Integración domótica Orbit B-hyve, gratuita y de código abierto
Control Orbit B-hyve sprinkler timers: water a zone, set run time and rain delay.
Controls Orbit B-hyve Wi-Fi sprinkler timers through the B-hyve cloud, using the same API and event stream as the B-hyve app.
Features (per timer)
- <zone> watering — one switch per zone. On waters that zone for the current Run time; off stops watering.
- Run time — minutes a switched-on zone waters (1–120, default 10).
- Rain delay — hours to suspend scheduled programs (0–168; 0 cancels).
- Next watering — the next scheduled start and program, e.g.
Thu 1 Oct 09:00 · Bonsai. - Fault —
OK, or the zone faults the timer reports.
Scenes
- Triggers: watering started, watering finished (filter by zone name), zone fault, fault cleared.
- Actions: water a zone for N minutes, stop watering, set a rain delay.
Watering started by the timer's own schedule or from the B-hyve app is reflected live over the event stream.
Enter your B-hyve account email and password. Then open the Discovery tab and create the device.
- Login refused — check the credentials in the B-hyve app.
- States lag — the event stream reconnects automatically; the refresh interval is a safety net.
- Logs:
docker logson the integration container.
Estos son los parámetros que Orbit B-hyve te pide en su pantalla de configuración en Gladys.
| B-hyve account | section | No | The same email and password you use in the B-hyve app. |
string | Sí | ||
| Password | secret | Sí | |
| Refresh interval (s) | number | No | Safety-net poll; live changes arrive instantly over the event stream. |
Cómo instalar Orbit B-hyve en Gladys
- En Gladys, abre Integraciones: Orbit B-hyve aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
ghcr.io/plsoftware/gladys-bhyve:0.2.0), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración). - Abre la pantalla de Configuración de la integración, rellena los parámetros y guarda.
- También puedes instalarla directamente desde la URL de su repositorio: https://github.com/plsoftware/gladys-bhyve.
Orbit B-hyve requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Orbit B-hyve es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene plsoftware, no el equipo principal de Gladys.
