Integración domótica Apple WeatherKit, gratuita y de código abierto
Integración Apple WeatherKit para Gladys Assistant
Unofficial connector: Apple WeatherKit weather, forecasts and alerts, with your Apple key.
Unofficial connector, not affiliated with Apple. It makes Apple WeatherKit the weather provider of Gladys: current conditions, 24-hour and 8-day forecasts, and the official alerts of the country you set. The weather widget, the assistant and the weather-alert scene triggers of Gladys use it directly.
This integration was never tested with a real Apple Developer account: it is written from the documentation of the WeatherKit REST API. Feedback is welcome.
What you need​
  • An Apple Developer Program membership of your own (paid: 99 USD a year). It includes 500,000 WeatherKit calls a month for the whole team; above that, Apple sells paid tiers in your developer account.
  • Gladys 5.1 or later, and at least one located house (Settings → Houses) for the test button.
Getting the credentials​
On developer.apple.com/account:
  1. Team ID: Membership details, 10 characters.
  2. Service ID: Certificates, Identifiers & Profiles → Identifiers → + → Services IDs, for example com.example.weather.
  3. Key: Keys → + → tick WeatherKit → register, then download AuthKey_XXXXXXXXXX.p8 (Apple gives it once). The 10 characters after AuthKey_ are the Key ID.
See also WeatherKit: get started.
FieldPurpose
Team ID, Key ID, Service IDThe identifiers above.
Private key (.p8)The whole .p8 file, -----BEGIN/END PRIVATE KEY----- lines included (pasted on one line works too). Kept by Gladys in its database, never shown again, used only to sign the requests sent to Apple WeatherKit. It never appears in the logs, the status or /data.
Country for the alertsTwo-letter code (FR, BE, US...). WeatherKit gives alerts only with it. Empty: no alerts.
Weather alertsOn by default (when a country is set).
Refresh interval15 minutes by default (10 to 120). A location is read from Apple at most once per interval.
Monthly budget50,000 calls by default (1,000 to 500,000), per calendar month in UTC.
Test WeatherKit makes one call (the data sets at your first located house, or at Cupertino when no house has a location): it says whether Apple accepts the credentials, whether alerts exist for your country, and the calls of the month. It runs at most once every 30 seconds, and not during a pause asked by Apple nor once the budget is reached.
Costs, quotas and pacing​
  • Gladys asks for the weather when a dashboard shows it, when the assistant answers, and every 30 minutes for the alerts. The integration answers from its kept copy while it is younger than the interval: with 15 minutes, count about 3,000 calls a month per location.
  • Each call is counted in /data before it leaves. Once the budget is reached, nothing is sent until the 1st of the next month (UTC). Apple counts the calls of your other apps in the same quota.
  • HTTP 429: paused as long as Retry-After says (compared with Apple's Date header), between 60 s and 6 hours; without the header, 60 s then doubled.
  • Server error, unreadable, oversized (over 1 MB) or missing answer: 60 s pause, doubled at each failure up to 1 hour.
  • Other 4xx (400, 404...): the location or the country is not served; only that location is held back for one refresh interval, the others go on.
  • Gladys waits 15 s for an answer: a call (or its retry after a 401) that cannot end in time does not leave.
  • During a pause or an outage, Gladys gets the last copy if it is under one hour old, with its own date (never presented as new); otherwise an error, and Gladys moves on to its next provider.
  • Pauses, the counter and the copies are kept in /data: a restart does not trigger a call.
Refused credentials​
A single 401 or 403 stops nothing: the request is made once more with a new token. Refused twice in a row, the credentials are recorded as refused and no request leaves with them any more. /data keeps only one byte of a salted hash of the identifiers and of the public key: nothing secret, and nothing a reader could check a guess against (one guess in 256 matches). Saving different credentials while the integration runs lifts the refusal at once. After a restart only that byte is known: new credentials whose byte happens to be the same (1 chance in 256) stay held back until a success of Test WeatherKit, which always makes its call.
What is sent to Apple​
The coordinates of the house rounded to 3 decimals (about 100 m), the user's language (its base: pt-BR → pt), the alert country, and a token signed for one hour. /data/state.json holds the month counter, the pause, one byte marking refused credentials, and the last answers. The answers carry no coordinates, but each is filed under a salted hash of the rounded location: with the salt beside it, the location can be found back by brute force, and the alerts name their area. /data stays on your Gladys.
