Migrate from Home Assistant to Gladys: Zigbee2MQTT, Z-Wave, Matter
Moving from Home Assistant to Gladys? Most of your devices come with you without pairing them again: the Zigbee2MQTT network, the Z-Wave network, Matter devices and MQTT devices. What stays behind is what you built in Home Assistant: automations, dashboards and history.
You don't have to switch everything in one evening: Gladys can run next to Home Assistant, connected to the same devices, while you rebuild your scenes. You turn Home Assistant off at the end.
What you keep, what you redo​
In Home AssistantIn GladysPair again?
Zigbee2MQTT add-onZigbee2MQTT integration: Gladys connects to it, then takes it overNo
ZHAZigbee2MQTT integrationYes
Z-Wave JS or Z-Wave JS UIZ-Wave JS UI integration (community), with the same stickNo
MatterMatter integration, with a code shared by Home AssistantNo
MQTT devices (ESPHome, OpenMQTTGateway, DIY…)MQTT integration, Home Assistant DiscoveryNo
Tasmota, ESPHome, Shelly, Philips Hue, Netatmo, Tuya…Their integration in GladysNo, in most cases
Automations, scriptsScenesRebuild them
DashboardsDashboardsRebuild them
HistoryNot transferred—
  1. Install Gladys next to Home Assistant, on another machine or in another virtual machine: for example Gladys Assistant OS on a mini-PC.
  2. Connect Gladys to what Home Assistant runs: the Zigbee2MQTT add-on, the MQTT broker, the Matter devices. Nothing moves, and you can go back at any time.
  3. Rebuild your scenes and your dashboards in Gladys, and use it every day for a while.
  4. Move the radios (Zigbee dongle, Z-Wave stick) to the Gladys machine, one at a time.
  5. Turn Home Assistant off, once nothing depends on it anymore (see Turn Home Assistant off).
warning
A Zigbee dongle or a Z-Wave stick is driven by a single software at a time. Never let Home Assistant and Gladys drive the same radio: stop the add-on in Home Assistant before you start it in Gladys.
Zigbee2MQTT​
If your Zigbee devices run on the Zigbee2MQTT add-on of Home Assistant (called an app in recent versions of Home Assistant), you have two options:
  • Option A: Gladys connects to the Zigbee2MQTT of Home Assistant. Nothing moves: Zigbee2MQTT stays on Home Assistant and Gladys reads it through MQTT. It's the fastest way to try Gladys.
  • Option B: you move Zigbee2MQTT into Gladys. Gladys then runs the MQTT broker and Zigbee2MQTT itself, and Home Assistant no longer needs to run.
You can do both in a row: start with option A, then switch to option B when you are ready. The devices you add in Gladys are linked by their Zigbee2MQTT name, and option B keeps these names: you normally don't have to add them to Gladys again.
Option A: connect Gladys to the Zigbee2MQTT of Home Assistant​
  1. Create an MQTT user for Gladys. The Mosquitto broker add-on of Home Assistant accepts the Home Assistant users: create a user dedicated to Gladys in Settings > People > Users. You can also add one under logins in the configuration of the Mosquitto add-on.
  2. In Gladys, go to Integrations > Zigbee2MQTT, Setup tab. In step 1 of the wizard, click on I already have a Zigbee2MQTT.
  3. Enter:
    • the MQTT broker address: mqtt://IP_OF_HOME_ASSISTANT:1883 (the Mosquitto add-on opens port 1883 by default);
    • the User and the Password you just created;
    • the Zigbee2MQTT interface address (optional). On Home Assistant, the Zigbee2MQTT interface usually opens only from the Home Assistant sidebar: leave this field empty, unless you opened its port in the network settings of the add-on.
  4. Click on Connect. Your devices show up in the Discover tab: add them to Gladys.
warning
Gladys listens to the zigbee2mqtt/# topic: the base topic of your Zigbee2MQTT (mqtt.base_topic) must still be zigbee2mqtt, the default value of the add-on.
A device shows its values as soon as it is added, when Zigbee2MQTT has sent them since Gladys connected to it. A battery sensor shows its values at its next report: give it up to an hour or so.
Pros: five minutes of setup, nothing to break, and you can go back at any time. Cons: Home Assistant (Mosquitto and Zigbee2MQTT) keeps running. If it goes down, your Zigbee network goes down with it.
Option B: move Zigbee2MQTT into Gladys​
Your whole Zigbee network lives in the data folder of Zigbee2MQTT and on the coordinator (your Zigbee dongle). Copy the folder, move the dongle, and Gladys takes over the network as it is.
Before you start
  • You have SSH access to the Gladys machine.
  • You keep the same Zigbee dongle as in Home Assistant: the network settings are stored on it.
  • Zigbee2MQTT is not set up in Gladys yet. If it is (you used option A, or you installed it to test), first click on Reset the integration in the Advanced settings of the Setup tab. Do it before copying the files: the reset deletes the Zigbee2MQTT folder of Gladys. The devices you already added in Gladys are kept.
