Integración domótica MyNeomitis (Axenco), gratuita y de código abierto
Integración MyNeomitis (Axenco) para Gladys Assistant
Control your Neomitis / Axenco heaters and thermostats from Gladys.
This integration controls the Neomitis / Axenco heaters, thermostats and modules managed by the MyNeomitis mobile app from Gladys. It is a JavaScript port of the Home Assistant myneomitis integration and of the pyaxencoapi library: same REST calls, same real-time channel, same supported models.
It goes through the Axenco cloud (there is no local API): your devices must already be paired in the MyNeomitis app, and an Internet connection is required.
  2. Open the Configuration tab and enter the email address and password of your MyNeomitis account — the same ones as in the mobile app. Axenco offers no OAuth2 flow.
  3. Leave the refresh interval at 300 s unless you have a reason not to: changes normally arrive in real time over the WebSocket, and this interval is only a safety net for a missed message.
  4. Go to Discovery: every recognized device of your account shows up. Create the ones you want to use.
The connection indicator on the Configuration screen turns green once the Axenco session is established. If it stays red, the message tells a rejected credential apart from an unreachable cloud.
Supported devices​
ModelKindWhat Gladys exposes
EV30Thermostat / heaterTemperatures + 7 modes
ECTRLThermostat / heaterTemperatures + 8 modes
ESTATThermostat / heaterTemperatures + 8 modes
RSS-ECTRLThermostat / heaterTemperatures + 8 modes
NTDSub-thermostat (behind a gateway)Temperatures + 6 modes + heating/cooling
ETRVRadiator valve (sub-device)Temperatures + 5 modes
EWSWireless module, dry contact relay3 modes: On / Off / Auto
EWSWireless module, fil pilote7 modes (deviceType: 1), else 10
UFHUnderfloor heating / coolingHeating / Cooling change-over
How an EWS behaves depends on how it is wired: Axenco reports it through state.deviceType (0 = dry contact, anything else = fil pilote), and the integration picks the right mode list on its own.
Sub-devices (NTD, ETRV, UFH) are driven through their gateway: the integration finds it in the device's parents field and addresses the device by its rfid.
Features created in Gladys​
One Axenco device becomes one Gladys device carrying several features — Gladys has no climate entity bundling temperature, setpoint and mode the way Home Assistant does.
  • Current temperature — sensor, in °C, with history (charts).
  • Target temperature — writable setpoint. Its bounds come from the device itself (comfLimitMin / comfLimitMax) rather than a hard-coded 7–30 °C: a heater limited to 16–21 °C really shows 16–21 °C.
  • Current mode — read-only text: "Confort", "Éco", "Boost"… In Auto it says which side of the schedule is running: "Auto (Confort)" or "Auto (Éco)". The switch itself stays a single "Auto".
  • One switch per mode — "Auto", "Confort", "Éco", "Hors gel", "Boost", "Veille"… depending on the model. Auto is a mode like any other (targetMode: 0): picking it leaves the manual modes, and vice versa.
  • Consigne Confort / Consigne Éco / Consigne Hors gel — the temperatures the modes use, writable. Not to be confused with the target temperature above, which is the one-off derogation. Neither pyaxencoapi nor the Home Assistant integration exposes them. Restricted to devices that actually regulate a temperature. An EWS does report the three fields but refuses to write them: it drives a fil pilote and has no sensor, so it has nothing to regulate. UFH is excluded for the same reason, sub-devices because the rfid-keyed payload has never been observed.
  • Rafraîchissement — heating/cooling switch, writable on UFH, read-only on NTD.
  • Read-only sensors — Signal (reception quality, drawn as antenna bars), Présence, Fenêtre ouverte, Verrouillage clavier and Défaut système. These values already travel in the state the device sends: no extra call, nothing to configure. A device only exposes the ones it actually reports. The system fault is published as-is — 0 means "no fault" on every device seen, a non-zero value is likely a code. Neither pyaxencoapi nor the Home Assistant integration exposes them.
Feature names are in French, matching the MyNeomitis app and the Neomitis product range.
Mode switches are exclusive: turning one on sends that mode to Axenco and turns the others off in the same batch. Turning one off does nothing — an Axenco device is always in some mode, there is no "no mode" to send, so the switch snaps back to reality.
