Integración domótica APsystems EZ1 & ECU, gratuita y de código abierto
Integración APsystems EZ1 & ECU para Gladys Assistant
Unofficial connector: APsystems EZ1 micro-inverters and ECU gateways, live solar production.
Unofficial connector, not affiliated with APsystems. It reads your APsystems EZ1 micro-inverters (balcony solar: EZ1-M, and the other EZ1 models that offer the local API) on your local network, through the local API the inverter opens itself, and the micro-inverters behind an ECU gateway (ECU-B, ECU-R, ECU-C: DS3, DS3-L, QS1, YC600, YC1000, QT2…) through the ECU's local port 8899 (see ECU gateways): no cloud, no account, nothing leaves your home. APsystems is a trademark of Altenergy Power System Inc.
SurfaceContent
One device per inverterproduction power (W, total and per panel), energy today (kWh), lifetime energy (kWh, a production meter index for the Gladys energy monitoring, with its 30-minute production), power limit (W, settable), on/off, reachable, alarms
Scene triggerssolar production started (the morning), solar production stopped (the evening), solar inverter alarm (off grid, output fault, DC short circuit on a panel)
Scene actionsset the solar power limit of an inverter, read the solar production (power, energy of the day and lifetime, of one inverter or all of them)
Dashboard widgetSolar production: power now, energy of the day and lifetime, per panel, the limit and the state of one inverter, or the totals of all of them
One device per ECUproduction power (W), energy today (kWh), lifetime energy (kWh, production index), inverters online, reachable; read-only
One device per micro-inverter behind an ECUonline, production power (W, total and per panel), AC voltage (V, per phase on a three-phase model), grid frequency (Hz), temperature (°C); read-only
Setup​
  1. Enable the local API on each inverter, once: in the AP EasyPower app, connect to the inverter (Bluetooth, "Direct connection"), open Settings → Local mode, enable it and choose Continuous. The app shows the inverter's IP address.
  2. In your router, give each inverter a fixed address (DHCP reservation): the integration finds the inverters by address.
  3. In Gladys, type the addresses in Inverter addresses, separated by commas: 192.168.1.50, 192.168.1.51. The port is 8050; add :port only if yours differs.
  4. Save, then click Test the inverters: each address answers with its model, serial number, firmware and current power. Do it by day: an EZ1 sleeps at night.
  5. Open Discovery and add the inverters. Put the Solar production widget on a dashboard: pick an inverter, or leave it empty for the totals of all of them.
Each inverter is read every 30 seconds (option Refresh interval, 10 s minimum: the EZ1 answers slowly); its alarms and on/off every 5 minutes, its information and power limit every hour.
The night​
An EZ1 is powered by its panels: without sun it switches off, Wi-Fi included. That is normal and not an error: after three readings without an answer, the inverter is shown sleeping (night), its power reads 0 W, its energy counters keep their value, and it is only tried every 5 minutes until it wakes up. The connection status stays green.
The status turns red only when an inverter disappears while producing (at least 50 W at its last answer), or stays silent for a whole day: then check its Wi-Fi, its address, and that local mode is still on.
Energy today is the inverter's own counter since it woke up this morning; it keeps the evening's value through the night and restarts at sunrise. A restart of the inverter during the day (a very dark cloud) is added up, not lost.
Energy monitoring​
The lifetime energy feature is a production index: Gladys turns it into a 30-minute production (the "Lifetime energy (30-minute production)" feature, which Gladys fills itself) for its energy screens. Gladys counts every rise of an index in full, so the integration guards it (EZ1 and ECU alike):
  • a 0 (or a value missing) is never published;
  • a rise is published when the inverters could have produced it: at most 1.5 times the maximum power of an EZ1 (2 kW per inverter behind an ECU) since the last value published, over two intervals at least, plus a small margin;
  • a fall, or a larger jump, is held back: never accepted by repetition nor by time. The connection status (it stays green) and the Test the inverters button show it, with both values. If it is real (a counter reset, an inverter replaced), press Accept the lifetime energy (it accepts every value held back at once): the next reading close to the value shown (within what the inverters could have produced since) is taken; any other reading is held again. A jump taken is counted once as production; a fall counts nothing. The acceptance is not kept across a restart of the integration: press again after one. A value back to normal (it was a glitch) ends the hold by itself;
  • the last value published and what is held are kept in /data/state.json, so a restart changes nothing.