  • If this Gladys already runs its own Zigbee network, with devices you use, these devices are not part of the Home Assistant network: you will have to pair them again on it after the move. Keep a copy of /var/lib/gladysassistant/zigbee2mqtt/z2m before the reset, in case you want to go back.
1. Stop Zigbee2MQTT in Home Assistant​
In Home Assistant, stop the Zigbee2MQTT add-on and turn off its Start on boot option, so that it stays stopped. Two Zigbee2MQTT must never run on the same network.
2. Get the Zigbee2MQTT folder​
With the Samba share or Terminal & SSH add-on, get the folder of Zigbee2MQTT. It is the zigbee2mqtt folder of the Home Assistant configuration: config/zigbee2mqtt on the Samba share, /homeassistant/zigbee2mqtt (or /config/zigbee2mqtt, depending on the version of the add-on) in the terminal. If you changed the data_path option of the add-on, the folder is at that path instead.
Take the whole folder, not only some files. Besides configuration.yaml, database.db and coordinator_backup.json, it can hold devices.yaml and groups.yaml (the names of your devices), secret.yaml (the network key, when the configuration reads it with !secret), state.json (the last known states) or an external_converters folder. Only the log folder is not needed.
Keep a copy of this folder as it is: it is your way back.
3. Copy the folder to the Gladys machine​
Its content goes into the Zigbee2MQTT folder of Gladys: /var/lib/gladysassistant/zigbee2mqtt/z2m/ on a standard installation. For example, from your computer, send the folder to your home folder on the Gladys machine with scp:
scp -r zigbee2mqtt USER@IP_OF_GLADYS:~
Then, on the Gladys machine, copy its content into the Zigbee2MQTT folder of Gladys, created if it does not exist yet:
sudo mkdir -p /var/lib/gladysassistant/zigbee2mqtt/z2m
sudo cp -r ~/zigbee2mqtt/. /var/lib/gladysassistant/zigbee2mqtt/z2m/
If you installed Gladys with Docker in another folder than /var/lib/gladysassistant, use your folder instead.
4. Edit configuration.yaml​
Open configuration.yaml on the Gladys machine (for example with sudo nano /var/lib/gladysassistant/zigbee2mqtt/z2m/configuration.yaml) and fix these lines by hand:
homeassistant:
enabled: false
mqtt:
base_topic: zigbee2mqtt
server: mqtt://localhost:1884
  • server must point to the MQTT broker of Gladys (port 1884). Otherwise, it still points to the Mosquitto of Home Assistant: Gladys does not rewrite this line. If the line is missing, add it.
  • homeassistant: write enabled: false under the homeassistant section. Don't replace the section with homeassistant: false: Zigbee2MQTT 2 refuses this form and does not start.
  • Leave the rest as it is. Gladys rewrites on its own, at startup, the MQTT username and password, the serial port and the adapter of the dongle, and the port of the web interface. The network key, the PAN ID and the channel are kept.
5. Install Zigbee2MQTT from Gladys​
Plug the Zigbee dongle into the Gladys machine. If Gladys runs in a virtual machine, pass the dongle through to it (see the Proxmox guide). With a network coordinator (SLZB-06…), there is nothing to plug in: in the wizard, click on Network coordinator (SLZB-06…)? and enter its address (see Use a network coordinator).
In Gladys, go to Integrations > Zigbee2MQTT, Setup tab, and follow the setup wizard: Gladys recognizes the most common dongles (ConBee II, SONOFF ZBDongle-P and ZBDongle-E…); otherwise, choose its model in the list. Click on Install.
Gladys keeps the configuration.yaml it finds in the folder, so Zigbee2MQTT starts on your existing network. Once the network is ready, the dashboard shows the number of devices in the network.
6. Check your devices​
  • Devices you already added in Gladys with option A work again as they are.
  • The other ones show up in the Discover tab: add them to Gladys.
Battery sensors show their values at their next report.
Go back to Home Assistant​
Something went wrong? On the dashboard of Gladys, click on Stop (Gladys remembers it and does not start Zigbee2MQTT again). Plug the dongle back into the Home Assistant machine, put your copy of the folder back if needed, and start the Zigbee2MQTT add-on again.
Devices paired with ZHA​
ZHA (the built-in Zigbee integration of Home Assistant) is a different case:
  • ZHA does not use MQTT. Gladys cannot connect to it, so option A does not work for these devices.
  • Gladys runs a single Zigbee2MQTT, so a single Zigbee dongle. If you used one dongle for Zigbee2MQTT and another one for ZHA, you can't run both in Gladys.
The simplest and most reliable way: move the Zigbee2MQTT network (option B), then pair the devices that were on ZHA again on it, from the Discover tab, with Permit joining. It takes a bit of work once, but you then have a single network, and a stronger mesh.
If all your Zigbee devices are on ZHA, stop ZHA in Home Assistant (or turn Home Assistant off), plug the dongle into the Gladys machine, install Zigbee2MQTT and pair your devices again.
Z-Wave​
Gladys talks to Z-Wave through the community Z-Wave JS UI integration, which you install from the integrations catalog. Z-Wave JS UI keeps driving the stick, and the integration reads it over MQTT. Your Z-Wave network (the devices and their node numbers) is stored on the Z-Wave stick itself: plugged into another Z-Wave JS UI, the stick brings its devices with it.
