Integración domótica MENNEKES AMTRON, gratuita y de código abierto
Integración MENNEKES AMTRON para Gladys Assistant
MENNEKES AMTRON charger over Modbus TCP: state, power, energy, pause; optional commands.
This integration shows a MENNEKES AMTRON 4You 400/500 or 4Business 600/700 EV charger in Gladys, read on your local network through Modbus TCP (port 502), without any cloud. It can pause the charge, and, only if you allow it, resume it and set the charging current.
Never tested with a real device. It was built from the register document MENNEKES publishes ("AMTRON 4You 500 / 4Business 700 - Modbus TCP Server - Data Points", protocol 1.5, firmware 1.5.21) and from mennekes-amtron-ha (MIT), and tested against a simulated charger. Unofficial: not affiliated with MENNEKES.
Before you start​
  1. In the installer menu of the charger, enable the Modbus TCP server in "HEMS read and write" mode (register 2010 = 2). In "read only" mode Gladys shows the values but the charger refuses the pause and the commands (the status says so).
  2. Give the charger a fixed IP address on your router.
  3. The charger serves one Modbus client at a time: Gladys opens one short connection per read and closes it, but do not let another energy manager hold the connection.
  4. Modbus TCP has no password: anyone on your network can read and control the charger. Keep it on a trusted network (no port forwarding to the internet).
FieldMeaning
IP address of the chargerModbus port 502 unless you add one (192.168.1.80:502).
Port of the web interface80 unless changed: Gladys reads the serial number there (/api/v1/PublicInfo, no login).
Allow resume and currentOff by default: see "Resume and current" below.
Highest charging current (A)6 to 16 A (16 by default): the most Gladys may set (the document's range, every model).
Refresh intervalSeconds between two reads (30 by default, 10 at least); see "Safe Current" below.
LanguageNames of the device and features added from now on, status and errors.
Save, then add the charger from the Discovery tab.
The Modbus map has no serial number: Gladys reads it on the web interface of the charger (no login) with every read and before every command, at the very address the Modbus connection reached, and keeps it with the model name the charger gives over Modbus. The device is keyed on that serial number: another serial number at the address is another device (the old one shows unreachable), and its values never go to the first one. When the web page cannot be read, that is not another charger: the read is published if the device says over Modbus it is an AMTRON (register 141 = "AM") with the same model, else nothing is published until the serial number is read again. Until the serial number has been read once, nothing is published (the status says why).
The Test the connection button reads the charger once, never sooner than the refresh interval after the last read (it then shows the last result).
FeatureGladys categoryNote
Charge point statustextOCPP status: Available, Preparing, Charging, SuspendedEV…
Connector, charging statecharging stationfrom the OCPP status
Vehicle plugged inEV chargefrom the control pilot (A: no vehicle)
Errorbinary sensor1 when an error code is set
Paused by the limitbinary sensorthe HEMS current limit is below 6 A
Charging powerenergy sensor, W
Current and voltage L1, L2, L3energy sensor, A and Va phase at 0 V (not connected) is left unknown
Energy meterenergy sensor, index (kWh)the meter total of the charger, guarded (below)
Energy of the sessionEV charge, kWhstays at its maximum until the next session
Duration of the sessionduration, minutes
Current offered to the vehicleEV charge, A
Current limit set (HEMS)EV charge, Aregister 2000
Pause / Resume chargingbuttonssee below
Charging currentselection, 6 A to the ceilingsee below
A value that is implausible or not read is left unknown, never published as 0 or as an old value. If an optional block (session, Safe Current, minimum current…) does not answer, the other values are published all the same (the status lists what was not read).
Energy meter​
Gladys counts every rise of an index as consumption. So the meter is never published at 0, and a drop (reset, charger replaced) or a jump larger than the charger can draw (25 kW) is held back: nothing is published for it, the status says so with its values, whatever the time. If it is real, press Accept the held index: the first press shows it, a second press 3 s to 5 minutes later accepts exactly that value.
Pause charging​
Pause charging writes the HEMS current limit to 0 A (register 2000). It does not depend on the option, nor on the value sent by the button, a read in progress (it ends it), a command waiting (it goes first; the commands clicked before it and not sent yet are dropped), a failed read, a backoff, an identity that cannot be read, nor a configuration Gladys cannot read yet (it then goes to the charger of the last read).
The pause answers an error only in these cases:
  • no address is known (none in the configuration, or the configuration cannot be read and no charger was ever read);
  • the charger cannot be reached for 3 s (connection tried again every 250 ms): "could not leave yet", the pause is kept and tried again every 15 s;
  • the charger refuses the write (Modbus TCP server not in "HEMS read and write" mode, or a firmware without register 2000): kept and written again every 15 s;
  • it was sent but the read back does not show it yet: "sent, without confirmation".
