Integración domótica Bitcoin Monitor, gratuita y de código abierto
Integración Bitcoin Monitor para Gladys Assistant
Monitor Bitcoin fees, mempool, network, market price and transaction costs.
Overview​
Bitcoin Monitor is an external Gladys Assistant integration that monitors public Bitcoin network data through the mempool.space REST API. It requires no account, API key, MQTT broker, Node-RED flow, or manual device definition. Discovery proposes five virtual devices; the user remains in control of which ones are created.
The integration is informational. Fee estimates are not confirmation guarantees, and the storage opportunity score is a transparent convenience heuristic, not financial advice.
Prerequisites and installation​
  • Gladys Assistant 4.86.0 or newer.
  • Internet access to https://mempool.space.
  • No Gladys Plus subscription and no third-party account.
Install Bitcoin Monitor from the decentralized integration catalog. Open its Configuration page, save the desired settings, then open Discovery. Create all five proposed devices, or only the devices you want. The integration never calls an undocumented Gladys API to create them automatically.
  • The API endpoint is fixed to https://mempool.space and is not editable in Gladys. Legacy api_base_url configuration values are ignored.
  • Currency: EUR, USD, GBP, CHF, CAD, AUD, or JPY. These are the currencies currently returned by /api/v1/prices.
  • Fast refresh: fees, projected blocks, mempool, price, and tip height, from 30 to 900 seconds (default 60).
  • Difficulty refresh: 300 to 3600 seconds (default 600).
  • Hashrate refresh: 600 to 21600 seconds (default 1800).
  • Default transaction vSize: 50 to 10000 vB (default 250).
  • Default priority: Fastest, 30 minutes, 1 hour, or Economy.
Changing the currency republishes discovery because a native Gladys currency unit or the visible ISO code can change. Existing devices may show an Update action in Discovery; use it to accept the feature-structure change.
Available actions:
  • Test connection validates the precise-fee and tip-height responses and displays a translated result.
  • Refresh now runs all three collection families immediately.
  • Update transaction simulator saves the vSize and priority locally. The BTC amount is entered directly from a Gladys dashboard.
Devices and metrics​
Bitcoin Fees​
  • Fastest fee, 30 min fee, 1 hour fee, Economy fee, and Minimum fee are precise feerates in sat/vB.
  • Projected block 1/2/3 median fee comes from the projected mempool blocks.
  • Projected block 1 transaction count and virtual size describe the first projected block.
  • Fast/economy spread is fastestFee - economyFee, never below zero.
  • Storage opportunity score ranges from 0 to 5:
    • economy ≤1: 5 (Exceptional)
    • economy ≤2: 4 (Excellent)
    • economy ≤3: 3 (Good)
    • economy ≤5: 2 (Fair)
    • economy ≤10: 1 (Wait)
    • economy >10: 0 (Avoid)
  • If economy is at most 3 sat/vB but projected block 2 is above 5 sat/vB, the score is capped at 1 (Wait) to reflect temporary projected congestion.
  • Storage opportunity advice explains the current score in plain text.
sat/vB is written in the feature name because Gladys has no native unit for it.
Bitcoin Mempool​
  • Unconfirmed transactions: transaction count currently in the mempool.
  • Mempool backlog: total virtual size divided by 1,000,000, in vMB.
  • Total mempool fees: sum of fees in satoshis.
  • Backlog >= 1/2/5/10 sat/vB: histogram vsize at or above each threshold, divided by 1,000,000.
Bitcoin Network​
  • Blockchain height: current chain-tip height.
  • Last block age: minutes since the latest known block timestamp.
  • Last block transaction count, size, and weight: enriched v1 block information. The block-detail endpoint is called only when the tip height changes.
  • Difficulty adjustment estimate and Difficulty progress: percentages returned by mempool.
  • Blocks until adjustment: remaining blocks in the 2016-block period.
  • Average block time: mempool's timeAvg, explicitly parsed as milliseconds and converted to minutes.
  • Estimated retarget date: mempool's millisecond Unix timestamp rendered as ISO 8601 text.
  • Network hashrate: currentHashrate / 10^18, displayed as EH/s in the name.
  • Network difficulty: currentDifficulty / 10^12, displayed as T in the name.
Bitcoin Market​
  • Bitcoin price is the current public price in the configured currency.
  • Gladys native units are used for EUR, USD, and GBP. CHF, CAD, AUD, and JPY are not mislabelled as dollars; their ISO code appears in the feature name instead.