Power limit and on/off​
  • Power limit: caps the output, within the bounds the inverter reports (30 to 800 W on an EZ1-M). The integration never writes it on its own, and does not rewrite a value the inverter already has. Whether the inverter keeps it in its memory is not documented by APsystems: a scene that changes it every few seconds is not a good idea, once every few minutes is plenty.
  • On/off: stops or restarts the production; the local API keeps answering while the inverter is off. Some firmware (the ones ending in _b, for battery systems) have no on/off: the feature is then not offered.
ECU gateways (ECU-B, ECU-R, ECU-C)​
Never tested with a real ECU. This part was built from the Home Assistant integration of HAEdwin (APsystems ECU Reader 2.15.0) and its source by ksheumaker, both Apache-2.0 (see THIRD_PARTY_NOTICES.md), without an ECU at hand. If you have one, your feedback on the forum is very welcome.
Micro-inverters such as the DS3, DS3-L, QS1, YC600 or YC1000 talk to an ECU gateway over Zigbee; the ECU uploads to the EMA cloud and answers on your local network, on TCP port 8899. The integration asks it there: nothing goes through EMA.
  1. Put the ECU on your local network, with local access. The ECU-B and the ECU-R of the 2160 series connect over Wi-Fi only; the ECU-R "Pro" (2162 series, its ECU id starts with 2162) and the ECU-C connect over Wi-Fi or Ethernet (cable). For Wi-Fi: install EMA Manager, press and hold the ECU button until its own Wi-Fi starts, join that Wi-Fi (default password 88888888), launch EMA Manager and choose the Local connection, then connect the ECU to your home Wi-Fi (the same network as Gladys). Port 8899 then answers on your network.
  2. In your router, give the ECU a fixed address (DHCP reservation).
  3. In Gladys, type it in ECU gateway addresses (192.168.1.60; port 8899, add :port only if yours differs). Several ECUs: separate them with commas.
  4. Save, click Test the inverters, then open Discovery: one device for the ECU and one per micro-inverter it knows (their external id is the inverter's own id, so they stay the same if the ECU is replaced).
The pace. An ECU is known to hang when asked too often. It is read every ECU refresh interval (300 s by default, and never less, the pace the Home Assistant integration recommends), one connection at a time for all your ECUs, with a 5-second pause between two queries; a reading is two queries (the ECU, then its inverters). After a failure, the next attempt waits 5 minutes, then 10, then 20, up to 30 minutes: never sooner than the interval, even when the link to Gladys drops and comes back or the integration restarts (the pace is kept in /data/state.json). The test button never asks an ECU before its next reading is due: it reports the last one. After three failed readings in a row the status turns red: an ECU that hangs usually comes back after unplugging it for a minute.
The night. The ECU is powered by the grid and keeps answering; its micro-inverters go offline with the sun. That is the sleeping (night) state, never an error: the ECU's power reads 0 W, each micro-inverter is offline with 0 W, the rest keeps its last value. A micro-inverter the ECU no longer lists, or has not reported for two intervals, is shown offline at 0 W too.
The figures are the ECU's own: its current power, its energy of the day, its lifetime energy, the number of inverters online; per micro-inverter, what the ECU gives (online, the power of each panel, the AC voltage, the grid frequency, the temperature while online). An inverter of a type the reference does not know only gets online, and the inverters listed after it are not read (a guess would invent inverters). The ECU's lifetime energy is the production index of the Gladys energy monitoring, guarded as described in Energy monitoring (some ECU firmware answer 0 now and then; 80 inverters are assumed when the ECU does not say how many it has). The micro-inverters have no energy counter: the ECU counts the energy, once. Micro-inverters created without their ECU are counted on their own in the widget and the "read the solar production" action.
Read-only. No on/off nor power limit through the ECU in this version; the "set the solar power limit" action is for EZ1s only. The scene triggers "solar production started/stopped" also fire for an ECU (its total power), and the widget and the "read the solar production" action count it.
Scenes​
  • Solar production started: an inverter produced 10 W or more for a minute. Variables: the power and the energy of the day so far.
