Integración domótica Linn & OpenHome, gratuita y de código abierto
Integración Linn & OpenHome para Gladys Assistant
Linn and OpenHome network players, local: standby, volume, sources, pins, playback.
Drive your Linn network players (DS, DSM, Majik, Selekt, Klimax…) and the other OpenHome devices from Gladys, locally, without any cloud: power on, standby, volume, mute, source, pins (the presets of the Linn app), play, pause, next, previous and the title playing.
Important. This integration has never been tested with a real device: it was written from the openhomedevice library (the one of Home Assistant) and tested against a fake device only. Your feedback is welcome. Unofficial integration, not affiliated with Linn Products.
This is not the DLNA integration​
The DLNA integration by guim31 (guim31/gladys-dlna) drives any generic UPnP AV renderer (the AVTransport and RenderingControl services): play a URL or a media server, volume, playback. It works with a Linn too.
This one takes another path: it only talks to the OpenHome services (urn:av-openhome-org), never to AVTransport or RenderingControl. It brings what DLNA has not got:
  • the sources of the device (Playlist, Radio, Songcast, HDMI, analogue, digital inputs…), picked from a list;
  • the pins set in the Linn app: a radio, a playlist, an input, recalled in one click;
  • standby (power on, standby, power state).
It also drives the volume (capped), the mute, the playback and the title, through the OpenHome Volume, Transport and Info services.
It does not play URLs, browse media servers or play notifications: keep the DLNA integration for that. Both can run side by side; the same player can then be created in each. Beware: the volume cap of this integration does not apply to what the DLNA integration sends to the same player.
  1. In Gladys, install the Linn & OpenHome integration.
  2. Choose the volume cap (50 by default) in its configuration.
  3. Open the Discovery tab: the players found by the SSDP search (run by Gladys on your network) are listed. Create them.
A player on another subnet or VLAN is not found by SSDP: type the URL of its UPnP description in the configuration instead (optional field, for example http://192.168.1.30:55178/<uuid>/Upnp/device.xml). A UPnP discovery tool on your computer shows it.
FeatureGladys typeNote
Powerbinary state (read only)1 on, 0 in standby or unreachable
Power onbuttonwakes the player from standby
Standbybuttonputs the player in standby
Volumemusic / volume (0 to 100)capped; absent when the player has a fixed volume
Mutebutton (television / mute)a press reads the state, sets the opposite; 0 unmutes
Play, pausemusic buttons
Next, previousmusic buttonsnot on a radio
Playbackmusic state (read only)1 playing, 0 otherwise
Sourcelistthe visible sources, then the pins ("3. FIP")
Now playingtext (read only)"Artist - Title" (or the radio text); "—" otherwise
On purpose, no switch: an "everything off" or "everything on" from a voice assistant or a scene never wakes up or cuts your player.
Volume cap​
The volume asked from Gladys (dashboard, scene, voice assistant) never goes above the cap of the configuration: a higher volume is set to the cap. The cap is read just before sending: a new value saved applies at once. The volume set on the player itself (knob, remote, app) is not changed, except where Gladys would make it audible:
  • Unmuting: if the volume is above the cap, it is lowered to the cap first, then the mute is removed.
  • Power on, or a source, a pin, Play, Next or Previous while the player is in standby (a Linn then leaves standby): after the wake-up, the volume is read and lowered to the cap if above it. If the player takes time to wake up, the integration checks again every 2.5 s for about 15 s, unless Standby is pressed meanwhile.
The cap is a percentage: when the player announces a maximum volume other than 100 (Volume.Characteristics), the volume and the cap are scaled to its steps.
Reading the state​
The container of the integration has no inbound port: UPnP events (GENA) cannot reach it. The integration therefore reads each created player at a regular interval (10 s by default, 5 to 300 s): standby, source, volume, mute, playback state, and the title only when its counters say it changed. One request at a time per player. In standby, only the standby is read. The source list and the pins are read again every 30 minutes, or when an unknown source is selected.
