Integración domótica FF-Agent, gratuita y de código abierto
Integración FF-Agent para Gladys Assistant
Receive FF-Agent alarms via Gladys Plus and send acceptance or rejection responses.
This external provider integration targets Gladys Assistant 5.2.1 or newer. Accept/reject actions send real HTTP requests to FF-Agent. HTTP success does not prove FF-Agent recorded the mission response; check it there. This does not replace official alarm systems.
Acceptances and rejections require neither Gladys Plus nor an Open API key. Plus and its key are only needed for real incoming FF-Agent alarms via webhook. Local simulation triggers scenes without Plus or a key.
Configuration and use​
Install the local development image and manifest as described in the repository README. Start the integration's local Node process. In Configuration, press Simulate incident. Add FF-Agent incident to a dashboard to see the latest incident and its response buttons. Widget buttons require confirmation and send real requests, even for a test alarm. Test scenes can also send real responses. Configuration and scene actions need no additional incident ID and no prior alarm.
Find the reply UUID in FF-Agent → Personal profile → “Weblinks für Einsatzmeldung”. Example: https://www.ff-agent.com/app2/missionreplies/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/accept. Copy only your UUID in place of the x characters, between /missionreplies/ and /accept or /reject, not the full URL or parameters such as ?transport=CAR. The reply UUID stays visible and editable. Acceptance also requires transport (CAR/BICYCLE/FEET) and a native Gladys house selection. Rejection only needs the UUID. Acceptance actions optionally override transport for that request only; leave the field empty to use the configured default. The saved configuration is not changed. This applies to scene and configuration actions; widget buttons use the default. Coordinates come from the selected Gladys house, requiring the declared location permission. Reply actions validate their required settings before sending a real request and then check the HTTP response. No separate settings check is needed. Simulation does not require these settings. Never share personal reply links.
Set up the FF-Agent generic webhook​
Connect the intended instance to Gladys Plus. Create a key under Plus → Settings → Open API and save it in this integration's native Webhooks section in Gladys. The native Gladys Plus Webhooks card shows the current complete URL including the key. Paste it into FF-Agent’s Generic webhook form: POST, HTTPS, JSON, and body {}. No Basic authentication or additional headers; FF-Agent sets Content-Type. Omit https:// from the URL if FF-Agent's protocol dropdown supplies it separately. The URL is secret; never use a personal reply link as the alarm endpoint. After key rotation, retrieve the new URL and replace it in FF-Agent.
For privacy, FF-Agent supplies no incident details: only an alarm signal is needed. Do not send incident IDs, titles, categories, locations or timestamps. The handler ignores the body and processes POST only. Gladys acknowledges immediately using fire_and_forget, without waiting for scenes. HTTP 200 is not proof of reception: disconnected/stopped integrations can lose signals. Send a test from FF-Agent and check the widget/scene trigger in Gladys before operational use. Every delivered POST counts as an alarm; without event IDs, reliable deduplication is impossible. Connection and processing each have a five-second timeout according to the FF-Agent form. Local authenticated REST simulation uses the same reception path, but does not test FF-Agent → Plus delivery. FF-Agent cannot reach this Mac through localhost. Do not change the existing production Plus link.
The scene trigger Incident received has no filters and exposes only received_at, generated locally on the Gladys system (UTC/ISO 8601), not supplied by FF-Agent. Test alarms use the same minimal data; no simulation flag or incident details are passed to scenes. The widget labels tests and shows only the local reception time. Both reply scene actions output only success: true for HTTP 2xx (also when no incident is active), false for invalid settings, HTTP errors or an unconfirmed request. Scenes continue after a false result so subsequent steps can evaluate it. This is HTTP success, not proof of an operational response. A timeout may occur after FF-Agent processed the request, so false must not trigger automatic retries. Configuration and widget buttons still display detailed messages/errors. Requests time out after five seconds with no automatic retries or redirects.
Limitations and troubleshooting​
Only the latest alarm is held in memory; restarting clears it. Docker Desktop and Node 24 are required for the documented local setup. Keep the registration container running and use only one active SDK process per selector. npm run dev synchronizes registration and the integration token automatically. Never commit tokens or actual incident data. See the repository README for setup and logs.
Widget: alarms and replies​
“No alarm” means no open alarm received locally, not verification of FF-Agent or the alarm connection. An alarm shows a red state, reception time and buttons for immediate acceptance/rejection, without a confirmation dialog. Test alarms are clearly marked. After a successful HTTP acceptance, “Sent” remains until “End incident” is pressed, then idle returns with the last reply and reply time. A successful HTTP rejection or explicit no-active-incident response returns idle immediately. Errors/timeouts keep alarms open; never retry automatically. New alarms interrupt acceptance displays; stale/concurrent clicks cannot dismiss them. Scene/configuration actions update the same history. None of this proves an operational mission reply. “End incident” only resets the display and sends nothing to FF-Agent. The display refreshes normally every ten seconds; browser suspension or connection failures may delay the display. Times use your browser's local timezone. History records the decision sent; an explicit FF-Agent “no active incident” response is shown separately. Only the last alarm and successful request remain in memory; a restart clears both.
Supervision → Start starts/restarts the Docker container, even when already running. It is unnecessary while connected and does not start the local Mac Node process; use npm run dev for that. Logs reads Docker output only: during local development see the npm run dev terminal; the idle registration container has no application logs. With the production image, refresh Logs in Gladys to see them. Technical logs are in English and describe alarm/test reception, event publication, reply attempts, HTTP status and failures. They never contain UUIDs, coordinates, keys, URLs, webhook bodies or raw provider responses. Reception does not prove scene execution or an operational reply. UI reply errors follow the selected Gladys language.
Estos son los parámetros que FF-Agent te pide en su pantalla de configuración en Gladys.
Real FF-Agent responsessectionNoAcceptances and rejections work without Gladys Plus or an Open API key. Plus and its key are only needed for incoming FF-Agent alarms; local simulation also works without them. Responses send real requests, even for test alarms. HTTP success is not proof of a mission response; check FF-Agent if unclear.
Reply UUIDstringNoFF-Agent → Personal profile → “Weblinks für Einsatzmeldung”. Example: https://www.ff-agent.com/app2/missionreplies/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/accept — copy only your UUID in place of the x characters, between /missionreplies/ and /accept (or /reject), not the full URL or its parameters.
TransportselectNoTransport sent with an acceptance. Rejections only use the reply UUID.
Home in GladysselectNoCoordinates for acceptances. Set the location in this house's settings.
Set up alarms in FF-AgentsectionNoSave your Plus Open API key in the Gladys Plus Webhooks card below, then copy its alarm URL into FF-Agent’s “Generic webhook” form. POST · HTTPS · JSON body: {}. No Basic authentication or extra headers. Omit https:// from the URL if the protocol is selected separately. Keep the URL private. Send a test alarm from FF-Agent and check reception in Gladys; HTTP 200 alone is not proof of delivery.
Cómo instalar FF-Agent en Gladys​
  1. En Gladys, abre Integraciones: FF-Agent aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/stefanbauer/gladys-ff-agent:1.0.1), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/stefanbauer/gladys-ff-agent.
FF-Agent requiere Gladys >=5.2.1. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
FF-Agent es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene stefanbauer, no el equipo principal de Gladys.
