Integración domótica Apple TV, gratuita y de código abierto
Integración Apple TV para Gladys Assistant
Control your Apple TV: power, remote, playback, volume and applications.
Control your Apple TV from Gladys Assistant: power, remote, playback, volume and applications. The integration talks to your Apple TV directly on your local network, using pyatv — the reference implementation of Apple's AirPlay and Companion protocols, and the same library Home Assistant uses. Nothing goes through Apple's servers, and no Apple ID is required.
Dashboard widgets​
In the dashboard editor, add a widget from the Apple TV integration and choose your device:
  • Apple TV — Playback: current title and application, playback state, play/pause, skip backward, skip forward and standby, depending on device capabilities. In standby, Turn on replaces the playback controls.
  • Apple TV — Volume: view the current level and open a form to set it from 0 to 100%, when your setup supports it. The known level is prefilled. No volume command is offered in standby.
  • Apple TV — Favorites: enter up to four installed application names in the widget settings, such as Netflix or Plex. Names are case-insensitive; leave unused fields empty. Without favorites, the widget shows available names. Enable application shortcuts in the integration settings. A button opens the application; it does not automatically start a movie.
Cards refresh every ten seconds and after a command. Opening the dashboard does not wake the Apple TV. Metadata depends on the active application; artwork is not displayed. Add multiple widget instances for multiple Apple TVs.
Requirements​
  • An Apple TV (HD, 4K, any generation running tvOS 15 or later).
  • Gladys 5.2.0 or later.
  • The Apple TV and your Gladys server on the same network. Routed VLANs or subnets work too, provided an mDNS relay forwards the announcements: see troubleshooting.
  • Physical access to the television during pairing: Apple displays a code on the screen that you have to read and type into Gladys.
Setting it up​
Three steps, in this order. An Apple TV has to be added and then paired before a single command works — adding it alone gets you a device that obeys nothing.
1. Find your Apple TV​
Open the Discovery tab of the integration and press Scan. Gladys listens for the AirPlay announcements on your network, and the integration checks every candidate address directly with pyatv. Your Apple TV appears with its name and its model.
Press Add to Gladys to create the device. An Apple TV is usually named after the room it sits in ("Living room"), so the device is created as "Apple TV Living room" — clear in a device list, and it is also what makes its selector readable in scenes. You can rename it afterwards in the Devices tab.
2. Pair it​
Pairing is what authorizes Gladys to control the device. It happens in the Configuration tab, with the first two buttons:
  1. 1. Pair an Apple TV — pick your Apple TV in the dropdown and press Run. The list holds the Apple TVs you added at step 1, so there is no IP address to look up. A code appears on your television.
  2. 2. Enter the code — type the code you see on screen, then press Run.
Apple asks for one code per protocol: after the first code is accepted, a second one appears on the television. Two codes is normal.
The second code goes in the same field as the first one. The form keeps what you typed, so you have to clear the field and type the new code in its place, then press the button again. Pressing it a second time without clearing does nothing useful — the integration recognizes the old code and says so rather than wasting the new one.
Codes expire fast, and the connection carrying them closes on its own after a short while. If that happens, the integration says so and immediately puts a new code on your television: read the message, clear the field, enter the new code, and carry on. There is no need to start over from step 1.
Once pairing is complete, run a scan again (or accept the Update that Gladys offers in the Discovery tab): the integration now knows what your Apple TV can actually do, and adds the volume control and the application shortcuts.
3. Use it​
The device exposes:
  • Power — on/off. "Off" means standby, in Apple's sense: the box stays on the network, the screen and the HDMI output go away.
  • Remote — directional pad, OK, Back, Home, Control Center.
  • Playback — play, pause, stop, previous, next, rewind, fast forward.
  • Volume — a slider, plus volume up/down buttons. The slider only appears when your setup exposes a readable volume level. An Apple TV controlling a soundbar over HDMI-CEC usually only supports the up/down buttons.
  • Now playing and Application — text sensors showing what is on screen.
