encrypted by Gladys and never sent back to the browser.
Country of the accountselectSíThe country you registered your account in. An account created in France cannot log in through another country.
Refresh interval (s)numberNoHow often the boiler is read, in seconds. The Saunier Duval platform is rate limited: keep a comfortable interval, a boiler is a slow system.
Default override duration (h)numberNoWhen a zone follows its schedule, changing its temperature starts a temporary override, after which the schedule takes over again. This is the duration a zone starts from: each zone then carries its own "Override duration" control, from 30 minutes to 24 hours in 30-minute steps. Half-hours only.
Cómo instalar Saunier Duval en Gladys​
  1. En Gladys, abre Integraciones: Saunier Duval aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/philippema/gladys-vaillant-saunierduval:1.1.0), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/PhilippeMA/gladys-Vaillant-SaunierDuval.
Saunier Duval requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Saunier Duval es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene PhilippeMA, no el equipo principal de Gladys.
