Integración domótica MCZ Maestro, gratuita y de código abierto
MCZ pellet stoves with Maestro and Maestro+ Wi-Fi, through the MCZ MAESTRO app cloud.
MCZ pellet stoves with Maestro or Maestro+ technology are controlled with the MCZ MAESTRO phone app, through the MCZ cloud. This integration logs in to that cloud with your app account, like the app does, and brings your stoves into Gladys: turn them on and off, set the temperature, the power and the fans, switch the eco and silent modes, follow the temperatures, the state and the alarms, and react to an alarm in a scene.
Unofficial: not affiliated with MCZ Group.
Development version (0.1). Built on the cloud protocol of the Home Assistant integration used by many MCZ owners, and tested against answers shaped like those of real stoves, not yet against a real stove. Your feedback is welcome on the GitHub repository.
Which stoves
- Maestro+ stoves (Wi-Fi and Bluetooth, the "Maestro+ MCZ" app): air and hydro models such as Cute, Tecla, Ego, Star, Club, Mood, Jazz, Aki, Pad…
- First-generation Maestro stoves once moved to an account with the "MCZ Maestro – Upgrade" app.
Not this integration:
- MCZ stoves with Easy Connect (older Micronova module): use the Micronova Agua IOT integration, app "Easy Connect", "Easy Connect Plus" or "Easy Connect Poêle".
- Palazzetti stoves have their own Gladys integration.
One Gladys device per stove of the account, with the features the model of the stove offers:
| Feature | In Gladys |
| On/off | thermostat mode: off / on |
| Setpoint | thermostat setpoint, with the bounds of the model, by 0.5 °C |
| Heating | operating state: the stove is producing heat or not |
| Room temperature | temperature sensor (°C) |
| Smoke temperature | temperature sensor (°C) |
| State | text: off, ignition, heating, cleaning, standby, shutting down, alarm… |
| Alarm | binary sensor: 1 while the stove is in alarm |
| Last alarm | text: the code of the last alarm and its meaning ("A01: Ignition failed") |
| Power level | a choice among the power levels (1 to 5) |
| Fans | one choice per fan (room fan, ducted fans): off, speed 1 to 5, auto, silent |
| Eco mode | switch: the Start & Stop mode (the stove stops and restarts on its own) |
| Silent mode | switch, on first-generation stoves (on Maestro+ it is the "silent" fan value) |
| Pellets low | binary sensor, when the pellet level sensor of the stove is turned on |
The state reads like "Heating (Potenza 3)": the phase first, the same for every stove, then the text of the stove itself when it sends one.
The fans follow the work mode of the stove, like in the app: in manual (and dynamic/auto) you choose their speed, in comfort and overnight the stove drives them and Gladys says so if you try.
- Check that your stove works in the MCZ MAESTRO app on your phone.
- In the configuration of the integration, type the e-mail and the password of that app.
- Click Test the connection: the stoves of the account are listed.
- Open the Discovery tab and add your stoves.
Options
| Option | Default | Purpose |
| Language of the stove texts | French | names of the features, state and alarm texts |
| Refresh interval | 60 s | how often each stove is read (60 to 3600 s): each reading asks the MCZ cloud |
Scenes
The Stove alarm trigger fires when a stove goes into alarm (failed ignition, flame out, smoke too hot, flue blocked…), once per alarm. Leave the stove empty to watch them all. The scene gets the name of the stove, the alarm code ("A01"…) and its meaning, the state, and a ready-to-send sentence, for example "Living room stove: stove alarm (A01: Ignition failed)" to send as a notification.
The features work in scenes like any device: turn the stove on at 6:30, set the setpoint when you leave, turn the eco mode on at night, check the room temperature in a condition…
How it works
- Gladys talks to the MCZ cloud (
s.maestro.mcz.it) over the Internet, never to the stove directly: the stove must be online in the app. Each reading asks the cloud to reach the stove, then reads its state; one minute is the shortest interval, to stay polite with the MCZ cloud. - The e-mail and the password stay in the Gladys configuration (the password is a secret field) and are only sent to the MCZ cloud.
- The commands follow the model of the stove, as the cloud describes it: only the features your stove has are offered. Gladys shows the new value at once and reads the stove again 5 seconds later to confirm it.
- On a Maestro+ the on/off command is a press of the power button: Gladys sends it only when the stove is in the other state.
- A refused login is retried after 15 minutes, or as soon as you save the configuration. The MCZ cloud has outages now and then: the integration shows the cloud as unreachable and connects again on its own.
Local mode
The first-generation Maestro stoves also open their own Wi-Fi access point
with a local websocket (ws://192.168.120.1:81), and the Maestro+ stoves
talk Bluetooth to the app. Neither is used: Gladys runs the integration in a
container on your home network, which cannot join the stove's access point
nor use Bluetooth. Projects such as maestrogateway bridge the local
websocket to MQTT, if you need a cloud-free setup.
- "refused the e-mail or the password": check them in the MCZ MAESTRO app. An Easy Connect account does not work here (see above).
- No stove: the stove was added with another account. Log in to the app with the same e-mail.
- A stove shown as unreachable, "not connected to the MCZ cloud": the stove lost its Wi-Fi or its power: check it in the app.
- A fan setting is refused: the stove is in comfort or overnight mode, or its silent mode is on: change it in the app or turn the silent mode off.
- "Pellets low" never changes: the stove may not report its pellet sensor to the cloud (the app notifies the empty tank through its own push messages). Tell us on GitHub what your stove does.
Credits
The cloud protocol and the names of the stove commands come from the Home Assistant integration maestro_mcz by Robbe-B and contributors (Apache License 2.0). The historic Maestro states and alarm codes are documented by maestrogateway (Chibald).
Estos son los parámetros que MCZ Maestro te pide en su pantalla de configuración en Gladys.
| Your MCZ stove, from the MCZ MAESTRO app | section | No | For the MCZ stoves with Maestro or Maestro+ technology, controlled with the MCZ MAESTRO app. Type the e-mail and the password of that app: Gladys logs in to the MCZ cloud like the app, offers each stove in the Discovery tab and reads it at the chosen interval (one minute at most). On/off, setpoint, power level, fans, eco and silent modes, room and smoke temperatures, state, pellet sensor and alarms, with a "Stove alarm" scene trigger. Older MCZ stoves with Easy Connect use the Micronova Agua IOT integration instead. Unofficial, not affiliated with MCZ Group. |
| E-mail of the MCZ MAESTRO account | string | Sí | |
| Password of the account | secret | Sí | |
| Language of the stove texts | select | No | Names of the features, state and alarm texts. |
| Refresh interval (s) | number | No | How often each stove is read, between 60 and 3600 seconds. Every reading asks the MCZ cloud to reach the stove: keep it reasonable. |
Cómo instalar MCZ Maestro en Gladys
- En Gladys, abre Integraciones: MCZ Maestro aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
ghcr.io/lm1lc3n7/gladys-mcz-maestro:0.1.1), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración). - Abre la pantalla de Configuración de la integración, rellena los parámetros y guarda.
- También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LM1LC3N7/gladys-mcz-maestro.
MCZ Maestro requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
MCZ Maestro es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LM1LC3N7, no el equipo principal de Gladys.
