Integración domótica Android TV Remote, gratuita y de código abierto
Integración de Gladys Assistant para Android TV y Google TV mediante el protocolo Remote v2.
Control your Android TV and Google TV sets and boxes from Gladys Assistant, over the local network, through the Remote v2 protocol (TLS, ports 6466 and 6467): the one the Google TV app of your phone uses. No developer mode, no ADB to enable.
Features
For every paired TV, a Gladys device with:
- Power on / off, with state feedback: a TV that stops answering the network is marked off.
- Volume (percent) and Mute, followed in real time.
- The navigation keys (up, down, left, right, OK, back, home, menu) and the playback keys (play, pause, stop, previous, next, fast forward, rewind).
- An Application select to launch YouTube, Netflix, Prime Video, Disney+, Spotify, Plex, Twitch, Crunchyroll, YouTube Music, Apple TV, Arte, Molotov or myCANAL, and your own applications. The foreground app shows there.
- Optional Wake-on-LAN: with the MAC address of the TV, "turn on" wakes a TV that is fully powered off.
Pairing
Everything is typed in the actions of the configuration page, nothing to save in between.
- Turn the TV on.
- Step 1 — Start pairing: type the IP address of the TV (e.g.
192.168.1.50), a name if you like (e.g.Living Room TV) and its MAC address for Wake-on-LAN, then run the action. A PIN code shows up on the TV. - Step 2 — Confirm the PIN: type the code and run the action right away, the code expires.
- Run a device scan (Discovery tab) to add the TV to your devices.
Repeat for every TV. Reserve the IP address of the TV in your router (DHCP reservation): it identifies the device in Gladys.
The "Set the MAC address", "Remove a paired TV" and "Test the connection" actions list your TVs.
Dashboard widgets
With Gladys 5.1 or newer, four widgets (Edit dashboard → Add a widget). Each has a TV setting; left empty, it shows the first paired TV. They show the last state the TV reported and refresh as soon as it reports a change.
- Remote — power (On, Off, Unreachable), volume, mute, foreground app, and the Turn on / Turn off, Home, Back, OK keys.
- Playback — the foreground app and the Play / Pause, Stop, Previous, Next keys.
- Apps — up to four buttons. Without a setting, the first four apps of the launcher; else type in Application 1 to 4 the name of an app (case and accents do not matter). An unknown name is reported with the known ones. The foreground app is ticked. For more than four buttons, add a second widget.
- Volume — a tile bound to the Volume feature of the TV (live), the mute state, and the Vol −, Vol +, Mute keys (ticked while mute is on).
Good to know
- The Power and Mute keys are toggles on the TV: the integration only sends them when the known state differs from the requested one.
- The protocol has no absolute volume: the requested level is reached key by key.
- Without Wake-on-LAN, "turn on" only works on a TV in network standby. A USB-Ethernet adapter never allows a wake-up: leave the box in standby rather than off.
- An application the TV does not have is refused by the TV, which drops the connection on the way: hide it ("Applications to hide") or fix its link ("Custom applications").
- "The TV refused the pairing": the TV revoked the certificate, pair it again.
Limits
- A TV fully powered off, without a stored MAC address, can only be turned on with its remote or through HDMI-CEC.
- The foreground app is only recognized when it is part of the launcher; a custom app only when it replaces a catalog entry.
- The widgets need Gladys 5.1: an older installation no longer receives the updates of the integration.
Estos son los parámetros que Android TV Remote te pide en su pantalla de configuración en Gladys.
| Emparejar un Android TV / Google TV | section | No | Todo lo que debe introducir está en las dos acciones numeradas al final de esta página — no hay nada que guardar entre ellas. Encienda el televisor, ejecute el paso 1 y luego el paso 2, y después busque dispositivos. Repita la operación para cada televisor que quiera añadir. |
| Activar el lanzador de aplicaciones | boolean | No | Añade un selector de aplicaciones a cada televisor (Netflix, YouTube, Prime Video, Disney+, Spotify, Plex, Twitch, Crunchyroll, YouTube Music, Apple TV, Arte, Molotov, myCANAL). Se aplica a todos los televisores emparejados en la próxima búsqueda de dispositivos. |
| Aplicaciones que ocultar | string | No | Aplicaciones de la lista integrada que se quitan del selector, separadas por comas — p. ej. "Spotify, Arte". Un televisor rechaza abrir una aplicación que no tiene instalada. Se aplica en la próxima búsqueda de dispositivos. |
| Aplicaciones personalizadas | string | No | Aplicaciones que se añaden al selector, como entradas "Nombre = enlace" separadas por punto y coma — p. ej. "France TV = https://www.france.tv ; VLC = vlc://". El enlace es un App Link https o el esquema de la aplicación. Una entrada con el nombre de una aplicación integrada la sustituye (para corregir su enlace). Se aplica en la próxima búsqueda de dispositivos. |
Cómo instalar Android TV Remote en Gladys
- En Gladys, abre Integraciones: Android TV Remote aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
ghcr.io/guim31/gladys-integration-android-tv-remote:1.5.0), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración). - Abre la pantalla de Configuración de la integración, rellena los parámetros y guarda.
- También puedes instalarla directamente desde la URL de su repositorio: https://github.com/guim31/gladys-integration-android-tv-remote.
Android TV Remote requiere Gladys >=5.1.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
Android TV Remote es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene guim31, no el equipo principal de Gladys.
