Integración domótica Google Chat, gratuita y de código abierto
Integración Google Chat para Gladys Assistant
Unofficial: Gladys messages and alerts in a Google Chat space, through an incoming webhook.
Unofficial integration, not affiliated with Google. Send only: Gladys posts its messages and alerts in a Google Chat space through an incoming webhook. Nothing is read back from Google Chat: you cannot talk to Gladys from there.
This integration has never been tested with a real Google Chat space: it is written from Google's public documentation, and tested against simulated answers.
What you need​
  • A Google Workspace Business or Enterprise account with access to Google Chat. A free personal Google account (gmail.com) cannot create webhooks.
  • Your Workspace administrator must allow users to add incoming webhooks (Admin console → Apps → Google Workspace → Google Chat → Chat apps).
  • A space where the webhook is added (a webhook posts in its own space only).
Create the webhook​
  1. In Google Chat, open the space, click its name → Apps & integrations → Webhooks → Add webhook.
  2. Give it a name (e.g. "Gladys") and an avatar if you like, save.
  3. Copy the URL. It looks like https://chat.googleapis.com/v1/spaces/…/messages?key=…&token=….
The URL is a secret: anyone holding it can post in the space. Gladys keeps it in its database, never shows it again and sends it only to Google Chat; the integration never writes it in its logs, its status or its /data folder (logs name a space by a short fingerprint, like space #3fa91c). If it leaks, delete the webhook in the space and create a new one.
Configuration screen (administrator):
  • Default space: webhook URL (optional): the space of the "Post in Google Chat" scene action and of the Test button.
  • Messages per hour, at most (default 60, 1 to 600): all spaces together, the Test button included. Beyond it a message is not sent (the refusal is logged), it is never kept for later.
My account block (each user, administrators or not): paste the webhook URL of the space where you want the messages Gladys sends you (scene action "Send a message", system messages such as a failed backup or a low battery, the answers of the assistant to a message you typed in Gladys). Clear it to stop.
The scene action "Post in Google Chat"​
Posts a text in the default space. Optional thread key: messages with the same key are grouped in one thread (letters, digits and . _ : -, 64 at most). Outputs for the next actions: posted, deduplicated and message_name (the name Google gives the message). When the same text (and thread key) was sent to that space less than 15 s earlier and posted, nothing is posted again: posted stays true (the message is in the space) and deduplicated is true, so a fallback branch on posted does not fire.
The scene action waits for Google's answer: if the message is refused, or if Google does not answer, the action fails and the scene goes on.
What is sent, and when​
  • Nothing is sent without a Gladys message, a scene or a click on Test. No polling, no background traffic.
  • Gladys writes Markdown; it is turned into the Google Chat syntax: bold, italic, strikethrough, code, links [text](https://…), titles become a bold line. Texts longer than 4,096 characters are cut (ending with "…"), never inside a link or a code block. A mention typed in a text, code included (<users/all>), becomes plain @all: it never notifies the whole space.
  • Images are not sent (a camera snapshot attached to a message): an incoming webhook posts text only. The text of the message is still posted.
  • A "space" here is the Google space (the spaces/… part of the URL), shared by all its webhooks: two users with two webhooks of one space share its limits.
  • One message every 1.1 s per space (Google's limit is one a second): a message waits its turn for up to about 2 s; a burst beyond that is not sent ("too many messages at once").
  • The same text to the same space within 15 s is posted once: when several users receive the same space, a message Gladys sends to all of them appears once. A duplicate gets the outcome of the first message: if the first one failed, the duplicate fails too; it is never said "posted" before the first one is.
Never sent twice​
A message that may have reached Google is never sent again, so the integration never posts it twice. What each answer leads to:
Answer of Google ChatWhat happens
Posted (200)Done.
429 (too many requests)Nothing posted. The Google space (all its webhooks) is paused (the delay Google gives, else 1 min, then 2, 4… up to 6 h). During the pause, messages to that space are not sent. The pause survives a restart.
401, 403, 404The URL is refused: webhook deleted, token revoked, or webhooks turned off by the administrator. Nothing more is sent to that URL until a new URL is saved, the Test button succeeds (default space), or Forget the refused webhook URLs is clicked. Kept across restarts as an 8-bit salted fingerprint, never the URL. Other webhooks of the same space are not refused.
Another 4xxNothing posted (the message was rejected); the next message is tried.
5xxMaybe posted, maybe not: not sent again, the space paused like a 429.
No answer within 10 sMaybe posted: not sent again.
Network, DNS, certificate error before sendingNothing sent; the next message is tried.
Gladys gives a message 5 seconds: the integration answers it within 3.5 s; a message still waiting for Google then goes on and its outcome is logged.
Test button​
Test the default space posts one test message in the default space and says what Google answered. It counts in the hourly cap and is not sent during a pause, like any message; a click tries the default URL again even when it was refused. Two clicks within 15 s: the second says "Already posted".
Forget the refused webhook URLs (administrator) clears every refusal: the next message to each refused URL, of the default space or of a user, is tried once. The click sends nothing. A user can also save a new URL in "My account".
Status​
The Configuration screen shows: ready (with or without a default space), a default URL that is not a Google Chat webhook URL, a default URL refused by Google, a pause in progress, or a configuration that could not be read (read again every 5 s, then less and less often, up to every 5 min).
Privacy​
What leaves Gladys: the text of the messages, to Google Chat (chat.googleapis.com) only, over HTTPS. A redirect is never followed. What /data/state.json keeps: a random salt, 8-bit salted fingerprints of the refused URLs and of the paused spaces (one URL in 256 shares a fingerprint, so the file never confirms a URL), the end dates of the pauses and the times of the messages of the last hour (for the hourly cap). Never a URL, a key, a token or a message text.
A collision is possible: after a restart, the first message to a URL whose fingerprint is the one of a refused URL is held back, with a message saying it may be another URL. A default URL saved after the restart never inherits such a mark. A user whose contact URL is held back this way asks the administrator to click Forget the refused webhook URLs (or saves a new URL); for the default space, the Test button also lifts it.
If /data cannot be read when the integration starts, messages still go; the refusals, pauses and messages learnt since the start are kept in memory, but those kept from before the restart are unknown until /data is read again (every 10 s).
Estos son los parámetros que Google Chat te pide en su pantalla de configuración en Gladys.
Google Chat in GladyssectionNoUnofficial connector, not affiliated with Google. Send only: Gladys posts in a Google Chat space, nothing is read back. Incoming webhooks need a Google Workspace Business or Enterprise account, and the Workspace administrator must allow users to add webhooks; a free personal Google account cannot create one. In the space: name of the space → Apps & integrations → Webhooks → Add webhook, then copy its URL. Each Gladys user pastes the URL of their space in “My account” to receive the messages Gladys sends them; the default space below serves the “Post in Google Chat” scene action and the Test button. Nothing is ever sent without a Gladys message, a scene or a click.
Default space: webhook URL (optional)secretNoUsed by the scene action and the Test button. The URL lets anyone post in the space: kept by Gladys in its database, never shown again, sent only to Google Chat, never written in the logs.
Messages per hour, at mostnumberNoAll spaces together, the Test button included. Beyond it, a message is not sent (it is logged). Google Chat itself takes one message a second per space.
Cómo instalar Google Chat en Gladys​
  1. En Gladys, abre Integraciones: Google Chat aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/lm1lc3n7/gladys-google-chat:0.1.1), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LM1LC3N7/gladys-google-chat.
Google Chat requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Google Chat es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LM1LC3N7, no el equipo principal de Gladys.
