Integración domótica PS5 Remote Play, gratuita y de código abierto
Switch your PlayStation 5 on or to rest mode and see the game being played.
Control your PlayStation 5 from Gladys: power on, rest mode, console status and game being played, with scene triggers and a dashboard widget. The integration follows the Home Assistant add-on ps5-mqtt, without MQTT: it talks to the console directly with Sony's Remote Play protocol (through playactor).
PlayStation 4 consoles are supported too (power on, rest mode, running game) once the dedicated option is enabled.
Prepare the console
In the PS5 settings:
- System > Remote Play: turn on Enable Remote Play.
- System > Power Saving > Features Available in Rest Mode: turn on Stay Connected to the Internet and Enable Turning On PS5 from Network.
- The console must be on the same local network as Gladys (or reachable from Gladys, see Console IP addresses).
Without these settings, the console does not answer in rest mode or refuses the commands (403 error in the logs).
Add the console
- Switch the console on (not in rest mode).
- Open the Discovery tab of the integration: Gladys searches the local network for consoles. Add yours.
- If it does not show up (another VLAN, a router filtering broadcasts), type its IP address in Console IP addresses (several addresses separated by commas), save and run the discovery again.
Each console becomes a device with three features:
| Feature | Values |
| Power | 1 = on, 0 = rest mode or unreachable (controllable) |
| Status | playing, idle, standby or offline |
| Game | name of the game being played, - otherwise |
The state is read every 10 seconds.
Pair the console
To switch the console on or put it in rest mode, the integration must be paired with the console, like the PS Remote Play app. It is done once, with the two actions of the Configuration tab:
- Click 1. Get the PlayStation sign-in link. Open the link shown, sign in
with the PlayStation account used on the console. You land on a blank page
(or an error page): copy its full address from the address bar of the
browser. It starts with
https://remoteplay.dl.playstation.net/remoteplay/redirect?code=. - On the console, switched on, open Settings > System > Remote Play > Link Device: an 8-digit code shows up.
- Click 2. Pair a console, pick the console, paste the copied address and type the PIN. The message under the button confirms the pairing.
The copied address is only valid for a few minutes: if pairing fails, start again from step 1 with a new PIN.
If your PlayStation profile asks for a passcode at login, set it in Profile
passcode (digits, or key names separated by spaces, e.g. up up down down).
Game being played (optional)
The PS5 does not say what it runs. The game is read from the presence of your PlayStation Network account, with an NPSSO token:
- Sign in on playstation.com.
- In the same browser, open https://ca.account.sony.com/api/v1/ssocookie.
The page shows
{"npsso":"…"}: copy the 64-character value. - Paste it in NPSSO token and save.
- Click Test the PlayStation Network account to check it.
The NPSSO token expires after two months, but it is only used for the first
sign-in: the integration then keeps and refreshes its own tokens (in its
/data volume, readable by it only). If signing in fails, the Configuration
screen says so: generate a new NPSSO token.
The game is attached to the switched-on console matching the platform of the game. When several consoles are on, pick the Preferred console. The Game refresh interval (30 s by default, 10 s minimum) stays within the limit of Sony's API (300 requests per 15 minutes).
On a PS4, the running game comes from the console itself, no PSN account needed.
Scenes
- Use the Power feature of the console in the "Control a device" actions to switch the console on or put it in rest mode, and in the "Device state change" triggers to react when it is switched on.
- Game started (trigger): a game starts on a console. Optionally filter on
the console and the title ID (e.g.
PPSA01521_00). The following actions can read{{triggerEvent.data.title_name}}and{{triggerEvent.data.title_id}}. - Game stopped (trigger): the game is closed, the console is put in rest mode or is no longer reachable.
Example: "when a game starts on the living room PS5, dim the lights and turn the soundbar on".
Dashboard
Add the PlayStation widget and pick a console: it shows the live power state, the status, the game being played with its cover, and two buttons, Switch on and Rest mode.
- The console is not in the Discovery tab: check it is on or in rest mode with Stay Connected to the Internet, then type its IP address in the configuration.
- "not paired yet": pair the console (actions 1 and 2).
- 403 error: Remote Play is disabled on the console, or the pairing was removed: pair the console again.
- "passcode": set the profile passcode.
- The status stays
offline: the console is fully switched off (not in rest mode) or changed IP address; the integration searches again at most every 5 minutes. - The logs of the integration (Gladys Supervision page) detail every error.
Estos son los parámetros que PS5 Remote Play te pide en su pantalla de configuración en Gladys.
| Getting started | section | No | On the console, enable Remote Play, and in the power saving settings keep it connected to the Internet and allow turning it on from the network. Then add the console from the Discovery tab and pair it with the two actions below. |
| Console IP addresses | string | No | Optional, comma-separated: consoles the network scan cannot find (another VLAN, broadcasts filtered). |
| Include PlayStation 4 consoles | boolean | No | PS4 consoles support power on, rest mode and the running game. |
| Profile passcode | secret | No | Only if the PlayStation profile asks for a passcode at login: digits, or key names separated by spaces. |
| Game being played (optional) | section | No | The console does not say what it runs: the game comes from the presence of your PlayStation Network account. Sign in on playstation.com, then open the NPSSO link below and copy the 64-character value of "npsso". |
| NPSSO token | secret | No | Only used to sign in: the tokens it yields are kept and refreshed by the integration. |
| Preferred console | select | No | When several consoles are on, the game is shown on this one. |
| Game refresh interval (s) | number | No | How often the PlayStation Network presence is read (10 s minimum, rate-limited by Sony). |
Cómo instalar PS5 Remote Play en Gladys
- En Gladys, abre Integraciones: PS5 Remote Play aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
ghcr.io/luckys7evin/gladys-ps5-mqtt:1.0.0), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración). - Abre la pantalla de Configuración de la integración, rellena los parámetros y guarda.
- También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LuckyS7evin/gladys-ps5-mqtt.
PS5 Remote Play requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
PS5 Remote Play es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LuckyS7evin, no el equipo principal de Gladys.
