Integración domótica National Rail, gratuita y de código abierto
Integración National Rail para Gladys Assistant
Live departures, delays and cancellations of British trains (National Rail Darwin).
Live departures of British trains in Gladys: the next trains of your stations, their platform, their delay, the cancellations and the National Rail disruption messages, from Darwin, the official real-time train information engine of Great Britain.
Unofficial integration, not affiliated with National Rail, National Rail Enquiries nor the Rail Delivery Group. Powered by National Rail Enquiries. Never tested with a real key: written from the official documentation of the Live Departure Board web service (LDBWS) and its schema, and tested against a simulated service.
What you need​
A free key of the Rail Data Marketplace (RDM), the platform where National Rail now publishes Darwin for developers:
  1. Create an account on raildata.org.uk.
  2. Find the Live Departure Board product (Darwin, free) and subscribe to it.
  3. Open your subscription and copy its consumer key.
The old OpenLDBWS registration page no longer answers (checked on 10 November 2026): its tokens are not used by this integration.
FieldWhat to type
Consumer keyThe consumer key of the subscription. Kept by Gladys in its database, never shown again, sent only to the Rail Data Marketplace.
BoardsStation codes (three letters: PAD for London Paddington, RDG for Reading…, shown on every station page of nationalrail.co.uk), separated by commas. RDG>PAD: only the trains from Reading that call at London Paddington. :My name at the end names the device. Up to 6 boards.
Refresh intervalHow often each board is read, 120 s by default (60 to 3600).
Trains per boardHow many upcoming trains are exposed as features (3 by default, 1 to 5).
Language of the valuesEnglish or French, for the feature names and the texts.
API addressLeave it as it is, unless the Rail Data Marketplace moves the product. Only an https://…raildata.org.uk address is accepted: the key is sent nowhere else.
Example: PAD, RDG>PAD:Train to work.
Save, then open the Discover tab and add the boards. Only the boards added as devices are read on their own. The Test the connection button reads the first board (at most once every 30 s; a board read less than an interval ago is answered from that read, failed or not; a click during a read waits for it; a new key is read at once, outside a 429 pause).
Devices​
One device per board, read-only. For each of the next trains that will run with a known time:
  • Next train, Train 2…: minutes until it leaves (from its expected time). 999 means no train in the next two hours.
  • Next train details…: 18:15 Reading · platform 4 · 5 min late (expected 18:20).
And for the whole board:
  • Departure board: every service, cancelled and delayed ones included: 18:15 Reading (+5) · 18:22 Oxford (on time) · 18:30 Didcot (cancelled).
  • Disruption messages: the National Rail messages of the station, without their HTML.
A cancelled train, or a train Darwin only calls “Delayed” without a time, gets no countdown: it is told in the departure board text, never given a made-up time. Replacement buses are not shown: Darwin lists them apart, and this version reads the trains only. Times are UK times (GMT in winter, BST in summer), changes of time and midnight included (in the hour repeated in October, the reading nearest to the board is taken). The countdowns count from the time the board was served (the Date of the answer). No feature keeps a history.
Scenes​
  • Train delayed (trigger): a train of a watched board is now late by at least 5, 10, 15 or 30 minutes. Once per train and threshold (a train 12 min late fires the 5 and 10 min thresholds, then 15 if it gets later). Variables: station, destination, scheduled and expected time, delay, platform, operator, reason.
  • Train cancelled (trigger): once per train, with the reason when Darwin gives one.
  • Read the next trains (action): the next trains of a board, read again if the last read is older than the interval. Outputs: minutes to the next and the following one, destination, times, delay, platform, details, departure board, number of trains. Without a train, the outputs of a train are empty.
The events already fired are kept in /data: a restart does not fire them again. At most 60 events a minute are sent, the rest at the next reads.
Reads, pauses and errors​
  • Each board is read once per interval, one request at a time. The time of each attempt is written to /data before the request (when /data can be written): a restart, a reconnection, a saved form or the Discover tab never read sooner.
  • Key refused (401 or 403 with the error of the Rail Data Marketplace gateway): no automatic retry. The status says so; saving a different key, or a successful press of Test the connection, lifts it (a key changed while the integration was stopped shares the tag of the refused one once in 256: the button then lifts it). Only a tag of 8 bits of a salted hash is kept in /data, never the key. An unreadable 401/403 is not taken for a refusal.
  • 429 (too many requests): every board waits, Retry-After if given, else 1 min doubling, between 1 min and 6 h; the pause is kept in /data.
  • One board failing (server error, no answer within 10 s, unknown station code): it is read again later and later (the interval doubling, up to 1 h); the other boards go on.
  • Answers larger than 1 MB are cut before they are read, and a board generated more than 5 min before it was served is not used.
  • Darwin without train information for the station (areServicesAvailable: false): nothing is published, the status says so with the National Rail message; never “no train”.
  • After 15 min without a good read of a board, its texts say “No recent data” (Gladys cannot unpublish a countdown: its date in Gladys tells its age).
  • A 404 of the gateway itself (not of a station) says the API address may be out of date.
  • Saving a new key reads at once the boards that failed with the old one.
  • /data unreadable: never written over; the integration reads it again every 10 s and, within 30 s, goes on with the pauses and the refusal in memory (the status says so). /data that cannot be written is told in the status too (the pace is then not kept across a restart).
Privacy​
The integration sends the station codes and your key to the Rail Data Marketplace only, with its own User-Agent (gladys-national-rail/<version>). Nothing else leaves your Gladys.
Data and licence​
Train data: National Rail Enquiries (Darwin), through the Rail Data Marketplace, under the terms you accept when you subscribe. Powered by National Rail Enquiries. The code of the integration is Apache-2.0.
Estos son los parámetros que National Rail te pide en su pantalla de configuración en Gladys.
Get startedsectionNo1. Create a free account on the Rail Data Marketplace, subscribe to the free “Live Departure Board” product and copy its consumer key. 2. Paste it below and type your stations. 3. Save, then add the boards from the “Discover” tab. Unofficial integration, not affiliated with National Rail nor the Rail Delivery Group; data: National Rail Enquiries (Darwin). Never tested with a real key: written from the official documentation.
Consumer keysecretSíThe consumer key of your “Live Departure Board” subscription. Kept by Gladys in its database, never shown again, sent only to the Rail Data Marketplace.
BoardsstringSíStation codes (three letters, shown on every station page of nationalrail.co.uk), separated by commas. Only the trains calling at a second station: add > and its code. A name for the device: add : and the name. Up to 6 boards.
AdvancedsectionNoThe defaults suit almost everyone. Each board is one request per interval.
Refresh interval (s)numberNoHow often each board is read, in seconds.
Trains per boardnumberNoHow many upcoming trains each board exposes as features.
Language of the valuesselectNoLanguage of the feature names and of the texts published.
API addressstringNoChange it only if the Rail Data Marketplace moves the product (https, a raildata.org.uk address).
Cómo instalar National Rail en Gladys​
  1. En Gladys, abre Integraciones: National Rail aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/lm1lc3n7/gladys-national-rail:0.1.1), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LM1LC3N7/gladys-national-rail.
National Rail requiere Gladys >=5.3.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
National Rail es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LM1LC3N7, no el equipo principal de Gladys.
