Integración domótica Fumis WiRCU, gratuita y de código abierto
Integración Fumis WiRCU para Gladys Assistant
Pellet stoves with a Fumis WiRCU module (Austroflamm, Haas+Sohn…), read only, via the cloud.
Unofficial integration, not affiliated with Fumis (ATech elektronika) nor with the stove makers. It brings into Gladys a pellet stove with the Fumis WiRCU Wi-Fi module (Austroflamm, Haas+Sohn, Westfeuer and other brands that use Fumis electronics), through the Fumis cloud, read only.
Warning: never tested with a real stove. This integration was written from the python-fumis library (the one of the Home Assistant integration) and tested against a fake cloud only. Feedback is welcome.
Undocumented API. Fumis has not documented the API of its cloud (api.fumis.si) officially: the reference library learnt it by observing its own stoves. It may change or go away without notice, and the integration stop working.
One Gladys device, Fumis stove (or "Austroflamm Clou Duo stove" for a known model), with, when the stove sends them:
FeatureValue
StateOff, Heating up, Ignition, Burning, Eco, Cooling down
PhaseThe detailed phase of the stove (Pre-combustion, Cold start, Wood combustion…)
Operating0/1
Room temperature°C, the main sensor of the stove
Target temperature°C, read only (a sensor, not a thermostat)
Combustion chamber temperature°C (Austroflamm and stoves with a thermocouple)
Power level (set)1 to 5 usually
Heat output (kW)While burning only; 0 when off; nothing in the other phases
Pellet level (%)Only when the stove estimates it
Error, Error code0/1, and "E102: Chimney or burning pot dirty…"
Warning, Warning code0/1, and "A001: Low fuel level"…
Eco mode0/1, when the stove has one
Door open0/1, on the Austroflamm Clou Duo only (the only model where it was checked)
Time to serviceHours (negative when the service is overdue)
Burning timeHours
Igniter starts, Misfires, OverheatingsCounters
Wi-Fi signal (%)The signal of the WiRCU module
kW and % have no unit in Gladys (the core lists none for these categories): the unit is in the name. The heat output is the one the stove reports while burning (Combustion and Wood combustion phases); when off it is 0 (the stove may keep reporting its nominal power), and during ignition, eco or cooling no value is sent (it lags behind). It is not sent to the Gladys energy dashboard (it would count it as electricity).
Scene trigger Fumis stove error or warning: when a read shows a new error code (E…) or warning code (A…). Variables: message, code (E102, A001…) and kind (error or warning). The same code fires again only after it cleared. The codes last seen are kept in /data: a restart never fires an alarm still shown again. Never at the very first read. A code that is not an integer from 0 to 999 is ignored: the known code is kept and nothing fires.
The badge of the device shows "cloud", or "unreachable" when the cloud does not answer, refuses the MAC address or the PIN, does not reach the stove, or has not seen it for more than 10 minutes.
  1. The stove must already work with the app of its brand (for example Austroflamm PelletControl): the WiRCU module is on your Wi-Fi and reaches the Fumis cloud.
  2. Note the MAC address and the PIN printed on the label of the WiRCU module (the ones the app asks for).
  3. In Gladys, install the Fumis WiRCU integration, enter the MAC address (with or without ":") and the PIN, then save.
  4. Add the stove from the Discovery tab.
One stove per integration. When you change the MAC address, the old stove stays in Discovery with its features and an orange badge: delete it if you no longer want it.
Read only​
This first version controls nothing: no ignition, no shutdown, no setpoint, no power level, no eco mode. A stove is a flame appliance, commands go through a cloud that relays them to the stove 2 to 5 minutes later without confirmation, and the integration was never tested with a real stove: v1 only reads. Every feature is read only; a command from Gladys (scene, dashboard, voice assistant) is refused and nothing is sent.
PIN, MAC address and privacy​
  • The PIN is kept by Gladys in its database, never shown again, and sent only to the Fumis cloud (api.fumis.si, over HTTPS), in a header of each read, as the app does. The MAC address goes with it: together they give access to the stove.
