Integración domótica Mobilize Power V2G, gratuita y de código abierto
Integración Mobilize Power V2G para Gladys Assistant
Mobilize Powerbox Verso: charges, energy sent back, V2G hours, cost, V2G bonus, balance
Mobilize Power V2G in Gladys
Follow in Gladys the charges and the energy sent back by your car on a Mobilize Powerbox Verso with the Mobilize Power offer: charging cost, V2G hours gain, subscription and balance, per day, month and year.
Requirements​
  • A Mobilize Powerbox Verso on your local network (Wi-Fi or Ethernet), with a fixed IP address (set it in your router).
  • The password of the installer account of the borne, printed on its label (user installer).
The integration reads the borne read-only: it never changes its settings and does not interfere with Mobilize Power or the My Renault app.
Setup​
  1. Configuration tab: the borne's IP address, user and password, then Test the connection to the Powerbox. Gladys hides the password as you type it: this button confirms it is right ("OK") or refused.
  2. Your contract's subscribed power (for the subscription).
  3. Discovery tab: create the "Mobilize Power V2G" device.
  4. Dashboard: add the V2G balance widget and pick the period (today, this month, this year).
Updating from version 0.1​
Version 0.1 misread the car's presence (always "plugged") and declared features Gladys duplicated as "(consumption)" and "(cost)". After the update, delete the "Mobilize Power V2G" device (Devices tab) and create it again from the Discovery tab. The V2G hours estimated before the update are reset; the energy and the official hours you entered are kept.
The calculation​
LineCalculation
Charging costkWh charged × price per kWh
Subscriptionannual subscription × days of the period ÷ days of the year
V2G bonusV2G hours × V2G Hour rate
Buyback of the energy sent backkWh sent back × buyback price (0 by default)
Balancecharging + subscription − V2G bonus − buyback
A negative balance is a gain.
The tariffs come from the grid published on mobilize-v2g.fr, read once a day (built-in fallback: the August 2026 grid). A value entered in the configuration always wins over the grid.
The V2G hours are estimated from the time the car is plugged in (Mobilize counts them only once the minimum charge level is reached and until the departure time). The car is detected on the socket's control pilot: a cable left in the borne without a car does not count. Enter the official figure of a month with the Official V2G hours button of the widget, or the action of the same name in the configuration.
Limits​
  • The borne's local API is not documented by Mobilize: a firmware update could change it.
  • If the borne or Gladys is unreachable for more than 10 minutes, that time is not counted as V2G hours; the energy is caught up thanks to the borne's counters.
  • Amounts are TTC (taxes included), computed with the grid prices: the invoice may differ slightly.
  • In Discovery, Gladys shows a "$" icon for every currency feature whatever the currency: the amounts are in euros (unit €).
Estos son los parámetros que Mobilize Power V2G te pide en su pantalla de configuración en Gladys.
Your Mobilize Powerbox VersosectionNoThe integration reads the borne on your local network, read-only: it never changes its settings and does not interfere with Mobilize Power. The user and password are those of the installer account, printed on the label of the borne. Give the borne a fixed IP address in your router.
Powerbox IP addressstringNo
Powerbox userstringNo
Powerbox password (installer account)secretNoHidden as you type it: after saving, the "Test the connection to the Powerbox" button says whether it is right.
Read the borne every (seconds)numberNo
Tariffs (TTC)sectionNoBy default the tariffs come from the grid published on mobilize-v2g.fr, read once a day. A value you enter below always wins over the grid; leave it empty to follow the grid. The V2G gain is the V2G hours times the V2G Hour rate. The V2G hours are estimated from the time the car is plugged in: enter the official figure of a month from the widget or below.
Read the tariff grid on mobilize-v2g.frbooleanNo
Subscribed powerselectNo
Price per kWh (€, empty = grid)numberNo
V2G Hour rate (€ per hour, empty = grid)numberNo
Annual subscription (€, empty = grid for your power)numberNo
Count the subscription in the balancebooleanNo
Buyback of the energy sent back (€/kWh, 0 = none)numberNoThe Mobilize information sheet says the energy sent back is bought at the selling price; the V2G hours are the main gain. Leave 0 unless your invoice shows such a credit.
Cómo instalar Mobilize Power V2G en Gladys​
  1. En Gladys, abre Integraciones: Mobilize Power V2G aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/gaetanb76/gladys-mobilize-v2g:0.2.0), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/Gaetanb76/gladys-mobilize-v2g.
Mobilize Power V2G requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Mobilize Power V2G es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene Gaetanb76, no el equipo principal de Gladys.
