Integración domótica Players (works with BluOS), gratuita y de código abierto
Unofficial connector: Bluesound, NAD… players that work with BluOS, on the local network.
Unofficial connector, not affiliated with Lenbrook (Bluesound, NAD) nor with the other brands. It brings into Gladys the network players that work with BluOS: Bluesound Node, Powernode, Pulse, Flex, soundbars, NAD streamers and amplifiers (C658, M10, CI580…), and the other devices the BluOS Controller app drives. Everything goes through the local API of the players, on your network: no account, no cloud.
Testers wanted: this first version was written without a player at hand, from the official BluOS API documentation, the library of the Home Assistant integration and answers recorded on real NAD and Bluesound players. It was tested against simulated players. Tell us on the forum what works on your model, and what does not.
| Surface | Content |
| One device per player | play, pause, previous, next, volume (0-100), playback state, mute, source (the inputs and presets of the player), title, artist, album, group, and the "notification" function of Gladys speakers |
| Scene triggers | playback changed (playing, paused, stopped), source changed (input, preset or service; filter by input type: optical, HDMI ARC, Bluetooth…), new track |
| Scene actions | playback (play, pause, play/pause, stop, next, previous), play a preset, change the source, play a sound or a stream, join a group, leave its group, now playing |
| Buttons of the configuration | Test the players, List the sources and presets of a player |
The players are followed live: Gladys keeps one request open on each player (the "long polling" of the BluOS API), which answers as soon as something changes. A change made in the BluOS app, with the remote or on the player reaches Gladys within a second, without asking the player in a loop.
Getting started
- Install the integration and open Discovery: the players answering on your network are listed (Gladys looks for them over mDNS, like the BluOS app). Add yours.
- A player is missing? Its address goes in Player addresses (an IP or a
host name, several separated by commas), then scan again. The port is
11000; zones 2, 3 and 4 of a multi-zone player (NAD CI580) are
address:11010,:11020,:11030. Give your players a fixed address in your router: a player that changed address is found again by a new Discovery scan. - On a dashboard, the Music box of Gladys drives a player (play, pause, next, previous, volume), like a Sonos.
Gladys notifications
The Play a notification scene action of Gladys (the text to speech, through Gladys Plus) works on a BluOS player: pick it in the list. The player plays the message, then resumes what it played where the API allows it:
- the play queue resumes at the track and second it was at;
- an input (optical, HDMI ARC, Bluetooth…) is selected again;
- a radio of your presets is played again.
A radio outside the presets, Spotify Connect or AirPlay cannot be restarted through the API: the player then stays stopped after the message. If you change the source yourself during the message, nothing is resumed.
Gladys does not pass the volume chosen in that action to external integrations yet: set Announcement volume in the configuration instead (0 = current volume unchanged); the previous volume comes back after the message. A player in a group plays the message on the whole group.
Scenes
- Playback changed: a player (or none for any), and optionally the new
state (
playing,paused,stopped). Variables: the player name, the new state and the previous one, the source, the title, the artist, the album and a one-line summary. - Source changed: filters on the kind of source (an input, a preset, a streaming service) and on the input type (optical, analog, coaxial, Bluetooth, HDMI ARC / eARC, phono…). For example: "when the TV switches to the HDMI ARC input, dim the lights".
- New track: what a playing player plays changed on the same source.
- Playback: play, pause, play/pause, stop, next or previous track. On a radio, "next" only works if the service allows it (Radio Paradise, Slacker…).
- Play a preset: its number (
3) or its name (FIP). - Change the source: the name of an input (
HDMI ARC), an everyday word (optical,TV,HDMI,Bluetooth,analog,aux,phono,vinyl,optical 2for the second one) or a preset (number or name). The List the sources and presets button shows what a player offers. - Play a sound or a stream: an
http://orhttps://address (a chime on your NAS, a web radio), an optional volume, and Then resume as for the notifications. - Join a group / Leave its group: the player to add and the primary player of the group; a primary player leaving its group leaves the others grouped together.
- Now playing gives
online,playing,state,title,artist,album,summary,source,volume,muted,groupfor a message or a condition. The following actions of the scene find them in their variable list (written{{<step>.<action>.<key>}}, e.g.{{0.0.summary}}when this action is the first of the scene).
Changes made through Gladys (a command, a scene, a notification) fire none of the integration's triggers: a scene can never loop through the player. The generic Control a device action also drives playback, volume and source. Mute is shown by Gladys as a button: each press mutes or unmutes.
Good to know
- The volume of a device is the volume of that player alone, even when it leads a group (like a room); a player with a fixed volume (set in the BluOS app) has no volume in Gladys.
- The secondary player of a group plays what the primary plays: its title, source and state are the group's.
- Gladys sends at most three requests at once to a player (its two follow-up requests and one command), and never the same one twice within a second, as the BluOS API requires.
- The source list follows when you change the presets in the BluOS app (a few seconds later).
- No player in Discovery: the scan needs a network that lets multicast through (no VLAN between Gladys and the player); type the address of the player in the configuration instead. Check that it answers: Test the players.
- Offline: the player is unplugged, out of reach or has a new address. Gladys retries by itself (5 s, 10 s, 20 s… then every two minutes); if it has a new address, scan again in Discovery.
- "cannot skip tracks": the current radio or input has no next track.
- Logs: the log level of the integration is set with the
LOG_LEVELvariable.
Privacy
The integration only talks to your players, on your local network, without any account. The addresses played (notifications, sounds, streams) are downloaded by the player itself.
Estos son los parámetros que Players (works with BluOS) te pide en su pantalla de configuración en Gladys.
| BluOS players in Gladys | section | No | Unofficial connector, not affiliated with Lenbrook (Bluesound, NAD) nor with the other brands. It drives the players that work with BluOS (Bluesound Node, Powernode, Pulse, NAD streamers and amplifiers…) on the local network through their BluOS API, without any account: playback, volume, mute, source, presets, now playing, groups and announcements, followed live, with scene triggers and actions. Open Discovery: the players answering on the network are found automatically; type the address of the others below. |
| Player addresses (if not found automatically) | string | No | IP addresses or host names, separated by commas, with an optional :port (11000 by default; 11010, 11020, 11030 for the other zones of a multi-zone player). Only needed for the players Discovery does not find (another network, multicast blocked). Give them a fixed address in your router. |
| Announcement volume (0: unchanged) | number | No | The volume (0-100) of the "Play a notification" scene action of Gladys on a BluOS player, put back afterwards. 0 keeps the current volume. |
Cómo instalar Players (works with BluOS) en Gladys
- En Gladys, abre Integraciones: Players (works with BluOS) aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
ghcr.io/lm1lc3n7/gladys-bluesound:0.1.2), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración). - Abre la pantalla de Configuración de la integración, rellena los parámetros y guarda.
- También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LM1LC3N7/gladys-bluesound.
Players (works with BluOS) requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Players (works with BluOS) es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LM1LC3N7, no el equipo principal de Gladys.
