Integración domótica Daikin Airbase, gratuita y de código abierto
Daikin ducted air conditioning via a local Airbase (BRP15B61) adapter: mode, temperature, zones.
Controls Daikin ducted air conditioning fitted with an Airbase (BRP15B61) Wi-Fi adapter, directly on your local network — no Daikin account or cloud.
Features
- Power, Mode (auto, cool, heat, dry, fan), Target temperature and Fan speed (auto, low, mid, high).
- Indoor temperature, and Outdoor temperature when the unit reports it.
- One switch per zone, named as in the Daikin Airbase app.
- In your router, give the adapter a fixed IP (DHCP reservation).
- Enter that IP in the Configuration tab (several adapters: separate with commas).
- Open the Discovery tab and create the device.
- No Airbase adapter answered — check the IP, and that
http://<ip>/skyfi/common/basic_infoopens in a browser on the same network. - Changes from the wall controller appear after the refresh interval (30 s by default).
- Logs:
docker logson the integration container.
Estos son los parámetros que Daikin Airbase te pide en su pantalla de configuración en Gladys.
| Airbase adapters | section | No | The adapter is reached directly on your network, no Daikin account needed. Give it a fixed IP (a DHCP reservation on your router) so it keeps the same address. |
| Adapter IP address(es) | string | Sí | One or more, separated by commas, e.g. 192.168.1.50 |
| Refresh interval (s) | number | No | How often the adapter is read; changes made from the wall controller or the Daikin app appear within this delay. |
Cómo instalar Daikin Airbase en Gladys
- En Gladys, abre Integraciones: Daikin Airbase aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
ghcr.io/plsoftware/gladys-daikin-controller:0.1.1), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración). - Abre la pantalla de Configuración de la integración, rellena los parámetros y guarda.
- También puedes instalarla directamente desde la URL de su repositorio: https://github.com/plsoftware/gladys-daikin-controller.
Daikin Airbase requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Daikin Airbase es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene plsoftware, no el equipo principal de Gladys.