Mappings​
WeatherKitGladys
Clear, MostlyClear, Hot, Frigidclear
PartlyCloudy / MostlyCloudy, Cloudypartly-cloudy / cloud
Fog, Haze, Smokefog
Drizzle / Rain, Showers... / HeavyRaindrizzle / rain / pouring
FreezingDrizzle, FreezingRainfreezing-rain
Sleet, WintryMix, MixedRainAndSnow...sleet
Snow, Flurries, Blizzard...snow
Hailhail
Thunderstorms, StrongStorms...thunderstorm
Breezy, Windy / Dust, BlowingDustwind / sandstorm
TropicalStorm, Hurricane / Tornadohurricane / tornado
any other codeunknown
Units: WeatherKit answers in metric; the integration converts to m/s and km (metric) or °F, mph, inches and miles (US); pressure stays in hPa; humidity, cloud cover and precipitation chance in percent. A missing value stays missing, never 0.
Alerts: Apple's CAP severity is kept; "unknown" becomes "minor" (the alert is kept). The phenomenon (storm, wind, snow...) is read from the title in English, French, German or Spanish; without a match the alert is shown with its title alone. The description gives the area and the source; the long text is not fetched (one more call per alert). Alerts expired by Apple's clock are removed.
Attribution​
Apple asks to show the Apple Weather mark and a link to its data sources: https://weatherkit.apple.com/legal-attribution.html. The Gladys weather widget cannot show it yet: the link is on the configuration screen and here.
Statuses​
  • "Enter the Team ID...": nothing configured.
  • "Invalid configuration: ...": names the wrong fields (never their value); nothing is sent.
  • "Ready", then "WeatherKit answers".
  • "Apple refused these credentials...", "WeatherKit asked to slow down...", "did not answer properly...", "Monthly budget reached...".
  • "/data/state.json is unreadable": read again every 10 s, nothing is sent meanwhile (an unreadable file is not taken as empty).
  • "The configuration could not be read": new try after 5 s, then doubled up to 5 minutes.
Limits​
No minute-by-minute forecast, no radar image, no air quality. Apache-2.0 license.
Estos son los parámetros que Apple WeatherKit te pide en su pantalla de configuración en Gladys.
Apple WeatherKit in GladyssectionNoUnofficial connector, not affiliated with Apple. It makes Apple WeatherKit the weather provider of Gladys: current conditions, 24 hours, 8 days, and the official alerts of the country you set. It needs your own Apple Developer Program membership (paid, 99 USD a year, which includes 500,000 WeatherKit calls a month for the whole team): a WeatherKit key (.p8), its Key ID, your Team ID and a Service ID. Each location is read at most once per refresh interval, and a monthly budget stops the calls before your quota. Data: Apple Weather (see the attribution link).
Team IDstringSíThe 10 characters of your Apple Developer team (Membership details).
Key IDstringSíThe 10 characters of the WeatherKit key (Certificates, Identifiers & Profiles → Keys).
Service IDstringSíThe identifier of a Services ID registered with WeatherKit, in reverse-domain form.
Private key (.p8)secretSíThe whole content of the AuthKey_XXXXXXXXXX.p8 file, header lines included. Kept by Gladys in its database, never shown again, used only to sign the requests sent to Apple WeatherKit.
Country for the alertsstringNoTwo-letter country code of your houses (FR, BE, US...). WeatherKit gives alerts only with it. Empty: no alerts.
Weather alertsbooleanNoAsks WeatherKit for the official alerts of the country set above, shown by the weather widget and used by the weather-alert scene triggers of Gladys.
Refresh interval (minutes)numberNoA location is read from Apple at most once per interval; Gladys gets the kept copy in between. 15 minutes is about 3,000 calls a month per location.
Monthly budget (calls)numberNoCalls allowed per calendar month (UTC), counted by this integration only. Reached: no call until the next month. Apple counts the calls of all your apps in the same quota.
Cómo instalar Apple WeatherKit en Gladys​
  1. En Gladys, abre Integraciones: Apple WeatherKit aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/lm1lc3n7/gladys-apple-weatherkit:0.1.1), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LM1LC3N7/gladys-apple-weatherkit.
Apple WeatherKit requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Apple WeatherKit es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LM1LC3N7, no el equipo principal de Gladys.