Bitcoin Transaction Simulator​
Local inputs:
  • Transfer amount in BTC.
  • Transaction vSize in virtual bytes.
  • Priority: Fastest, 30 minutes, 1 hour, or Economy.
Outputs:
  • Transfer value in the configured fiat currency.
  • Selected fee rate, satoshis, BTC, fiat value, and percentage of transfer.
  • Fiat fee for all four priorities.
  • A plain-text simulation summary.
The fee is calculated as:
fee_sats = ceil(vsize × feerate)
fee_btc = fee_sats / 100,000,000
fee_fiat = fee_btc × BTC_fiat_price
fee_percent = fee_btc / transfer_amount_btc × 100 (only when amount > 0)
The amount transferred does not determine the network fee. A transaction carrying 0.01 BTC can cost the same fee as one carrying 1 BTC when their virtual size and feerate are identical. vSize depends mostly on the number and type of inputs and outputs, not the BTC value.
Gladys does not provide a generic writable numeric widget for a sensor/decimal feature. Bitcoin Monitor therefore maps Transfer amount (BTC) to Gladys' supported numeric setpoint contract, with a 0.00000001 BTC step. The amount and priority can be changed directly from a dashboard; vSize remains in the validated action form. The three values are atomically persisted in /data/simulator-state.json.
Values are rounded before publication: BTC prices and transfer values to 2 decimals, fiat fees and percentages to 4, feerates to 3, BTC amounts to 8, and satoshis/vSize to integers. Gladys may omit an insignificant trailing zero, but JavaScript floating-point tails are never exposed.
Polling, rate limits, and failures​
Each collection family uses setTimeout only after the previous run completes, so requests cannot accumulate. A small jitter avoids synchronized bursts. The HTTP client uses a timeout and retries only network failures, HTTP 429, and HTTP 5xx responses. Retry delays use exponential backoff plus jitter, honor Retry-After, and are capped at 30 seconds.
The public mempool.space service does not promise a fixed public quota. Keep the default intervals to limit requests. Bitcoin Monitor never downloads all mempool transaction IDs, all transactions, or large block histories.
On temporary failure, the last valid in-memory values remain intact; zero or null is not published as replacement data. After three fast cycles with no successful important request, Gladys shows the mempool connection as unavailable. Collection resumes automatically after recovery.
  • No devices: open the integration's Discovery tab and run discovery; creation is a user action.
  • No values on one device: confirm that the device and its current feature structure were created. Use Update in Discovery after changing currency or upgrading.
  • Connection test fails: verify DNS/firewall access to https://mempool.space.
  • HTTP 429 in logs: increase the fast refresh interval.
  • Some metrics stay old: the endpoint may be temporarily unavailable or malformed. Bitcoin Monitor deliberately keeps the last valid value.
  • Transfer amount is not editable after upgrading: update the Bitcoin Transaction Simulator device from Discovery so Gladys receives the new writable feature definition. Use Configuration → Update transaction simulator only for vSize.
  • Persistence warning: verify that Gladys mounted the integration's writable /data directory and that it is owned by UID/GID 1000.
Privacy​
There is no telemetry, analytics, tracker, or user account. Only public-data GET requests are sent to https://mempool.space. The local BTC amount, vSize, and priority are never included in those requests and never leave the integration's /data volume. No secret is required or logged.
Estos son los parámetros que Bitcoin Monitor te pide en su pantalla de configuración en Gladys.
GeneralsectionNoBitcoin Monitor uses the public mempool.space API at a fixed endpoint. No account or API key is required.
CurrencyselectSí
PollingsectionNoConservative non-overlapping polling protects the public API. Temporary failures keep the last valid values.
Fast refresh interval (seconds)numberSí
Difficulty refresh interval (seconds)numberSí
Hashrate refresh interval (seconds)numberSí
Transaction simulator defaultssectionNoTransaction fees depend on virtual size and feerate, not on the transferred BTC amount. Enter the BTC amount on a Gladys dashboard; use the action below for vSize and priority.
Default transaction vSize (vB)numberSí
Default priorityselectSí
Cómo instalar Bitcoin Monitor en Gladys​
  1. En Gladys, abre Integraciones: Bitcoin Monitor aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/checconio/gladys-bitcoin-monitor:1.0.4), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/Checconio/gladys-bitcoin-monitor.
Bitcoin Monitor requiere Gladys >=4.86.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Bitcoin Monitor es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene Checconio, no el equipo principal de Gladys.
