Integración domótica Ruuvi Gateway, gratuita y de código abierto
Integración Ruuvi Gateway para Gladys Assistant
Unofficial connector: your RuuviTag sensors, through a Ruuvi Gateway on your network.
Unofficial connector, not affiliated with Ruuvi. It brings into Gladys the RuuviTag sensors that your Ruuvi Gateway hears, read through the local HTTP API of the gateway, on your own network (no cloud).
This integration has never been tested with a real gateway. It follows the official documentation of Ruuvi (docs.ruuvi.com) and its published test frames. Please report what you see on the Gladys forum.
What you need​
  • A Ruuvi Gateway on the same local network as Gladys, with a fixed address (set it in your router). The gateway listens to the tags over Bluetooth and relays them; this integration does not use Bluetooth (a Gladys integration runs in a container without Bluetooth).
  • The read-only access by API key turned on: open the configuration pages of the gateway in a browser (http://<address of the gateway>), go to Access settings, turn on the read-only access with a bearer API key and copy that key. This is the "polling mode" of the Ruuvi documentation (polling mode). A gateway that allows the LAN without a password works without a key.
One Gladys device per tag, named "Ruuvi" and the last four digits of its MAC address (as in the Ruuvi apps; rename it when you create it):
FeatureUnitNotes
Temperature°C
Humidity%
PressurehPa
Motionnone (0 or 1)1 when the tag felt a movement since its previous measure
Battery voltage (V)none (in the name)about 3 V new; replace the battery below about 2.5 V
Signal (dBm)none (in the name)the Bluetooth signal between the tag and the gateway
  • Motion: the tag counts the movements it feels (movement counter of the frame). At each read, Motion is 1 when the counter moved since the previous measurement of the tag, 0 otherwise. It needs two measurements in a row, at most an hour apart: the first measurement after a start gives no Motion value. A tag sends its counter only in the RAWv2 and Cut-RAWv2 formats.
  • Gladys has no unit for a voltage nor a signal in dBm in these categories: these two are plain values, the unit is only written in their name.
  • A value the tag marks "not available" in its frame (0x8000, 0xFFFF and the like in RAWv2 and Cut-RAWv2; in RAWv1, which has no such value, a humidity, a raw pressure or a voltage of 0, and a temperature of 0 when the humidity and the raw pressure are 0 too), or outside the range of the feature, is left out, never replaced by a guess.
Data formats​
The integration decodes the frames itself (GET /history?decode=false), after the format pages of Ruuvi:
  • 5 (RAWv2), the format of RuuviTags since 2019: data format 5;
  • C5 (Cut-RAWv2), RAWv2 without the acceleration: data format C5;
  • 3 (RAWv1), the old format (no measurement number, no movement counter): data format 3.
The formats of Ruuvi Air (6 and E1), format 8 and the URL formats are not decoded: the status counts them ("Ruuvi frame(s) not decoded"). Beacons of other brands relayed by the gateway are ignored.
  1. Install the integration from the Gladys catalog (Gladys 5.1 or newer).
  2. In the Configuration screen, enter the address of the gateway (for example 192.168.1.50, with :port if it is not 80) and the read-only API key.
  3. Click Test the gateway: the message shows the main values of each tag.
  4. Open the Discovery tab and add the devices. Their values arrive as soon as they are created.
  • Address of the gateway: an IP address or a host name, with an optional port; http:// in front is accepted, https:// too if you put the gateway behind a reverse proxy with a valid certificate. A path, a user name, a space, a multicast or a broadcast address are refused at once ("not valid") and nothing is sent.
  • Read-only API key: kept by Gladys in its database (in clear, like every secret field of Gladys) and never shown again in the configuration screen. It is sent only to the gateway, in the Authorization: Bearer header of each read, never in a URL, a log, a status nor under /data. The gateway speaks plain HTTP on the local network (open ports): the key crosses your network as is, so use the read-only key (never the read-write one), on a network you trust. A key holding a space or a character that is not printable ASCII is refused at once and never sent nor shown back.
  • Read interval: 2 minutes by default, 1 to 60.
How often the gateway is read​
  • At each interval, one request: GET /history?decode=false, the last frame of every tag the gateway heard. Nothing is ever written to the gateway.
  • Never faster than the interval, counted from the last read: not by the test button, a reconnection to Gladys, a saved configuration, the Discovery tab nor a restart of the container. Another address or key is tried within about a minute (the state file is written at most once a minute). Before the interval has passed, the test button shows the last values and the time of the next possible read.
  • A gateway that does not answer is tried again at the next interval.
  • When the gateway answers 429 or a 5xx, it is left alone for the Retry-After delay given, else 5 minutes, then 10, 20...; always between 1 minute and 6 hours, also across a restart.
  • When the gateway refuses the key (401 or 403), or sends to its sign-in page (a redirection: a key is needed), the reads stop for good and the status says so: no new try on its own, even after a restart. Change the address or the key (tried within about a minute), or press the test button once the interval has passed (one try; the stop is lifted only if it works). Saving the configuration unchanged never lifts the stop.
Which values reach Gladys​
  • A measurement is recognised by its measurement number (the sequence number of the frame, RAWv2 and Cut-RAWv2), else by the instant the gateway heard it (RAWv1), else by the frame itself. The gateway hears the same measurement many times: it is handed to Gladys once. The mark of the last measurement handed over is kept under /data (written at once by a clean stop), so a restart does not send it again.
