Integración domótica Flo by Moen, gratuita y de código abierto
Unofficial: Flo by Moen water shutoff and leak sensors, flow, pressure, alerts, Home/Away.
This integration brings the Flo by Moen Smart Water Shutoff and the Flo Water Sensors into Gladys, through the Flo cloud the Moen Smartwater app (formerly Flo) uses, with the e-mail and password of your account. These products are sold in the United States and Canada. Unofficial, not affiliated with Moen or Fortune Brands.
Development version (0.1). Written from the Python library
aioflo(the one of the Home Assistant Flo integration). The integration has never been tested on a real device or a real account: only against simulated answers. Feedback is welcome on the GitHub repository.
| Flo device | In Gladys |
| Smart Water Shutoff (valve) | valve open/closed and away mode (settable, see "Safety"), mode (text: home, away, sleep), flow m³/h, pressure psi, water temperature °C, today's use in litres, leak alert, pending alerts (text) |
| Water Sensor (leak sensor) | water leak, temperature °C, humidity %, battery % |
Other Flo devices (bridge…) are skipped: the Test the connection button counts them.
Units: the flow is converted from gallons per minute to m³/h, the use from gallons to litres, temperatures from °F to °C (Gladys shows them as you prefer). The pressure stays in psi. A shutoff without a water temperature probe sends a placeholder (225 °F): it is ignored.
- In the Configuration tab, enter the e-mail and password of your Flo or Moen Smartwater account, then save. The status reads "Connected to Flo: 2 devices."
- Open the Discovery tab and add the devices you want. Their values arrive as soon as they are added.
Sign-in: "Automatic" (default) tries the historical Flo sign-in, then the Moen one (newer Moen Smartwater accounts) when Flo refuses or no longer answers there. Once Flo refused, only Moen is tried until the configuration changes. You can force either.
Safety: commands off by default
These commands are refused until you allow them in the configuration:
| Option | Default | Off: Gladys… |
| Allow closing the valve | no | never shuts the water off |
| Allow opening the valve | no | never turns the water on |
| Allow changing the Home/Away mode | no | never changes the Flo mode |
To shut the water off from a scene when a leak is detected, turn on "Allow closing the valve". Even allowed, a valve command:
- runs one at a time for a device (two "close" at once are never sent together);
- reads the device from Flo just before acting: if that read fails, the device is offline, or the valve is moving the other way or in an unknown state, the command is refused; the state kept in memory never decides;
- sends nothing when the valve is already where asked, or already moving there;
- is refused rather than sent late when it could not leave in time (3.5 seconds after the request from the dashboard, 25 seconds for a scene action): Gladys would already have shown a failure;
- reads the device again 15 seconds and 60 seconds later (even after a failure), to show the real position.
Warning: as soon as a valve option is on, the valve is a Gladys switch like any other. A voice assistant, a "turn everything off" command or a scene acting on every switch can then shut (or open) the water. Check your scenes and assistants before turning these options on.
Home / Away mode (the "Away mode" switch or a scene action): off by default. Switching to Home disarms the automatic shutoff Flo applies in Away: turn the option on knowingly. Sleep needs a duration: it is shown, but set in the Moen app. A mode Flo has locked is refused.
Scenes
Triggers:
- Flo: leak detected: a Water Sensor detects water, or Flo raises a new critical or warning leak alert (water detected, drip, failed health test); filtered by severity;
- Flo: abnormal flow: a new critical or warning fast flow, long flow or high use alert;
- Flo: new alert: any new alert, filtered by severity and family.
A trigger fires once per new alert, at the refresh that finds it (an alert
still pending does not fire again). What the integration saw last is kept in
/data: an alert raised during a restart fires at the next start. The alerts
of a device never seen before do not fire (nothing says they are new).
The family of an alert (leak, flow, other) comes from its name in the Flo alarm catalog, read once a day, matched against a list of known names. When the catalog is unavailable (or an alert is not in it), the alert is "other": only "new alert" fires, and, by caution, an unknown critical alert turns "Leak alert" on. The "Pending alerts" feature always lists every alert.
Recommended to shut the water off: besides "leak detected", make a scene on the "device state changed" trigger of the Water leak feature of the Water Sensor (or Leak alert of the shutoff) going to 1. That state is read again at every refresh, even if a scene event was missed.