  • Neither the PIN nor the MAC address appears in the logs, the status messages, the request URLs or the Gladys devices. The device is identified by a hash of the MAC address (scrypt, computed once at start, never with the PIN). This hash is no secret: the MAC addresses of WiRCU modules all start with 00:16:D0, so the address can be found back by trying the 16 million candidates (scrypt makes that take days instead of seconds). The secret is the PIN.
  • The /data volume of the integration only keeps the current pause (429 or the wait after errors), a stop on refused credentials and the error and warning codes last seen, with that hash of the MAC address. Never the PIN, nor a hash of it.
  • The integration introduces itself under its own name (User-Agent gladys-fumis), never as the app of a stove maker.
Refresh​
The stove is read every 60 seconds by default (60 to 3600), one request at a time, never two closer than 3 seconds. The cloud gets new values from the stove about every 30 seconds. The Test the connection button and Discovery read only when the interval (30 seconds at least) has passed since the last attempt, successful or not, and no pause holds; otherwise the button shows the status and the time left.
Errors​
  • MAC address or PIN refused (HTTP 401): reads stop; a new try after 10 min, 1 h, then every 6 h, or at once when you change them. Test the connection also tries again, once the interval has passed since the last attempt. Only a successful read lifts the stop, and it is kept across restarts.
  • Stove not connected to the cloud (HTTP 404, WiRCU module off or without Wi-Fi) or not seen for more than 10 minutes (the cloud then sends its last values, which are not shown), cloud unreachable, cloud error (5xx): a new try after 1, 2, 5, 10 then every 15 minutes, never faster than the interval. This wait is kept across restarts.
  • HTTP 400 or 403: the cloud refuses the request itself (not the PIN); it may refuse clients other than the stove apps. Same wait, and the status says so.
  • HTTP 429: a pause of at least 1 minute (Retry-After when given, 6 h at most), for every path, kept across restarts.
  • A pause of the cloud itself (429, 5xx, cloud unreachable) holds when you change the MAC address; the one of an offline stove does not.
  • An answer too large (over 256 KB) or not JSON is refused.
Limits​
  • Never tested with a real stove: the fields come from the reference library and its sample answers.
  • API not documented officially: it may change without notice.
  • Internet access is needed: without the cloud, no values (the WiRCU module has no documented local API).
  • No command (see the TODO file of the repository for a v2).
Credits​
  • python-fumis by Franck Nijhof (MIT), 0.4.2: the cloud API, the status, error and warning codes and the reading of the values are ported to JavaScript.
  • See THIRD_PARTY_NOTICES.md.
Fumis, WiRCU, Austroflamm, Haas+Sohn and Westfeuer are trademarks of their owners; this project is not affiliated with Fumis nor with these makers.
Estos son los parámetros que Fumis WiRCU te pide en su pantalla de configuración en Gladys.
Your Fumis stovesectionNoBrings a pellet stove with a Fumis WiRCU Wi-Fi module (Austroflamm, Haas+Sohn, Westfeuer and other brands) into Gladys, read only: state, room temperature, setpoint, power level, heat output, pellet level, errors and warnings, counters, and a scene trigger on a new error or warning. Read every minute through the Fumis cloud, the one the stove apps use; Fumis does not document this API officially. Nothing can be changed on the stove from Gladys: no ignition, no shutdown, no setpoint. Never tested with a real stove. Not affiliated with Fumis nor with the stove makers.
MAC address of the WiRCU modulestringSíPrinted on the WiRCU module (12 hexadecimal digits, with or without ":"). Sent only to the Fumis cloud, never shown in the devices.
PIN of the WiRCU modulesecretSíPrinted on the WiRCU module, next to the MAC address. Kept by Gladys in its database, never shown again, sent only to the Fumis cloud (api.fumis.si, over HTTPS, in a request header).
Refresh interval (s)numberNoSeconds between two reads of the stove (60 to 3600). The cloud gets new values from the stove about every 30 seconds.
Language of the namesselectNoUsed for the names of the device and the features added from now on, the states, the error and warning texts.
Cómo instalar Fumis WiRCU en Gladys​
  1. En Gladys, abre Integraciones: Fumis WiRCU aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/lm1lc3n7/gladys-fumis:0.1.1), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LM1LC3N7/gladys-fumis.
Fumis WiRCU requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Fumis WiRCU es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LM1LC3N7, no el equipo principal de Gladys.
