Integración domótica Corrently GrünstromIndex, gratuita y de código abierto
Unofficial connector: Corrently GrünstromIndex, how green the power is per German postcode.
Unofficial connector, not affiliated with Corrently or STROMDAO. Never tested with a real Gladys installation yet: it was tested against the live Corrently API and a simulated Gladys.
The GrünstromIndex (green power index) tells, from 0 to 100, how much of the power around a German postcode comes from renewables, hour by hour, about five days ahead. Use it to run the washing machine, the heat pump or the car charge in the greenest hours.
Setup
- Enter your German postcode (five digits, leading zero included, e.g.
01067). - Save, then open the device
GrünstromIndex <postcode>in the integration's devices page.
| Feature | Meaning |
| GrünstromIndex | The index of the current hour (0-100) |
| GrünstromIndex next hour | The index of the next hour |
| GrünstromIndex best of 24 h | The highest index of the 24 hours starting with the current one |
| Hours until the greenest hour | Hours from now to that greenest hour (0: now; the earliest on a tie) |
An hour the forecast does not cover stays unknown (no value is published); the best of 24 h stays unknown unless all 24 hours are known. A forecast computed more than 72 hours ago is not used (its date is the time Corrently computed it, which a cached copy can put a few hours back).
Energy calendar green-power-index-de: every half hour gets a level, low (index 0-33),
medium (34-66) or high (67-100), up to seven days ahead. A tariff template of the Gladys energy
contracts (community catalogue or another integration) can read it. These bounds never change.
Reads and fair use
- One read per hour at most, as the Corrently fair-use policy asks. The time of each attempt is saved
in
/databefore the request, so a restart, a configuration save or a new postcode does not read sooner. A configuration saved during a read keeps its answer. - The Read the forecast button reads only when the last read is an hour old; otherwise it shows the forecast in memory and the time of the next read.
- After a failure, the wait doubles: 1 h, 2 h, 4 h, then 6 h. A
429answer with a longerRetry-Afteris obeyed (24 h at most). - If
/datacannot be read or written, the module does not read Corrently (it could not keep the hourly spacing) and retries/dataevery 10 seconds.
Not included
- Corrently tariff. The answer has an
energypricefield, but it is a signed value of a few cents (often negative) that is not documented as a retail tariff: it is never published as a price, and the module offers no energy contract template. - A Corrently token. The module reads without one, as Corrently allows at one read per hour. Corrently announces the end of the access without token; the token will come back once Corrently documents how to send it outside the address.
- The CO2 fields of the answer (often empty) and the solar forecast.
Data and licence
Data: Corrently / STROMDAO GmbH, licence
CC BY-NC-SA 4.0. The data is
adapted by this module (index rounded to an integer, levels low / medium / high computed from
it); the levels of the calendar are shared under the same licence. Non-commercial use only: a
commercial use needs a licence from Corrently
(corrently.energy).
Documentation: corrently.io/books/grunstromindex. The
module itself is Apache-2.0.
Estos son los parámetros que Corrently GrünstromIndex te pide en su pantalla de configuración en Gladys.
| Corrently GrünstromIndex | section | No | Unofficial connector, not affiliated with Corrently or STROMDAO. It reads the official GrünstromIndex forecast (0 to 100: how much of the power around a German postcode comes from renewables, hour by hour, about five days ahead) once an hour at most, as the Corrently fair-use policy asks. One device with the index now, next hour, the best of the next 24 hours and the hours until it, plus the Gladys energy calendar green-power-index-de (low, medium, high per half hour). Data: Corrently (STROMDAO GmbH), CC BY-NC-SA 4.0, adapted (index rounded, levels computed by this module); a commercial use needs a licence from Corrently. |
| German postcode | string | Sí | Five digits, leading zero included. Changing it creates a new device. |
Cómo instalar Corrently GrünstromIndex en Gladys
- En Gladys, abre Integraciones: Corrently GrünstromIndex aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
ghcr.io/lm1lc3n7/gladys-corrently:0.1.1), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración). - Abre la pantalla de Configuración de la integración, rellena los parámetros y guarda.
- También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LM1LC3N7/gladys-corrently.
Corrently GrünstromIndex requiere Gladys >=5.3.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Corrently GrünstromIndex es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LM1LC3N7, no el equipo principal de Gladys.
