Integración domótica AESO pool price (Alberta), gratuita y de código abierto
Integración AESO pool price (Alberta) para Gladys Assistant
Unofficial: the Alberta hourly pool price (AESO) for your energy contract.
Unofficial integration, not affiliated with the AESO (Alberta Electric System Operator). Never tested with a real AESO key nor a real Gladys energy contract yet.
For Alberta households on a floating (variable) retail rate that follows the hourly pool price. This integration reads the pool price of every settled hour, feeds the Gladys energy calendar spot-ca-ab and offers the contract template "AESO pool price (floating rate)". Wholesale prices are not the Regulated Rate Option (RRO) nor a fixed-rate contract: this template is for a rate that tracks the pool price.
Get a key (free)​
  1. Sign up on the AESO developer portal, https://developer-apim.aeso.ca/.
  2. Subscribe to the public product (subscribing means accepting the terms of use of the product) and copy its primary key.
  3. In Gladys, paste it in the AESO API key field of the integration and save. Press Test the key: it reads today's settled hours once and tells you the last one.
The key is kept by Gladys in its database, never shown again, sent only to the AESO (apimgw.aeso.ca) in the API-KEY header, never in a URL, a log, the status or /data.
Create the contract​
In Gladys, Energy monitoring → Contracts → New contract, pick AESO pool price (floating rate) and fill in:
InputWhat to type
Retailer adder per kWhThe adder (margin) of your floating-rate retailer, CAD/kWh, before GST. 0 counts the pool price alone.
Provisional price per kWhRequired. Your usual energy price, adder included, before GST: counted for an hour whose pool price is not published yet, then replaced.
Delivery charges per kWhYour variable distribution and transmission charges and riders, CAD/kWh, before GST. 0 leaves them out.
Fixed charges per monthYour fixed administration and delivery charges of a month, before GST.
GST5 % in Alberta.
Per kWh: (pool price + adder) + delivery, then GST on everything, fixed charges included. A negative pool price (not allowed by today's market rules) would be counted as published.
How the price of an hour gets there​
The pool price of an hour is the average of its 60 one-minute system marginal prices: it is known only once the hour has ended. So:
  • during an hour, and for a few minutes after it, Gladys counts the provisional price of the contract (labelled "Provisional (hour not settled yet)"); the price widget and the "current price" scene condition show that provisional price too;
  • 5 minutes after the end of each hour, the integration asks the AESO for the settled hours of the day and writes the new one to the calendar; Gladys then recomputes the costs from that hour with the real price (at most once every 10 minutes per calendar, by the Gladys core);
  • while the integration is stopped, the provisional price stays counted; when it comes back, it reads the missing hours and Gladys recomputes them.
A missing hour is never guessed by the integration nor written to the calendar: it stays unknown there, and Gladys counts the provisional price you chose (the price you type, even 0 if you type 0: Gladys does not refuse it). The AESO forecast pool price is never used.
What the template does not express​
  • Each hour of your meter is priced at the pool price of that hour. A retailer that bills a monthly average (weighted by the provincial load profile, for example) gives another amount: the template then only approximates your bill.
  • The integration keeps 400 days of prices: an interval older than that, in a contract starting earlier, keeps the provisional price.
AESO terms of use​
The pool prices are the AESO's data. The AESO allows a non-commercial, personal or educational use (https://www.aeso.ca/legal); the terms of use of the API product are accepted when you subscribe to it, and the AESO may refuse or revoke a key. Use your key for your own home only: do not share it, and do not share nor resell the prices. The conversion from /MWh to /kWh and the 30-minute slots are made in your own Gladys; nothing of the AESO data ships with the integration. Each status says "Source: AESO".
Source and requests​
The Pool Price Report of the AESO API, version 1.1: https://apimgw.aeso.ca/public/poolprice-api/v1.1/price/poolPrice?startDate=…&endDate=… (the days of Mountain time, both included).
  • At the first start: the last 35 days, in two requests (31 days at most per request). When a contract on the template starts earlier, its days too (400 days at most), three requests at most in a row, then a minute apart.
  • Then one request an hour, 5 minutes after the end of the hour: the day of that hour. If the hour is late, again 10, 20, 40 minutes later, then every hour while it stays late.
  • A past day answered incomplete: asked again once a day.
  • A complete day is never asked again. A restart, a reconnection, a new key or the button never ask sooner than a minute after the last request.
  • One request at a time, 20 seconds and 1 MB at most, the integration's own User-Agent (gladys-aeso/<version>), no redirect followed.
Answers are read strictly: an hour is kept only when its UTC and Mountain start times agree, the hour has ended, and the price is a plain number between −1,000 and 3,000 CAD/MWh (the market rules bound it to 0 .. 999.99 today). An empty price (the current and next hours, which only carry a forecast) is unknown, and so is a "-" (a late hour, whatever its age); any other non-numeric price is unknown during the hour after the end of its hour, then unreadable. An answer never erases a price held; a corrected price replaces it.
