Integración domótica MELCloud Home, gratuita y de código abierto
Control your Mitsubishi Electric air conditioners through the MELCloud Home cloud.
Requirements
- A MELCloud Home account (
melcloudhome.com) — the new Mitsubishi Electric platform. If your account was created on the legacy MELCloud (app.melcloud.com), it will not work here: the two platforms are separate. - Your air conditioners already added to your MELCloud Home account (via the MELCloud Home mobile app).
- Enter the email and password of your MELCloud Home account. They are stored encrypted by Gladys and used only to authenticate against MELCloud Home.
- Save. The connection status is shown right on this screen.
The state of your units is refreshed every minute; there is nothing else to configure.
Adding your devices
Your units are published as soon as the integration connects, so they are already listed in the Discovery screen — run a scan to refresh the list.
- Air-to-air units (air conditioners) expose Power, Mode (heat / cool / dry / fan / auto), Target temperature and a read-only Room temperature, plus a Fan speed (auto, or only the speeds the unit actually has). Units fitted with vanes also get Vertical swing and Horizontal swing. Gladys names the "automatic" vane position "off"; it is the automatic position of your unit.
- Air-to-water units (Ecodan heat pumps) expose Power, a Zone 1 temperature setpoint and read-only Zone 1 room temperature, an Outdoor temperature sensor, and — when a hot water tank is present — Hot water temperature (setpoint), a read-only Hot water tank temperature and a Forced hot water switch.
Create the ones you want to control.
Notes
- Air-to-air (air conditioners) and air-to-water (Ecodan heat pumps) units are supported. ERV ventilation units are ignored.
- Zone operation mode (heating curve, flow vs room thermostat) is not controllable yet on air-to-water units.
- The connection status is shown on this screen; if it reports a login failure, re-check your email and password.
Estos son los parámetros que MELCloud Home te pide en su pantalla de configuración en Gladys.
| MELCloud Home account | section | No | MELCloud Home (melcloudhome.com) is the new Mitsubishi Electric platform, separate from the legacy MELCloud. Sign in with the same email and password you use in the MELCloud Home app. |
string | Sí | The email address of your MELCloud Home account. | |
| Password | secret | Sí | The password of your MELCloud Home account (stored encrypted). |
Cómo instalar MELCloud Home en Gladys
- En Gladys, abre Integraciones: MELCloud Home aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
ghcr.io/callemand/gladys-melcloud-home:1.4.0), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración). - Abre la pantalla de Configuración de la integración, rellena los parámetros y guarda.
- También puedes instalarla directamente desde la URL de su repositorio: https://github.com/callemand/gladys-melcloud-home.
MELCloud Home requiere Gladys >=4.86.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
MELCloud Home es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene callemand, no el equipo principal de Gladys.
