Integración domótica LOA - Car Lease Mileage, gratuita y de código abierto
Integración LOA - Car Lease Mileage para Gladys Assistant
Track the mileage of a leased car (LOA/LLD): allowance, projection, extra-kilometre cost.
Your car is leased (LOA or LLD in France) with a mileage allowance: this integration tells you at any time whether you drive too much, what the odometer will read at the end of the contract at your current pace, and what the extra kilometres would cost when you return the car.
A "<vehicle name> (LOA)" device in the Discovery tab, with these values:
ValueMeaning
Compteur kilométriquethe last reading you entered
Compteur prévu à datewhat the odometer should read today if the allowance were spread evenly
Écart avec le prévureading − expected at the reading date; positive = you drive too much
Km restants au forfaitallowance − distance driven; negative once the allowance is exceeded
Budget km par moiswhat you can still drive each month to end exactly within the allowance
Compteur projeté en fin de contratthe final odometer if you keep your current pace
Dépassement projetéthe kilometres over the allowance in that projection
Surcoût projetéprojected extra kilometres × price per extra kilometre
Jours restantsdays until the end of the contract
The feature names are in French (LOA is a French contract); rename them in Gladys if you like. Every value keeps its history, so you can chart it on a dashboard.
The projection only appears after one week of contract: before that, a single long trip would distort it completely.
  1. Open the Configuration tab of the integration and copy your contract:
    • Contract start: the delivery date, as YYYY-MM-DD (e.g. 2025-03-15);
    • Duration in months (36 for 3 years);
    • Mileage allowance for the whole contract (60,000 km for 3 years at 20,000 km/year);
    • Odometer at delivery (often a few kilometres);
    • Price per extra km, from the contract terms.
  2. Save, then add the device from the Discovery tab.
  3. Record a first odometer reading (see below).
While something is missing, the Configuration screen says what to fix.
Recording the odometer​
Three ways:
  • Configuration screen: the Record the odometer button. The summary shows under the button.
  • Dashboard: add the Car lease widget; its New reading button opens a small form, pre-filled with the last reading. Its chart draws the allowance over the whole contract and your own pace, extended to the projected final odometer: when your line runs above the allowance line, you are driving too much.
  • Scene: the Record the leased car odometer action. Handy when your car is connected and another Gladys integration already reads its odometer: a daily scene can pass that value on. In the Odometer (km) field, type {{ and pick the car's odometer value from the list.
A reading a week or a month is enough: the projection uses the average pace since the delivery. A reading lower than the previous one is accepted (fixing a typo).
Scene examples​
  • Overage alert: "device value" trigger on Surcoût projeté above 0 → send a message.
  • Return reminder: trigger on Jours restants below 90 → "book the return inspection".
  • Reading reminder: scheduled trigger every Sunday → "read the car odometer".
The computation​
expected(date) = odometer at delivery + allowance × (days elapsed / contract days)
delta = reading − expected(reading date)
pace = distance driven / days elapsed at the reading date
projected = odometer at delivery + pace × contract days
projected cost = max(0, projected distance − allowance) × price per extra km
budget per month = km left / months left (all of it during the last month)
The contract ends on the start date plus the duration in months (a contract started on 31 January ends on the last day of the target month).
Read the integration logs from the Gladys UI (or docker logs on the host), with LOG_LEVEL=debug for the full detail.
Estos son los parámetros que LOA - Car Lease Mileage te pide en su pantalla de configuración en Gladys.
Your lease contractsectionNoCopy the figures from your lease contract. Then enter the odometer from time to time (button below, dashboard widget or a scene): Gladys compares it with the allowance and projects the end of the contract.
Vehicle namestringNo
Contract start (delivery date)stringSíFormat YYYY-MM-DD.
Duration (months)numberSí
Mileage allowance (km)numberSíFor the whole contract, not per year.
Odometer at delivery (km)numberNo
Price per extra km (€)numberSíWritten in the contract, usually between 0.05 and 0.20 €.
Cómo instalar LOA - Car Lease Mileage en Gladys​
  1. En Gladys, abre Integraciones: LOA - Car Lease Mileage aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/nagromdark/gladys-suivi-loa-lld:1.0.0), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/Nagromdark/gladys-suivi-loa-lld.
LOA - Car Lease Mileage requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
LOA - Car Lease Mileage es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene Nagromdark, no el equipo principal de Gladys.