  • Application shortcuts — one button per installed application, so a scene can open Netflix or Disney+ directly. Disable them, or lower the maximum, in the configuration.
On a dashboard​
Two boxes, two ways to use the same Apple TV:
  • Devices in a room — every remote key is a real button you can press: the directional pad, OK, Back, Home, Control Center, play, pause, the transport keys, the volume slider and the application shortcuts. This is the remote.
  • Music box — the transport bar of a media player. Add the Apple TV to it and drive it like a Sonos.
The device list shows both sets, which is why some keys appear twice: the ones prefixed with "Media" are what the Music box uses, the short ones are the remote buttons. Each box only offers the features it can actually use, so you never have to choose between them.
SettingWhat it does
Discovery durationHow long Gladys listens for AirPlay announcements. Increase it on a busy or slow network.
Manual IPv4 addressesAdds known targets when announcements do not reach Gladys; it never restricts the scan to them. Does not by itself enable discovery across routed VLANs.
Refresh intervalHow often the integration reconciles what the Apple TV does not push by itself, typically the power state on some models.
Application shortcutsWhether to expose one button per installed application.
Maximum number of shortcutsAn Apple TV can have a hundred applications; this bound keeps the device readable.
Other actions​
Each one acts on an Apple TV you pick in a dropdown — the same list as the pairing buttons, filled with the devices you added from the Discovery tab.
  • Reconnect and refresh — reopen the session and read the device again. The first thing to try when something looks stale.
  • List the installed applications — shows the bundle identifier of every application, which is what "Launch an application" expects.
  • Launch an application — opens an application by bundle identifier, e.g. com.netflix.Netflix.
  • Play a URL — sends a video URL or a deep link to the Apple TV over AirPlay.
  • Delete the pairing — forgets the stored credentials. Use it when pairing has to be redone, for example after a factory reset of the Apple TV.
The scan finds nothing. Gladys captures AirPlay announcements from the host network. Check that your Apple TV is powered on, that AirPlay is enabled (Settings → AirPlay and HomeKit), and that Gladys is on the same network. If your Gladys server is on the same LAN but automatic capture fails, try the manual IPv4 address. An address alone cannot make pyatv discovery work across routed VLANs; see below.
The integration log lists every announcement (name, host, IPv4 address and port), the origin of every candidate address, every pyatv answer and every candidate that did not answer. If the Apple TV disappears from that list when you unplug it but pyatv never answers, the mediated AirPlay capture works and the direct verification is what the network blocks.
Gladys and the Apple TV are on routed subnets or separate VLANs. This is handled from version 1.2.0, provided your network relays the Bonjour announcements between the two subnets (an mDNS repeater or reflector on the router, which most prosumer firmwares offer). The Apple TV still ignores the direct query the integration sends, because its source is outside the local subnet — but Gladys now captures the AirPlay and Companion announcements from the host network, and the integration rebuilds the device from them instead of insisting on an answer.
Two things to check when it still does not work. The relay must forward _airplay._tcp and _companion-link._tcp: AirPlay alone is not enough to pair or to drive the remote. And it must forward the address (A) records along with the service ones — the log says explicitly when an announcement arrived without an address, which is the usual sign of a partial relay.
A device recovered this way is logged as rebuilt from the announcements. That means it was never actually reached during the scan: discovery and pairing work, but the commands themselves still have to reach the Apple TV.
You run Gladys in Docker on a Mac or on Windows. Discovery cannot work there, and it is not a misconfiguration on your side. Docker Desktop, OrbStack and Colima run containers inside a Linux virtual machine, so network_mode: host means the virtual machine's network, not your Wi-Fi. Multicast from your Apple TV never reaches Gladys. Unicast does, so everything else works: put the IP address of your Apple TV in "Manual IPv4 addresses" and the integration discovers, pairs and controls it normally. A Gladys running on Linux (Raspberry Pi, NAS, server) is on the network for real and does not need this.
Every command fails with "not paired yet". The device was added but never paired. Run the two pairing buttons in the Configuration tab.
The pairing dropdown is empty. It only lists Apple TVs already added to Gladys, so step 1 has not happened yet: go to the Discovery tab, press Scan, then Add to Gladys.