Actions: Flo: set Home or Away (one home or all) and Flo: open or close the valve, behind the options above.
Usage limits
- Flo publishes no API limit. The integration reads the account and each device every 2 minutes by default (1 to 60), today's use every 15 minutes and the alarm catalog once a day: Home Assistant's pace (1 minute) or slower.
- When Flo answers "too many requests" (429), the integration pauses for the time asked (1 minute to 1 hour, 5 minutes when not given). After a network error or a Flo outage it tries again after 1, 2, 5, 10 then 15 minutes.
- A refused e-mail or password is never retried by itself: the integration waits for a change or a click on Test the connection.
- Values arrive at the refresh pace, not in real time.
- Gladys accepts 300 states a minute: only the values that change are sent (and every value at least every 30 minutes).
Options
| Option | Default | Role |
| E-mail, password | — | your Flo / Moen Smartwater account |
| Allow closing the valve | no | see "Safety" |
| Allow opening the valve | no | see "Safety" |
| Allow changing the Home/Away mode | no | see "Safety" |
| Sign-in | Automatic | Flo then Moen, or either one |
| Refresh interval (min) | 2 | how often the devices are read |
| Language of the feature names | French | names of the features of the devices added |
- "Flo refused the e-mail or the password": check them in the Moen Smartwater app. Try the "Moen" sign-in if your account was made in the Moen app.
- "Flo cannot be reached": a Flo outage or your connection; the integration tries again by itself.
unreachablebadge with an orange dot: Flo reports the device offline (Wi-Fi, sensor batteries).- "The state of the Flo valve could not be confirmed": the valve was offline, moving or unreadable when the command came; try again later.
- "The command waited too long for its turn": Flo answered slowly; try again.
Privacy
The e-mail and password are kept by Gladys in its database (and so in its
backups); the password is never shown again in the interface. They are only
sent to the Flo sign-in (api.meetflo.com) and the Moen one (Amazon Cognito,
execute-api.us-east-2.amazonaws.com), over HTTPS. The token stays in memory
and never reaches a log. The only file written to /data (flo-seen.json)
holds the alert counts and the "water detected" state of each device, no
secret.
Flo by Moen and Moen are trademarks of Moen Incorporated (Fortune Brands); this integration is not affiliated with Moen.
Estos son los parámetros que Flo by Moen te pide en su pantalla de configuración en Gladys.
| Your Flo by Moen account | section | No | Brings the Flo by Moen Smart Water Shutoff (flow, pressure, water temperature, today's use, valve, Home/Away mode, alerts) and the Flo Water Sensors (leak, temperature, humidity, battery) into Gladys, through the Flo cloud the Moen Smartwater app uses (US and Canada products). Enter the e-mail and password of your Flo or Moen account. Scene triggers fire on new leak and abnormal flow alerts. Opening or closing the valve and changing the mode stay off until you allow them below. Unofficial, not affiliated with Moen or Fortune Brands; never tested on a real device yet. |
| E-mail of the Flo account | string | Sí | |
| Password | secret | Sí | Kept by Gladys in its database, never shown again, sent only to Flo/Moen (HTTPS). |
| Allow closing the valve from Gladys | boolean | No | Off by default. Turn it on to shut the water off from a scene when a leak is detected. |
| Allow opening the valve from Gladys | boolean | No | Off by default: reopening the water after a leak should be done on site. |
| Allow changing the Home/Away mode from Gladys | boolean | No | Off by default. Warning: Home disarms the automatic shutoff Flo applies in Away. |
| Sign-in | select | No | Automatic tries the Flo sign-in, then the Moen one (the newer Moen Smartwater accounts). |
| Refresh interval (min) | number | No | How often every device is read, in minutes (1 to 60). Today's use is read every 15 minutes. |
| Language of the feature names | select | No | Used for the names of the features of the devices added from now on. |
Cómo instalar Flo by Moen en Gladys
- En Gladys, abre Integraciones: Flo by Moen aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
ghcr.io/lm1lc3n7/gladys-flo:0.1.1), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración). - Abre la pantalla de Configuración de la integración, rellena los parámetros y guarda.
- También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LM1LC3N7/gladys-flo.
Flo by Moen requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Flo by Moen es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LM1LC3N7, no el equipo principal de Gladys.