A pause not seen applied is kept in /data, one per charger (also across a restart: it is written again at the start, before anything else, even when /data is slow to read) and checked every 15 s: written again while the charger shows the limit it replaced, an unknown limit or nothing. It is let go only in these three cases:
  • the charger it was sent to shows the pause (a limit below 6 A);
  • another limit set elsewhere is read twice in a row on that charger after the pause was written (a newer choice is respected; a pause not written yet is never let go this way);
  • a newer current or resume clicked in Gladys left for that same charger.
It is never let go by time, because it could not leave (charger down, /data stuck), nor by a pause or a command sent to another address: a pause held for an old address (the configuration changed) is still checked every 15 s, with its note in the status, until it is seen applied. While a pause is held, "Charging current" and "Resume" always write (never "already done"), and that write lets the pause go.
Safe Current​
In "HEMS read and write" mode the charger watches the communication: after its communication timeout (register 132) without a read or a write, it applies its Safe Current (register 131). If the Safe Current is above the limit set (a pause included), the charge would start again. So, while that is the case (or while 131 and 132 cannot be read during a pause), Gladys reads the charger at least every half timeout, a failed read tried again within 5 s, a read that finds the line taken tried again within a second, and at once after a restart (the pace is kept in /data), and the status warns that the pause holds only while Gladys reads the charger. The half timeout is taken as 5 s at the least: a communication timeout under 10 s cannot be kept. To keep a pause even when Gladys is stopped, set the Safe Current to 0 A in the installer menu. Gladys never writes these two registers.
Resume and current​
Off by default. With Allow resume and current on, Gladys may:
  • Resume charging: writes back the charging current read before the pause (refused when none was read; choose one with the selection);
  • set the charging current: 6 A up to the configured ceiling, 16 A at most for every model, never below the minimum current the charger gives (register 712). The MENNEKES document gives 6 A to 16 A for register 2000; above 16 A on a 22 kW model is not in it, so Gladys never writes it.
Before each command Gladys reads the serial number on the web interface (another charger, or one that cannot be read, refuses the command), then, in the same Modbus connection, the Device Id, the model, the HEMS mode and the current limit. It refuses while a pause is being sent, checks the option and the configuration again right before the write, and confirms only by a read back showing the value asked. Otherwise it says "sent, without confirmation" (check in a few seconds) or "nothing sent". Commands go one at a time, in their order of arrival; one waiting its turn starts within 15 s or not at all.
Data kept​
/data/mennekes-amtron-state.json (readable by the integration only): the time of the last read, the charger of the last read, its serial number and model, the pauses not seen applied, the pace of reads while a limit below the Safe Current is set, the guard of the energy meter and the current "Resume" sets again. No password, no personal data.
Estos son los parámetros que MENNEKES AMTRON te pide en su pantalla de configuración en Gladys.
Your MENNEKES AMTRON chargersectionNoShows your AMTRON 4You 400/500 or 4Business 600/700 charger in Gladys over Modbus TCP on your local network, without any cloud: state, vehicle plugged in, power, current and voltage per phase, energy meter, energy and duration of the session. In the installer menu of the charger, set the Modbus TCP server to "HEMS read and write"; give the charger a fixed address, enter it below, save, then add it from the Discovery tab. Pausing the charge is always possible; resuming it and the charging current only if you allow them below. The charger serves one Modbus client at a time and Modbus TCP has no password: keep it on a trusted network. Never tested with a real device. Not affiliated with MENNEKES.
IP address of the chargerstringSíAn IPv4 address or a host name (Modbus port 502 unless you add one, for example 192.168.1.80:502).
Port of the web interfacenumberNoThe HTTP port of the charger's web interface, where Gladys reads its serial number (no login): 80 unless changed.
Allow resume and currentbooleanNoOff by default. On: Gladys may resume the charge and set the charging current (6 A up to the ceiling below). Off: these commands are refused. Pausing the charge never depends on this option.
Highest charging current (A)numberNoThe highest current Gladys may set, 6 to 16 A (16 by default): the range the MENNEKES document gives for every model, a 22 kW one included. The charger also applies the limit of its installation.
Refresh interval (s)numberNoHow often the charger is read, in seconds. While a limit below the Safe Current is set, Gladys reads it at least every half communication timeout of the charger (5 s at the least), also after a failed read and a restart.
Language of the feature namesselectNoUsed for the names of the device and features added from now on, the status and the command errors.
Cómo instalar MENNEKES AMTRON en Gladys​
  1. En Gladys, abre Integraciones: MENNEKES AMTRON aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/lm1lc3n7/gladys-mennekes-amtron:0.1.1), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LM1LC3N7/gladys-mennekes-amtron.
MENNEKES AMTRON requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
MENNEKES AMTRON es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LM1LC3N7, no el equipo principal de Gladys.