  • So a tag that stops measuring (RAWv2, Cut-RAWv2: its measurement number stops) sends nothing, even if the gateway still hears its last frame: neither its measures nor its signal, which are only sent with a new measurement. After an hour without a new measurement, the status lists it as "no recent measurement". A RAWv1 tag has no measurement number: each frame the gateway hears anew counts as a new measurement.
  • The age of a measurement is counted on the clock of the gateway: from the instant it first heard that measurement to the instant of its answer (both given by the gateway), so a Gladys clock that is off never makes it look older or newer. Without these instants (a gateway set without timestamps, or whose clock is not set: before 2020), the gateway returns every frame it ever kept, old ones included: a measurement seen for the first time then gives no value ("waiting for a new measurement"); only a measurement that changed since the previous read of the integration is sent, as made since that read.
  • A new measurement at most 5 minutes old (or the interval + 2 minutes) is sent as the current value; older, up to one hour, it is sent dated (Gladys records it at its real time and no scene fires); older than one hour, never. A frame more than 5 minutes ahead of the clock of the gateway is ignored, as is a frame whose MAC address is not the one the gateway filed it under.
  • At most 250 values per minute are sent to Gladys (the core accepts 300): with many tags, the rest follows in the next minute. A value that waits (full budget, Gladys unreachable) is judged again when it leaves: dated past 5 minutes (or the interval + 2 minutes), dropped past an hour. Unchanged values are not sent again (but every 30 minutes).
What is kept under /data​
The instant of the last read, the pause, the refusal, the MAC address of the gateway and the tags met (MAC address, names of their features, mark of the last measurement handed to Gladys, last time heard: nothing secret) survive a reconnection and a restart of the container. The instant of a read is written before its request leaves, and the file is written at most once per minute but for a pause, a refusal or a new tag (written at once). The key is never written: while it is refused, the file keeps only an 8-bit marker of a salted hash of the address and key (1 key in 256 gives the same marker: nothing that could find the key back), so that after a restart another key is tried without waiting for the interval.
At most 50 tags are read, the tags created in Gladys first, then the tags already known; an answer larger than 1 MB, or slower than 10 seconds, is abandoned. A tag neither heard for a week nor created in Gladys (a neighbour's tag that passed by) leaves the Discovery list.
External ids​
ext:ruuvi-gateway:tag:<MAC>, the MAC address of the tag as the gateway gives it, in 12 lowercase hexadecimal digits without separators (C6:A5:B9:E0:AD:06 gives c6a5b9e0ad06), then :<feature> (temperature, humidity, pressure, motion, battery_voltage, signal). These ids never change.
  • "access refused": check the read-only API key on the Access settings page of the gateway, then change it in the configuration, or press the test button.
  • "not an answer of a Ruuvi Gateway": the address points to another device, or the firmware of the gateway is too old for the polling mode (update it from its configuration pages).
  • "no recent measurement": the tag has not sent a new measurement for an hour (out of range, empty battery, gateway filter).
  • "waiting for a new measurement": the gateway gives no time (set without timestamps, or its clock is not set): a tag is shown once its measurement changes between two reads. Turn on the timestamps and the time synchronisation of the gateway to get values at once.
  • "Ruuvi frame(s) not decoded": a Ruuvi Air, a tag in a format this integration does not decode, or a frame cut short or of the wrong length.
  • Logs: the level is set with the LOG_LEVEL variable.
Privacy​
The integration talks only to your gateway, on your network. Of its answers, it keeps only the MAC address and the measures of each tag, and the MAC address of the gateway; the GPS coordinates the gateway may send are never read.
Credits​
Written from the developer documentation of Ruuvi (docs.ruuvi.com, repository ruuvi/docs): the local API of the gateway and the data formats of the tags. No code of another project is ported; the pages used are listed in THIRD_PARTY_NOTICES.md. Ruuvi, RuuviTag and Ruuvi Gateway are trademarks of Ruuvi Innovations Ltd; this connector is free and unofficial.
Estos son los parámetros que Ruuvi Gateway te pide en su pantalla de configuración en Gladys.
Ruuvi Gateway in GladyssectionNoUnofficial connector, not affiliated with Ruuvi. It reads the RuuviTag sensors your Ruuvi Gateway hears, through the local HTTP API of the gateway (polling mode): temperature, humidity, pressure, motion, battery voltage and signal. The gateway listens to the tags over Bluetooth; this integration does not use Bluetooth. On the Access settings page of the gateway, turn on the read-only access with an API key (bearer). Read only: nothing is ever changed on the gateway. Never tested with a real gateway yet.
Address of the gatewaystringNoThe IP address or the host name of the Ruuvi Gateway on your local network, with a port if it is not 80. Give it a fixed address in your router.
Read-only API keysecretNoThe read-only API key (bearer) set on the Access settings page of the gateway. Kept by Gladys in its database, never shown again; sent only to the gateway, in the Authorization header of each read, never in a URL nor a log. The gateway speaks plain HTTP: the key crosses your local network as is. A refused key is never tried again on its own.
Read interval (minutes)numberNoEach read sends one request to the gateway for the last frame of every tag. Nothing reads sooner, not even the test button or a restart; only another address or key is tried without waiting for the interval (within about a minute).
Cómo instalar Ruuvi Gateway en Gladys​
  1. En Gladys, abre Integraciones: Ruuvi Gateway aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/lm1lc3n7/gladys-ruuvi-gateway:0.1.1), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LM1LC3N7/gladys-ruuvi-gateway.
Ruuvi Gateway requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Ruuvi Gateway es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LM1LC3N7, no el equipo principal de Gladys.