Pairing fails or the code is refused. The code expires quickly — start again and enter it right away. If it keeps failing, remove Gladys from the Apple TV (Settings → General → AirPlay and HomeKit → Allow Access), run "Delete the pairing" in Gladys, then pair again.
The device shows as unreachable. Check that the Apple TV is powered on and still has the same IP address. A scan refreshes the address the integration uses; a static lease on your router avoids the problem entirely.
There is no volume slider. Your setup does not expose a readable volume level — a common case with HDMI-CEC. Use the volume up and volume down buttons instead.
The scan lists devices that are not Apple TVs. The filter accepts Apple TV HD and 4K models, as well as hardware identifiers for newer models not yet known to pyatv. Generations 1, 2 and 3 are excluded, including third-party receivers identified as an Apple TV 3, such as the reported Freebox Player. The advertised model is not proof of the actual hardware: another receiver could announce an accepted model. For false positives, include the pyatv response n/n log line in the bug report: it lists the resolved model, the available raw model and the detected protocols.
"Manual IPv4 addresses" does not restrict the scan. The addresses are added to the ones Gladys captured, they never replace them. The field exists to reach a device whose announcements do not arrive, not to pick which Apple TV to keep; the Candidate address log lines name every source of every address.
Privacy and storage​
The pairing credentials are stored in the integration's own writable volume (/data/pyatv.json), never in the Gladys configuration, and never leave your network. Deleting the integration deletes them with it.
Estos son los parámetros que Apple TV te pide en su pantalla de configuración en Gladys.
Setting up your Apple TV, step by stepsectionNoAn Apple TV has to be added AND paired before a single command works. Three steps, in this order. 1) Discovery tab: press "Scan", wait, then press "Add to Gladys" on your Apple TV. It now exists in Gladys, but obeys nothing yet. 2) Back on this page, at the bottom: run "1. Pair an Apple TV" and pick it from the list — no IP address to look up. A code appears on your television; type it in "2. Enter the code". Apple asks for one code per protocol, so a second code follows: clear the field and type the new one in its place. 3) Discovery tab again: press "Update" on your Apple TV to pick up the volume control and the application shortcuts that the pairing revealed.
Finding your Apple TVsectionNoThese two settings only affect the scan of the Discovery tab. The defaults work on a normal home network: leave them alone unless a scan comes back empty.
Discovery duration (seconds)numberNoHow long Gladys listens for the Apple TV mDNS announcements. Increase it on a busy or slow network.
Manual IPv4 addressesstringNoOptional, comma separated. Added to the addresses Gladys announces, never in place of them: this field cannot be used to restrict the scan to one Apple TV. Useful when automatic announcements do not reach Gladys but direct traffic still exits on the Apple TV's local subnet, as with some desktop Docker setups. An address alone does not enable discovery across routed VLANs.
What the device exposessectionNoThese settings shape the Gladys device itself. Changing one takes effect on the next "Update" you accept in the Discovery tab.
Refresh intervalselectNoThe Apple TV pushes what it can in real time. This interval reconciles what it does not push, typically the power state on some models.
Application shortcutsbooleanNoAdd one button per installed application to the device, so scenes can open Netflix or Disney+ directly. Read from the Apple TV after pairing.
Maximum number of shortcutsnumberNoAn Apple TV can have a hundred applications. This bound keeps the device readable.
Pairing and tools, with the buttons belowsectionNoEverything below this line acts on an Apple TV you already added from the Discovery tab: pick it in the list, then press "Run". The first two buttons are the pairing itself and they go together — start with "1. Pair an Apple TV". The others are troubleshooting tools you will rarely need.
Cómo instalar Apple TV en Gladys​
  1. En Gladys, abre Integraciones: Apple TV aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/valentinhttr/gladys-apple-tv:2.3.0), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/valentinhttr/gladys-apple-tv.
Apple TV requiere Gladys >=5.2.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Apple TV es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene valentinhttr, no el equipo principal de Gladys.
