Integración domótica Modern Forms, gratuita y de código abierto
Integración Modern Forms para Gladys Assistant
Modern Forms and WAC smart ceiling fans on your network: fan, light, direction.
Brings Modern Forms and WAC smart ceiling fans (generations 1, 2 and 3) into Gladys through their local HTTP API: no account, no cloud.
Never tested with a real device: it was built from the WAC reference of the API and the aiomodernforms library (used by Home Assistant). Tell us on the forum how it goes with your fan. Not affiliated with WAC Lighting nor Modern Forms.
One device per fan, named as in the Modern Forms app, with:
  • Fan speed (0 = off): 0 stops the fan, 1 to 6 starts it at that speed;
  • Direction: forward (summer) or reverse (winter);
  • Breeze mode (generation 3 fans): off or breeze;
  • Light and Brightness (fans with a light kit): brightness 0 turns the light off, 1 to 100 % turns it on at that brightness.
None of them is a switch: "turn every switch on" never starts a fan. The light is a light, so it follows "turn the lights off" like any other light.
Not handled: the sleep timers, the schedule, the away mode, the adaptive learning, pairing, reboot and reset (use the app), and generation 4 fans (another API; the status says "no /mf API (HTTP 404)").
  1. Set up the fan with the Modern Forms or WAC app, then give it a fixed address in your router (it shows as MF_Fan_XXXXXX or WAC_Fan_XXXXXX).
  2. In Addresses of the fans, type the address of each fan, separated by commas (up to 8), with :port only if it is not 80.
  3. Save, then add the fans from the Discovery tab.
The status says which fans were read, which address does not answer (and when it is tried again), an address where the same fan was typed twice, a device that answers without saying which fan it is, and the Offs not seen applied.
Test the connection reads each fan, or shows its last read if it was read less than an interval ago (never faster than the interval).
Which fan a device drives​
A device is tied to its fan by the clientId the fan gives in every answer (the MAC address of the fan), not by its address. If the fan moves to another address, type the new one: the device follows it.
  • A start, a speed, a direction, the breeze, the light on or a brightness: the fan is read first, and the command is written only if that read shows the fan of the device, at an address of the configuration.
  • An Off goes to the address the fan was last read at (or kept in /data, or saved with the device, or the only address typed), even if nothing was read yet. It is refused only when:
    • the address of the fan is not known: never read, nothing kept, no address on the device and several addresses typed;
    • another fan answered last at that address. Until a read shows it, a fan swapped with another one at the same address is not seen: an Off sent then may stop the other fan (its answer says so, and nothing is kept);
    • a newer command on the same part (another Off) took its place before it left.
The Offs (fan speed 0, light off, brightness 0)​
An Off needs no option and goes first: it does not wait for a read, a command in progress, a pause after failed reads, the configuration of Gladys (when the address is known) nor the first read after a restart. It cancels the commands of the same part still waiting, and cuts the request in flight to that fan.
If it cannot be sent at once (the fan does not answer), it is tried for 250 ms, then kept (in /data, and in memory if /data cannot be written) and tried again every 10 s, whatever the pause of the reads: it leaves within about 10 s of the fan answering again, and again after a 429 or 503 answer, a cut or a send left without answer, without end: none of these is a try. Once the fan accepted it, a read that still shows the part on sends it again, and so does the same 10 s turn when no read did (reads paused by an outage never hold it): at most once per read interval (10 s at most) and 3 times at most; a try counts only when the fan accepted the Off and its answer still shows the part on. Only the reads judge an Off, each on its own part (the answer of the Off of the light never sends the Off of the fan again). The status tells where each Off stands.
A kept Off ends when a newer command starting the same part has left (one the fan refused does not count), when the device is deleted, or, after a read showed it applied, when the part is read on twice in a row (started from the remote or the app: the integration never stops it again). Never by the time.
Reads and pauses​
Each fan is polled every interval (10 s by default, 5 s at least), never sooner, even after a restart or a reconnection (a command adds its own reads: the one before it, and those 5 s and 20 s after). A fan that does not answer is tried again after 10 s, 30 s, 1, 2 then 5 minutes (a minute at least when it asks to wait); its commands are refused meanwhile, but not its Offs. A command is confirmed by the state the fan answers (the commands of a scene on one fan go together: one read, one write): "sent, without confirmation" when no answer came, "does not show it yet" when the answer shows the old value; the fan is then read again 5 s and 20 s later.
Privacy​
The information the fan gives also holds the e-mail of the app account: it is never used, logged nor kept. /data keeps only the addresses, the ids of the fans, the times of the reads, the pauses and the Offs to send.
Estos son los parámetros que Modern Forms te pide en su pantalla de configuración en Gladys.
Your fanssectionNoBrings Modern Forms and WAC smart ceiling fans (generations 1 to 3, set up with their app) into Gladys through their local HTTP API, without account nor cloud: fan on / off and speed (0 = off), direction, breeze mode, light and brightness. An Off (speed 0, light off) needs no option and goes first, even while a fan does not answer or before the first read: it is kept and sent again until a read shows it. Generation 4 fans are not handled yet. Never tested with a real device: tell us on the forum how it goes. Not affiliated with WAC Lighting nor Modern Forms.
Addresses of the fansstringSíThe IP address (or name) of each fan on your network, separated by commas (up to 8), with :port only if not 80. Give each fan a fixed address in your router; the app shows it, and so does your router (a name starting with MF_Fan or WAC).
Read every (seconds)numberNoHow often each fan is read: 10 s by default, 5 s at least.
Language of the namesselectNoUsed for the names of the devices and features added from now on.
Cómo instalar Modern Forms en Gladys​
  1. En Gladys, abre Integraciones: Modern Forms aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/lm1lc3n7/gladys-modern-forms:0.1.1), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LM1LC3N7/gladys-modern-forms.
Modern Forms requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Modern Forms es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LM1LC3N7, no el equipo principal de Gladys.