  • Solar production stopped: under 5 W for 15 minutes, or asleep. Variable: {{triggerEvent.data.energy_today}}, the energy of the day (a good moment for a "today's production" message).
  • Solar inverter alarm: an alarm went up: off grid (check the AC connection), output fault (the AC connection too), DC short circuit (check the panel connector of that input, {{triggerEvent.data.input}}). The first reading after start-up or after the night does not fire: the inverter checks the grid each morning.
In each trigger, pick an inverter or leave it empty for any of them. The variables always hold the inverter's name, {{triggerEvent.data.name}}, and its serial number, {{triggerEvent.data.serial}}.
  • The action set the solar power limit takes an inverter and a value in W, and gives limit, the limit applied.
  • The action read the solar production takes an inverter, or none for all of them, and gives power (W), energy_today and energy_total (kWh), producing, sleeping and inverters (how many were counted), for a message or a condition. It uses the last readings; only an inverter not read yet since the start is read first.
The following actions of the scene find these outputs in their variable list (written {{<step>.<action>.<key>}}, for instance {{0.0.power}} when the read action is the first of the scene).
  • No answer by day: check the address (a fixed one), that local mode is on and set to "Continuous", and that Gladys can reach the inverter's network (the integration runs in a container on the Gladys host).
  • "…does not answer: it sleeps without sun" on a command: the inverter is asleep; try again once it produces.
  • No on/off feature: the firmware has none (see above).
  • The lifetime energy does not move any more: a fall or a jump is held back (the status says so, with both values): press Accept the lifetime energy if it is real.
  • ECU not answering: check its address, that it is on your network (nc -v <ECU address> 8899 from a computer, then type APS1100160001END: it answers a line starting with APS11), and unplug it for a minute if it hangs.
  • Logs: the integration's log level is set with the LOG_LEVEL variable.
Privacy​
Everything stays on your local network: the integration only talks to the addresses you typed, over HTTP on port 8050 (EZ1) and TCP on port 8899 (ECU).
Estos son los parámetros que APsystems EZ1 & ECU te pide en su pantalla de configuración en Gladys.
Your APsystems micro-inverters in GladyssectionNoUnofficial connector, not affiliated with APsystems. It reads your EZ1 micro-inverters (balcony solar) on your local network, through the local API each inverter opens once "Local mode" is enabled in the AP EasyPower app (choose "Continuous"): no cloud, no account. One device per inverter: production power (total and per panel), energy of the day, lifetime energy for the Gladys energy monitoring, power limit, on/off and alarms. Scene triggers when production starts or stops and on an alarm, scene actions to set the power limit and read the production, a dashboard widget. At night an EZ1 sleeps (no sun, no Wi-Fi): that is normal, not an error. Micro-inverters behind an ECU gateway (ECU-B, ECU-R, ECU-C: DS3, QS1, YC600, YC1000...) are read through the ECU's local port 8899, read-only: one device per ECU (power, energy of the day, lifetime energy, inverters online) and one per micro-inverter (online, power per panel, voltage, frequency, temperature). Never tested with a real ECU.
Inverter addressesstringNoThe IP address of each EZ1, separated by commas (port 8050 by default, add :port otherwise). Give each inverter a fixed address in your router (DHCP reservation). Then open Discovery.
Refresh interval (s)numberNoHow often the production is read. The EZ1 is slow to answer: 30 s is a good pace, 10 s the minimum. At night a sleeping inverter is tried every 5 minutes only.
ECU gateway addressesstringNoFor micro-inverters behind an APsystems ECU gateway (ECU-B, ECU-R, ECU-C): the IP address of each ECU, separated by commas (port 8899 by default). Give it a fixed address in your router. Leave empty if you only have EZ1s.
ECU refresh interval (s)numberNoHow often each ECU is read. An ECU hangs when it is asked too often: 300 s (5 minutes) is the minimum, the pace recommended by the Home Assistant integration. After a failure the next attempt waits longer.
Cómo instalar APsystems EZ1 & ECU en Gladys​
  1. En Gladys, abre Integraciones: APsystems EZ1 & ECU aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/lm1lc3n7/gladys-apsystems:0.1.5), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LM1LC3N7/gladys-apsystems.
APsystems EZ1 & ECU requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
APsystems EZ1 & ECU es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LM1LC3N7, no el equipo principal de Gladys.