Setting the target temperature creates a derogation: a setpoint differing from the one configured for the current mode. The integration sends the same call as the official app, targetTemp + overrideTemp + targetMode: 8 in one go. climate.py writes the mode first and then the temperature; that first call is a no-op, measured.
Why a mode dropdown is impossible, not merely inconvenient​
That is the fair question to ask in front of seven switches. The answer is in the Gladys code, not in a matter of taste.
The dashboard picks the widget of a writable feature by looking its type up in a static map (front/src/components/boxs/device-in-room/DeviceRow.jsx). Every widget that draws a list has its options hard-coded in the front:
Type triedWhat the widget actually renders
HEATER / PILOT_WIRE_MODE6 fixed fil-pilote options; min/max ignored
AIR_CONDITIONING / MODE3 fixed buttons (auto / cooling / heating)
VACUUM_CLEANER / RUN_MODE3 fixed values
FAN / *_SETTINGoptions from a fixed enum, labels from the front
SENSOR / INTEGERrendered as a sensor: not writable
TEXT / TEXTrendered as a sensor: not writable
Gladys does have the mechanism this would need: supported_options, a list of {value, label, sort_order} attached to a feature. It is validated and stored server side (normalizeSupportedOptions.js, device.syncFeatureSupportedOptions.js), and the integration could supply it. But no dashboard component consumes it correctly: the only one that reads it renders its label with
<Text id={`…${AC_MODE_TRANSLATION_KEYS[mode.value]}`} default={mode.label} />
and preact-i18n has no default prop — its Text component only reads { id, children, plural, fields } and falls back to children[0]. With no child, translate() returns null: the button renders empty. Values that do have a translation key inherit air-conditioning labels ("Cooling", "Heating"…) unrelated to the Axenco mode behind them.
So the only writable widget whose labels and value set are both ours is the plain binary switch (BinaryDeviceFeature, type binary), whose label is simply the feature name. Hence the choice.
Its accepted limits: many rows on the eight-mode models, and turning a switch off means nothing. In exchange, every mode of every model is reachable with the right label, and each one is directly usable in a scene or by the Gladys brain.
If Gladys fixes the rendering (a <Text> without a non-existent prop, and a translation table that does not shadow label), the right representation becomes a single AIR_CONDITIONING / MODE feature carrying its supported_options. The change would be confined to src/devices/features.js and src/devices/index.js.
Using it in scenes​
Each mode switch is an ordinary feature: a scene can turn Salon – Éco on in the evening and Salon – Confort on in the morning. The Mode actuel feature being text, it fits display and notifications better than conditions.
Known limitations​
  • Cloud only. No local API exists. Each device carries a badge showing whether it is reachable; a device offline on the Axenco side shows as unreachable in Gladys.
  • "Auto" is targetMode: 0, not 60. pyaxencoapi documents 60 and the Home Assistant integration sends it; measured on real hardware, 60 and 61 both answer 2xx and change nothing. The value the official app sends was captured from its network traffic: {"targetMode": 0}. Hardware in Auto reports 60 or 61 back, so all three decode to Auto on read — that read/write asymmetry is what made the reference library look right.
  • An unknown code stays visible. A mode Axenco reports that the integration does not know shows as "Inconnu (42)" in Mode actuel instead of being silently dropped — that is how the 61 case was spotted.
  • EWS fil pilote: the mode list depends on deviceType. pyaxencoapi and select.py advertise ten presets for every fil pilote EWS — the union of what Axenco hardware can do, not what a given module offers. A verified module gets its real list; every other one keeps the reference list. One has been verified so far: deviceType: 1 (EWSFPNEOA), measured over the WebSocket and cross-checked against its manual. It emits seven orders — comfort, eco, eco -1, eco -2, frost protection, standby, boost — plus Auto through the autoProgram flag. Worth knowing: the MyNeomitis app menu only shows six of them, hiding eco -1 and eco -2, while the manual names them explicitly ("Mode Éco, Éco-1 ou Éco-2") and states the module drives "un fil pilote 4 ou 6 ordres". comfort_plus really is absent though, ignored twice by the hardware. And per the manual, Boost only does something when the connected heater understands that order over the fil pilote. If your EWS reports another deviceType, send the output of node scripts/sweep-modes.mjs <id> --apply and your list will be added. The default stays the wider list on purpose: a mode that does nothing is visible and harmless, a hidden mode is a silent loss of capability.