To try Gladys first: if Home Assistant uses the Z-Wave JS UI add-on, turn on its MQTT gateway, connected to the Mosquitto of Home Assistant, with the MQTT and Gateway settings the integration expects (see Setting up Z-Wave JS UI). Then install the Z-Wave JS UI integration in Gladys and enter this broker in its Configuration tab. The official Z-Wave JS add-on has no MQTT gateway: Gladys cannot connect to it.
To move the stick:
  1. Write down the security keys of your network: in the Configuration tab of the Z-Wave JS add-on (the S0, S2 and Long Range keys), or in Settings > Z-Wave of Z-Wave JS UI. Without them, the devices paired securely (locks, alarms…) no longer answer.
  2. Stop the add-on in Home Assistant and turn off its Start on boot option.
  3. Install Z-Wave JS UI on the Gladys machine, with Docker (see the Z-Wave JS UI documentation), next to an MQTT broker: the one the MQTT integration of Gladys installs works. Plug the stick in.
  4. In Z-Wave JS UI, enter the same security keys in Settings > Z-Wave, then the MQTT and Gateway settings the integration expects: Name zwave-js-ui, Prefix zwave, Topic type Named topics, Payload type Entire Z-Wave value Object…
  5. In Gladys, install the Z-Wave JS UI integration from the integrations catalog, enter the broker in its Configuration tab, then add your devices from the Discover tab.
The integration identifies Z-Wave devices by their node number, which the stick keeps: devices added in Gladys before the move keep working. The names you gave in Home Assistant don't come along: rename the devices in Gladys.
Matter​
Matter devices can be controlled by several controllers at once (multi-admin). So you don't have to remove them from Home Assistant to add them to Gladys:
  1. In Home Assistant, open the device and click on Share device, then on Share device again: Home Assistant shows a QR code and a sharing code. The code expires after a few minutes: enter it in Gladys right away.
  2. In Gladys, go to Integrations > Matter, Add Device tab, enter this code, then add the device from the Devices tab (see the Matter guide).
Gladys becomes a controller of the device, next to Home Assistant: the device keeps working with Gladys once Home Assistant is turned off.
Thread devices
A Matter over Thread device needs a Thread border router on your network, and Gladys is not one. If yours is the one of Home Assistant (the OpenThread Border Router add-on, with a Home Assistant Connect ZBT-1 or ZBT-2 dongle, for example), your Thread devices stop answering when you turn Home Assistant off. Another border router (Apple TV, HomePod, Nest Hub…) only takes over if it is on the same Thread network, and it often forms its own. Before turning Home Assistant off, stop the OpenThread Border Router add-on and check that your Thread devices still answer in Gladys. Read If your device uses Thread only, and ask on the forum if in doubt.
MQTT devices and other integrations​
MQTT devices. Since Gladys 4.86, the MQTT integration understands the Home Assistant Discovery protocol: devices that publish their configuration on the homeassistant/ topic of the broker (ESPHome with MQTT, OpenMQTTGateway, DIY devices…) show up on their own in its Discovery tab. You can first connect the MQTT integration to the Mosquitto of Home Assistant. Before turning Home Assistant off, point your devices to the MQTT broker installed by Gladys, connect the MQTT integration to this broker, then restart the devices: they publish their discovery messages again when they reconnect.
Don't add your Zigbee devices from there: Zigbee2MQTT can publish Home Assistant discovery messages too, but use the Zigbee2MQTT integration for them, which supports them fully.
Devices with their own integration. Many brands have their integration in the Gladys catalog: Tasmota, ESPHome, Shelly, Philips Hue, Netatmo, Tuya, cameras… Look for yours in the integrations catalog, and add your devices from there: they stay paired with their bridge, their cloud or your Wi-Fi, so there is nothing to pair again.
Automations, dashboards and history​
These stay in Home Assistant:
  • Automations and scripts: rebuild them as scenes. Run them in Gladys only once they are turned off in Home Assistant, otherwise they run twice.
  • Dashboards: rebuild them in Gladys with the dashboards.
  • History: the history of your sensors is not transferred. Gladys starts recording when you add a device.
  • Node-RED: if you use the Node-RED add-on, you can export your flows and import them into the Node-RED that the community Node-RED integration runs next to Gladys. The Home Assistant nodes no longer work: replace them with MQTT nodes.
Turn Home Assistant off​
Before turning Home Assistant off for good, check that:
  • every radio (Zigbee dongle, Z-Wave stick) is plugged into the Gladys machine, and its add-on is stopped in Home Assistant;
  • no device uses the Mosquitto broker of Home Assistant anymore (Tasmota, Shelly, ESPHome…): point them to the broker of Gladys;
  • your Thread devices still answer in Gladys with the OpenThread Border Router add-on of Home Assistant stopped (see Matter);
  • your scenes run in Gladys.
Keep a backup of Home Assistant for a few weeks: it's your plan B.
Need help?​
If you get stuck at any step, ask your question on the community forum.