Errors and pauses​
AnswerWhat the integration does
401The key is refused: no automatic request any more, even after a restart, until the key is changed or the Test the key button succeeds. Only 8 bits of a salted hash of the refused key are kept in /data (many keys share them), never the key.
403 "quota"A pause until the quota comes back (the time the AESO gives, 1 minute to 6 hours, 10 minutes when none); not a refused key.
Other 403Not a refused key: retried after 5, 15, 30, 60 minutes, then every 3 hours.
429A pause for the Retry-After time (1 minute to 6 hours, 10 minutes when absent), kept in /data across a restart. The button waits for it too.
5xx, timeout, network, unreadable or too large answerRetried after 5, 15, 30, 60 minutes, then every 3 hours.
404 or 410The version 1.1 may be retired: asked again every 6 hours; update the integration.
A key changed while the integration was stopped shares those 8 bits with the refused one once in 256: it is then held as refused too until you press Test the key (a key changed while it runs is always tried).
The calendar owned by another integration (Gladys refuses it): said in the status, the prices are still read.
Time zone​
Alberta keeps UTC-6 all year: by law since 18 June 2026, and the clocks did not go back on 1 November 2026. The settlement days follow the time zone database of the integration's Node.js (2026c or later knows the change); with an older one, every winter hour would be an hour off the AESO's own Mountain times, so the integration asks nothing and says so. The history before November 2026 keeps its 23- and 25-hour days.
Status​
The integration status shows the last settled hour held, an unreadable answer (no hour of it reads while hours are expected: not connected, retried with the growing back-off), the settled hours that alone do not read (they keep the provisional price and are asked again a day later, the other hours go on hourly), no new pool price for more than 3 hours (the AESO late, or its answer changed: not connected, the contracts count the provisional price), the last check, the last error and the next attempt, the calendar not fed, the number of contracts on the template, a /data that cannot be written. /data unreadable: read again every 10 seconds, nothing asked meanwhile. The configuration not readable from Gladys: asked again after 10 seconds, then twice as long each time up to 5 minutes.
Limits​
  • Never tested with a real key nor a real contract.
  • Corrections the AESO makes to a day already complete are not read again.
  • At each connection the calendar is read back from the day of the last entry Gladys holds: days lost at its end (a database restored) are sent again. The oldest days Gladys purges every night (it keeps the calendar back to its oldest stored state) are never sent again. An empty calendar is sent again whole, once.
  • No device, no scene trigger: the price is used through the contract.
Estos son los parámetros que AESO pool price (Alberta) te pide en su pantalla de configuración en Gladys.
AESO pool pricesectionNoUnofficial, not affiliated with the AESO (Alberta Electric System Operator). For Alberta households on a floating (variable) retail rate that follows the pool price. The integration reads the hourly pool price from the official AESO API with your free API key, feeds it to the Gladys energy calendar spot-ca-ab and offers the "AESO pool price" contract template (pool price plus your retailer adder, delivery per kWh, fixed charges, GST). The pool price of an hour is known only once the hour has ended: until then Gladys counts the provisional price you type in the contract, then recomputes the cost with the real price. Get a key: sign up on developer-apim.aeso.ca, subscribe to the "public" product, copy its primary key here. Personal, non-commercial use only, under the AESO terms you accept when subscribing (aeso.ca/legal). Read-only.
AESO API keysecretSíThe primary key of your "public" subscription on developer-apim.aeso.ca. Kept by Gladys in its database, never shown again, sent only to the AESO (apimgw.aeso.ca) in the API-KEY header.
Cómo instalar AESO pool price (Alberta) en Gladys​
  1. En Gladys, abre Integraciones: AESO pool price (Alberta) aparece en el catálogo junto a las integraciones nativas, con una insignia de comunidad.
  2. Haz clic en Instalar. Gladys descarga la imagen Docker (ghcr.io/lm1lc3n7/gladys-aeso:0.1.1), la ejecuta en un entorno aislado del núcleo y genera la interfaz de la integración (dispositivos, descubrimiento y configuración).
  4. También puedes instalarla directamente desde la URL de su repositorio: https://github.com/LM1LC3N7/gladys-aeso.
AESO pool price (Alberta) requiere Gladys >=5.3.0. El catálogo de Gladys se actualiza cada hora, así que una nueva versión está disponible como máximo una hora después de publicarse.
AESO pool price (Alberta) es una integración externa: una integración comunitaria empaquetada como contenedor Docker y publicada en GitHub. Gladys la instala con un clic y la ejecuta en un entorno aislado del núcleo. La publica y mantiene LM1LC3N7, no el equipo principal de Gladys.
