Integración domótica owserver (1-Wire), gratuita y de código abierto
Integración owserver (1-Wire) para Gladys Assistant
Unofficial: 1-Wire probes read on an owserver (OWFS) of your network: temperatures, counters.
Unofficial connector, not affiliated with the OWFS project. It reads the 1-Wire devices served by an owserver (the network server of OWFS) running on your network, over its TCP protocol (port 4304), without any cloud.
Tested against owserver in its fake-adapter mode (owserver --fake), never tested with a real 1-Wire bus: tell us how it works with yours.
One Gladys device per 1-Wire device listed at the root of owserver, keyed by its ROM id (for example 28-4AEC29CDBAAB): a new address of the owserver, or the probe moved to another bus, keeps its device and its history.
FamilyChipFeatures
10, 22, 28, 3B, 42DS18S20, DS1822, DS18B20, DS1825, DS28EA00Temperature (°C)
26DS2438Temperature (°C)
1DDS2423Counter A, Counter B
05, 12, 3A, 29DS2405, DS2406, DS2413, DS2408Inputs, as opening sensors
Other families (DS2450, DS2409 hubs, EDS sensors...) are named in the status as "not supported yet". Devices behind a DS2409 hub are not read.
Read-only: only directory and read requests are sent, nothing is ever written to the bus. The outputs of the switches (DS2406, DS2408, DS2413) will come later.
Setting up owserver​
owserver must listen on the network, not only on localhost. In /etc/owfs.conf of the machine that holds the 1-Wire adapter:
server: usb = all # or: server: i2c = ALL:ALL for a DS2482
server: port = 0.0.0.0:4304
then restart owserver. Check from another machine with owdir -s 192.168.1.30:4304 /.
  • owserver address: its IP address or host name, with a port only if it is not 4304.
  • Read interval: 30 s, 1 min (default), 2 or 5 min. With many devices the interval is lengthened so that a full read stays under 250 values a minute (64 devices are read at most).
Then open the Discover tab and create the devices you want.
How values are checked​
  • Temperatures are asked in Celsius whatever owserver is set to. A value outside -55 to +125 °C, or a text that is not a number, is not published.
  • 85 °C is the value a DS18x20 gives when it did not convert (a power glitch, a parasite-powered probe that lost its supply): it is held back, unless the previous temperature of that probe was within 10 °C of it (that previous value is kept in memory only: after a restart, a first 85 °C is held back). The status names the probe; check its power supply.
  • Counters (DS2423) do not go down in Gladys (except after you accept a drop, or when /data was lost and the device is not created in Gladys yet, since then nothing holds its last value): a lower value (a counter without battery starts again from 0 after a power cut) is held back and the status says so. When it is right, click Accept the counter drops: each counter held takes its lower value as its new start, published from the next read. Saving the configuration never does it.
  • Inputs: owserver gives the level of the pin. A pin pulled low (a contact closed to ground) is shown as closed, a pin held high (a contact open, with its pull-up) as open.
  • A device that fails (gone from the bus, a bus error, a value not readable) leaves only that device unread; the status names it. A round of reads starts no new device after 60 s: the devices left over are read first next time. After a round, the bus rests at least half the interval.
Buttons​
  • Test the connection: reads the owserver once when a read is due (never more than one per interval), otherwise tells the last read.
  • Accept the counter drops: see above.
Status messages​
The configuration screen shows the address, how many devices were read, and notes: devices not read (and why), 85 °C held back, counters held back, families not supported yet, devices not created in Gladys, a /data folder that cannot be read (then counters are checked only against the values Gladys holds and nothing is saved; tried again every 10 s), or that does not finish writing (values are still read; nothing is kept for a restart). A state file that is not valid JSON is started again from empty.
Privacy and security​
owserver has no login: nothing secret is configured, stored or logged. The integration keeps in its /data folder only the time of the last read, the ROM ids seen and the counter values.
OWFS is distributed under the GPL 2.0; this integration contains none of its code and only talks to owserver over the network (see THIRD_PARTY_NOTICES.md).
Estos son los parámetros que owserver (1-Wire) te pide en su pantalla de configuración en Gladys.
owserver (1-Wire)sectionNoUnofficial connector, not affiliated with the OWFS project. It reads the 1-Wire devices served by an owserver (the network server of OWFS, port 4304) running on your network, for example on a Raspberry Pi with a DS9490R or DS2482 adapter: one device per 1-Wire device, with the temperature of the DS18B20, DS18S20, DS1822, DS1825, DS28EA00 and DS2438 probes, the two counters of a DS2423, and the inputs of the DS2405, DS2406, DS2408 and DS2413 as opening sensors. Read-only: nothing is ever written to the bus (the outputs will come later). Tested against owserver in its fake-adapter mode, never tested with a real 1-Wire bus.
owserver addressstringSíThe IP address (or host name) of the machine running owserver, with a port only if it is not 4304. owserver must listen on the network (for example "server: port = 0.0.0.0:4304" in /etc/owfs.conf), not only on localhost. Each 1-Wire device keeps its Gladys device if the address changes (they are keyed by their ROM id).
Read intervalselectNoHow often the 1-Wire devices are read. With many devices, the interval is lengthened so that a full read stays under 250 values a minute.
Cómo instalar owserver (1-Wire) en Gladys​
  1. En Gladys, abre Integraciones: owserver (1-Wire) aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/lm1lc3n7/gladys-owserver:0.1.1), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LM1LC3N7/gladys-owserver.
owserver (1-Wire) requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
owserver (1-Wire) es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LM1LC3N7, no el equipo principal de Gladys.
