Integración domótica Atlantic Cozytouch, gratuita y de código abierto
Integración Atlantic Cozytouch para Gladys Assistant
Control Atlantic Cozytouch air conditioners and heat pumps (Takao M3) in Gladys Assistant.
Controllable modes​
Besides mode, target (heat and cool) and swing: eco, boost, silence, presence/away and weekly program — the same capabilities as the Home Assistant integration. This integration brings Atlantic air conditioners and heat pumps controlled by Cozytouch (Takao M3 and other connected Atlantic equipment) into Gladys Assistant.
What it does​
One device per controllable room of the Cozytouch account, with: on/off switch, mode select (off, heating, cooling, auto, fan), writable target temperature (heating or cooling capacity follows the current mode), room temperature sensor with history, state text, and a fan speed select (Auto/Low/Medium/High) when the equipment exposes it.
Prerequisites​
  • A Cozytouch account that works in the Atlantic app on your phone.
  • Gladys Assistant 5.1 or later.
Setup​
  1. Install the integration from Integrations in Gladys.
  2. In the Configuration tab, enter the Cozytouch e-mail and password, then click Test the connection: the number of controllable rooms is shown.
  3. Open the Discovery tab and create the rooms you want.
If a room is missing from discovery, find its numeric id (magellan deviceId in the app's developer tools) and enter it in the “Room id” field.
The integration talks to the Atlantic Magellan cloud over the Internet, like the official app; your credentials stay in the Gladys configuration (secret field).
  • “0 controllable room(s) found”: check the credentials; for accounts with several installations, use the “Room id” field.
  • The heating and cooling setpoints are a single feature in Gladys: the integration writes the capability matching the current mode.
Unofficial community integration, not affiliated with Groupe Atlantic.
Estos son los parámetros que Atlantic Cozytouch te pide en su pantalla de configuración en Gladys.
Getting startedsectionNoUse the e-mail and password of your Cozytouch account (the same as the Atlantic Cozytouch app). The integration talks to the Atlantic Magellan cloud, exactly like the official app. Unofficial integration, no affiliation with Atlantic.
Cozytouch e-mailstringSí
Cozytouch passwordsecretSí
Room id (optional)numberNoLeave empty for automatic discovery. If a room is missing, find its numeric id in the Cozytouch app (magellan deviceId) and enter it here.
Labels languageselectNo
Refresh interval (s)numberNoHow often the rooms are read, in seconds (one minute minimum, to stay courteous with the Atlantic cloud).
Cómo instalar Atlantic Cozytouch en Gladys​
  1. En Gladys, abre Integraciones: Atlantic Cozytouch aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/tchoinard38/gladys-atlantic-cozytouch:1.2.0), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/tchoinard38/gladys-atlantic-cozytouch.
Atlantic Cozytouch requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Atlantic Cozytouch es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene tchoinard38, no el equipo principal de Gladys.