A player that stops answering is shown as off, named in the status of the integration, and tried again at spaced intervals (up to 5 minutes). A new SSDP search then runs by itself at most every 10 minutes, to follow a new address (the player is recognized by its UDN).
Commands​
Every command gets an answer within 4 seconds (Gladys waits 5 seconds): each request is bounded by what is left of that time, and the cap check after a wake-up goes on in the background if needed. A command that could not leave says "not sent"; a command that left but whose answer is missing or unusable (timeout, HTTP error) says "sent, without confirmation"; a refusal by the player (a SOAP fault) is quoted as is.
A command cancels the state read in flight and goes before it; Standby and mute also go before the other commands waiting. Standby wins over the commands that have sent nothing yet: the one reading is cancelled, and those waiting in the queue that could wake the player (Power on, Source, pin, Play, Next, Previous) are no longer sent; they say "not sent (Standby went first)". Standby only waits for a write already sent, within its time limit, never for a read or a player slow to answer. A source is checked against the list read again from the player before sending; for a pin, the slot is read again and must still hold the same pin (else nothing is sent).
Mute: the dashboard button sends a press, which sets the opposite of the state read. A scene sending 0 unmutes (cap applied); if already unmuted, nothing is sent.
Configuration buttons​
  • Check the players: the state of each created player (power, source, volume, mute) and the cap in force, within 25 seconds (a player that could not be read in time says "not read").
  • List the sources and pins: runs the search again, then lists the visible sources and the pins of each player.
Security, data and privacy​
  • The integration asks for no account and no password: OpenHome has none. It writes nothing on disk. Nothing leaves your local network.
  • The answers of the players are bounded (256 KB for a description, 64 KB for a SOAP answer) and read by a linear XML parser that refuses any DOCTYPE: no external or internal entity is ever resolved.
  • An SSDP answer is kept only when its description URL is http on the private address that answered; every control URL must stay on the same machine and port as the description.
Known limits​
  • No Songcast (room groups), URL playback, notification, balance, sleep timer or firmware update.
  • No UPnP events: a change made on the player shows at the next read at the latest.
  • Never tested with a real device: the real answers may differ.
Estos son los parámetros que Linn & OpenHome te pide en su pantalla de configuración en Gladys.
Your Linn and OpenHome players, on your local networksectionNoPower on, standby, volume, mute, source, pins (the presets of the Linn app), play, pause, next, previous and the title playing of each player that has the OpenHome services (Linn DS and DSM, and other OpenHome renderers), through UPnP on your network, without any cloud. The players are found by an SSDP search and appear in the Discovery tab. The volume set from Gladys never goes above the cap below. This is not the generic DLNA integration: it drives the OpenHome services only (Product for the sources and standby, Pins, and the OpenHome Volume, Transport and Info), never the UPnP AV ones; the cap does not apply to a player also created in the DLNA integration. Never tested with a real device. Unofficial integration, not affiliated with Linn Products.
Volume cap (%)numberNoThe highest volume Gladys may set, from 1 to 100 (100: no cap). A higher volume asked by a scene, a voice assistant or the dashboard is set to this cap; unmuting and waking a player up bring it back under the cap first. The volume set on the player itself (knob, remote, app) is not changed.
Refresh interval (s)numberNoHow often each player is read, from 5 to 300 seconds. A player that does not answer is tried again at spaced intervals (up to 5 minutes).
Description URLs (optional)stringNoOnly for a player the SSDP search cannot reach (another subnet or VLAN): the URL of its UPnP description, separated by commas. Most players are found without it.
Cómo instalar Linn & OpenHome en Gladys​
  1. En Gladys, abre Integraciones: Linn & OpenHome aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/lm1lc3n7/gladys-linn:0.1.3), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LM1LC3N7/gladys-linn.
Linn & OpenHome requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Linn & OpenHome es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LM1LC3N7, no el equipo principal de Gladys.
