Integración domótica Roth Touchline SL, gratuita y de código abierto
Roth Touchline SL underfloor heating: rooms, temperatures, optional setpoints and programs.
This integration shows the zones (rooms) of your Roth Touchline SL underfloor heating in Gladys, through the public Roth Touchline SL API (the cloud the Roth Touchline SL app uses), with the e-mail address and the password of your Roth account.
Never tested with a real controller nor a real account: it follows the pytouchlinesl library (the one of the Home Assistant integration), without having been tried on a real installation. Tell us on the forum whether it works for you. Not affiliated with Roth.
What it does
For each zone switched on of each controller of the account, a device "Room name (Touchline SL)" with:
- room temperature and humidity;
- setpoint (thermostat);
- heating running (idle, heating or cooling, read only);
- program (a list: constant temperature or one of the programs of the controller) and the mode read ("Program "Living"", "Constant temperature", "Temporary setpoint"…);
- zone status (OK, sensor damaged, no communication…);
- window open (when window sensors are paired), battery of the room thermostat.
Zones switched off in the controller are not offered.
Setup
- Enter the e-mail address and the password of your Roth Touchline SL account, then save. The password is kept by Gladys in its database, never shown again, sent only to Roth (roth-touchlinesl.com, over https).
- Open the Discovery tab and add the zones you want.
The Test the connection button reads Roth once and shows its state.
Commands (off by default)
By default Gladys only reads. Two separate options:
- Allow the setpoint commands: the dashboard, the scenes and the voice assistants can change the setpoint of a zone. The zone then goes to a constant temperature (it leaves its program, as in the Roth app).
- Allow the program commands: the "Program" list can put a zone on one of the programs of the controller, or on a constant temperature (with the setpoint it has).
Safety bounds:
- a setpoint goes from 5 °C to the setpoint ceiling, 24 °C by default, adjustable from 16 to 30 °C, never more than 30 °C;
- a program is chosen only when all its temperatures stay within these bounds (else the command is refused);
- the ceiling is checked again right before sending: when it was lowered during the command, nothing leaves;
- a program not read well (a half-empty interval, a zone whose mode cannot be read) is never sent back;
- a zone that cools, is switched off or is unknown is never commanded;
- a zone on its own program or a temporary setpoint can be put on a program from the list (the list then shows the last program read, the mode read tells the truth);
- no command goes through a switch: a "turn everything off" of a voice assistant never reaches the heating. The Roth API has no command to turn the heating off.
Each command reads the zone again right before acting and decides on that read; it leaves within 3.5 s or is refused with nothing sent. When Roth does not answer in time after sending, Gladys shows "sent, without confirmation" and reads the zone again 5 s and 20 s later. One command at a time. To choose a program, Roth asks for the whole program to be sent back: the integration sends it back as it just read it, changing nothing in it.
Limits and safety
- Read every 60 s (from 30 s to 10 min).
- Credentials refused: a stop kept in
/data, next tries after 15 min, 1 h, 6 h then every 24 h, never in a loop; saving other credentials or pressing "Test the connection" tries again. - Roth token refused: one new sign-in only, never two sign-ins within a minute (even after a restart); a token refused right after a sign-in, or three renewals without any successful read, give the stop above.
- Roth busy (HTTP 429) or failing (5xx): a pause of 1 min to 6 h, kept in
/data, for the reads and the commands alike. /datanever holds the e-mail address, the password nor the token.- A command never signs in to Roth itself: when the token was just refused, it answers "try again in a minute".
Credits
The Roth API and the shape of its answers come from
pytouchlinesl (jnsgruk,
Apache-2.0), the library of the Home Assistant integration. See
THIRD_PARTY_NOTICES.md.
Estos son los parámetros que Roth Touchline SL te pide en su pantalla de configuración en Gladys.
| Your Roth Touchline SL account | section | No | Shows each zone (room) of your Roth Touchline SL underfloor heating in Gladys, through the public Roth Touchline SL API (the cloud of the Roth app): temperature, humidity, setpoint, heating running, program, battery of the room sensor. Enter the e-mail address and the password of your Roth Touchline SL account, save, then add the zones from the Discovery tab. Never tested with a real controller nor a real account. Not affiliated with Roth. |
| E-mail address of the Roth account | string | Sí | |
| Password of the Roth account | secret | Sí | Kept by Gladys in its database, never shown again, sent only to Roth (roth-touchlinesl.com, over https). |
| Commands | section | No | By default Gladys only reads. Each kind of command has its own option. Once allowed, the dashboard, the scenes and the voice assistants can change the setpoint of a zone (from 5 °C to the ceiling below) or put a zone on one of the programs of the controller (only a program whose temperatures all stay within the same bounds). A zone in cooling mode is never commanded. |
| Allow the setpoint commands | boolean | No | Off by default. Off: every setpoint command is refused. A setpoint puts the zone on a constant temperature (it leaves its program). |
| Allow the program commands | boolean | No | Off by default. Off: every program change is refused. |
| Setpoint ceiling (°C) | number | No | Gladys never sets a zone above this temperature, nor puts it on a program that goes above it. 24 °C by default, from 16 to 30 °C (never more than 30 °C, whatever is typed). |
| Refresh interval (s) | number | No | How often Roth is read, in seconds. |
| Language of the feature names | select | No | Used for the names of the devices and features added from now on, for the mode texts and for the command errors. |
Cómo instalar Roth Touchline SL en Gladys
- En Gladys, abre Integraciones: Roth Touchline SL aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
ghcr.io/lm1lc3n7/gladys-touchline-sl:0.1.1), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración). - Abre la pantalla de Configuración de la integración, rellena los parámetros y guarda.
- También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LM1LC3N7/gladys-touchline-sl.
Roth Touchline SL requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Roth Touchline SL es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LM1LC3N7, no el equipo principal de Gladys.
