Integración domótica De Dietrich, gratuita y de código abierto
Control your De Dietrich heating, hot water and boiler sensors via the De Dietrich cloud.
Control your De Dietrich connected heating system from Gladys Assistant, through the De Dietrich cloud (the same service used by the De Dietrich mobile app, powered by the BDR Thermea platform).
Features
- Heating (climate zones) — read the room temperature and read/set the target temperature of each heating zone. Setting a temperature applies a temporary override when the zone follows its schedule, or switches it to manual mode otherwise, exactly like the app.
- Domestic hot water (DHW) — read the current water temperature and read/set the comfort setpoint of each hot-water zone.
- Boiler sensors — read the outdoor temperature and the water pressure of the appliance.
- Energy consumption — read the cumulative heating and domestic-hot-water energy consumed (in kWh), when the appliance reports it. These are meter-style indexes that feed the Gladys energy graphs.
- Install the integration from the Gladys integrations store.
- Open its configuration and fill in the email and password of your De Dietrich account (the same credentials you use in the De Dietrich mobile app).
- Go to the Discovery tab and start a scan: your heating zones, hot-water zones and boiler appear and can be added to Gladys.
Your devices are polled once per minute. Heating and hot-water setpoints you change from Gladys are sent straight to the De Dietrich cloud.
Notes
- This integration talks to the De Dietrich cloud, so an internet connection and a working De Dietrich account are required.
- Your credentials are stored encrypted by Gladys and are only used to authenticate against the De Dietrich cloud.
Estos son los parámetros que De Dietrich te pide en su pantalla de configuración en Gladys.
| De Dietrich email | string | Sí | The email address of your De Dietrich account. |
| De Dietrich password | secret | Sí | The password of your De Dietrich account. |
Cómo instalar De Dietrich en Gladys
- En Gladys, abre Integraciones: De Dietrich aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
ghcr.io/callemand/gladys-dedietrich:1.0.0), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración). - Abre la pantalla de Configuración de la integración, rellena los parámetros y guarda.
- También puedes instalarla directamente desde la URL de su repositorio: https://github.com/callemand/gladys-dedietrich.
De Dietrich requiere Gladys >=4.62.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
De Dietrich es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene callemand, no el equipo principal de Gladys.