  • UFH: a deliberate divergence from the Home Assistant source. select.py writes a UFH mode with set_device_mode on its _id, whereas a UFH is a sub-device whose mode lives on changeOverUser. This integration uses the dedicated sub-device route pyaxencoapi provides for exactly that case (set_sub_device_mode_ufh).
  • The weekly program is not exposed. The call exists in the client (setDeviceProgram), but Gladys has no representation for a device schedule: keep managing it in the MyNeomitis app. "Auto" mode follows that program.
  • has_feedback is optimistic. After a command the integration publishes the requested value without waiting for Axenco to confirm; the WebSocket push that follows corrects the display if the device did something else.
Verification status per model​
Everything below concerns the mode list only. The protocol findings are the same for every model: auto is written as targetMode: 0, a derogation is not a selectable mode, and a setpoint is sent as targetTemp + overrideTemp + targetMode: 8. Those three apply to the "inherited" rows too.
ModelMode listCommand routing
EV30measured + app capturemeasured
EWS fil pilote (deviceType: 1)measured + capture + manualmeasured
EWS relay (deviceType: 0)inherited from select.pyinherited
EWS fil pilote, other deviceTypeinherited from pyaxencoapiinherited
ECTRL, ESTAT, RSS-ECTRLinherited from pyaxencoapiinherited
NTD, ETRVinherited from pyaxencoapiinherited, gateway never tested
UFHinherited from pyaxencoapiinherited, gateway never tested
"Inherited" means: the reference library's behaviour, kept as is for lack of hardware to check it against. That library turned out to be wrong on at least two counts, so treat those rows as hypotheses.
The most doubtful one is comfort_plus (code 20), which pyaxencoapi gives to ECTRL / ESTAT / RSS-ECTRL. It is ignored by an EV30 and by an EWS, both measured. It is kept for those three models because nothing proves it is absent there — a useless mode is visible and harmless, a hidden one is a silent loss.
If you own one of these models, two commands are enough to get the list fixed:
node scripts/dump-devices.mjs # the raw state of your devices
node scripts/sweep-modes.mjs <deviceId> --apply # what the device really accepts
Send both outputs along with the mode list the MyNeomitis app shows for that device. The sweep only handles main devices for now: an NTD, ETRV or UFH goes through its gateway, whose response shape has never been observed.
  • "MyNeomitis rejected these credentials" — check the email and password in the mobile app. The integration does not retry in a tight loop on an authentication error.
  • No device in Discovery — only the models in the table above are picked up. The container logs say how many devices were seen and how many were ignored.
  • "No recent value" — Axenco only emits on change. The known state is published when the device is created and on every periodic refresh; wait one cycle.
  • Real-time updates stopped — the WebSocket channel reconnects on its own, and the periodic refresh covers the gap meanwhile. Set LOG_LEVEL to debug to see the events as they arrive.
Removal​
Uninstall the integration from Gladys: the container is removed and the devices created along with it. Nothing changes on the MyNeomitis side — your devices stay paired in the mobile app.
Estos son los parámetros que MyNeomitis (Axenco) te pide en su pantalla de configuración en Gladys.
Your MyNeomitis accountsectionNoUse the same email address and password as the MyNeomitis mobile app. The integration talks to the Axenco cloud: your heaters must already be paired in the app.
Email addressstringSíThe email address of your MyNeomitis account.
PasswordsecretSíThe password of your MyNeomitis account.
Refresh interval (s)numberNoSafety net: updates normally arrive in real time, this is how often the full state is re-read anyway.
Cómo instalar MyNeomitis (Axenco) en Gladys​
  1. En Gladys, abre Integraciones: MyNeomitis (Axenco) aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/dreamthy/gladys-neomitis:1.0.2), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/Dreamthy/gladys-neomitis.
MyNeomitis (Axenco) requiere Gladys >=4.86.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
MyNeomitis (Axenco) es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene Dreamthy, no el equipo principal de Gladys.
