Wiffi (stall.biz) Smart-Home-Integration, kostenlos und Open Source
Wiffi (stall.biz)-Integration für Gladys Assistant
Wiffi sensors by stall.biz (weatherman, rainyman, airsniffer…), locally, read only.
This integration reads the sensors of stall.biz Wiffi devices (weatherman, rainyman, airsniffer, wiffi-wz…): temperature, humidity, pressure, brightness, wind, rain, locally, without any cloud and read only. Each Wiffi sends its values to Gladys by itself, as JSON telegrams.
Unofficial integration, not affiliated with stall.biz. Never tested with a real device: it follows the reference library wiffi 1.1.2 (used by Home Assistant); your feedback is welcome.
How it works​
Gladys starts a small receiver (wiffi-push) next to the integration, listening on a TCP port Gladys chooses. The Wiffi opens a connection to that port, sends one JSON telegram ended by the byte 0x04, then closes. The integration reads the telegram, recognizes the Wiffi by its MAC address and publishes its values.
Setup​
  1. Install the integration, then save its configuration once (even empty): Gladys starts the receiver and chooses its port.
  2. Reload the configuration screen: the port shows in the "Set up each Wiffi" section.
  3. In the web page of each Wiffi:
    • set the CCU address ("CCU-IP") to the IP address of the Gladys machine on your local network (not the one of Gladys Plus or of a proxy);
    • set the port of the JSON telegrams (parameter send_json) to the port shown;
    • choose JSON without header (a telegram after HTTP headers is read too).
  4. Allow this port in the firewall of the Gladys machine if it has one.
  5. After the first telegram, the Wiffi appears in the Discovery tab: create it.
  • Allowed senders: the IP addresses of your Wiffis (or a network such as 192.168.1.0/24, /16 to /32), separated by commas, 16 at most. Empty: any private address of your local network (10.x, 172.16-31.x, 192.168.x, 169.254.x, local IPv6) is accepted. An invalid list refuses every telegram until it is corrected (the status gives the position of the wrong entry). Give your Wiffis a fixed IP address in your router. Depending on the Docker network setup, the receiver may see another address than the Wiffi's: the status shows the refused address.
  • Silent after (minutes): 2 to 60, 5 by default. A Wiffi that sends nothing for this long is shown unreachable and named in the status; a sensor without a valid value for this long (while its Wiffi talks) is named too.
What is published​
Wiffi unitIn Gladys
gradCtemperature (°C), -60 to 100
% whose name holds "feucht" or "humid" (not "abs")humidity (%)
% whose name holds "boden" or "soil"soil moisture (%)
mbpressure (mbar), 300 to 1200
luxbrightness (lux)
gradangle (°), -90 to 360 (wind direction, sun elevation)
km/h, m/sspeed
mm/hprecipitation (mm/h)
mm with a word of its name "heute", "tag", "today", "day", "24", "24h" or "h24"precipitation of the day (mm/day)
mm with a word of its name "stunde", "hour", "1h" or "h"precipitation of the hour (mm/h)
ppm whose name holds "co2", "kohlendioxid" or "carbon_dioxide" (or "carbondioxide")CO2 (ppm), 0 to 10,000
ppm with the word "co" in its name, or whose name holds "kohlenmonoxid" or "carbon_monoxide" (or "carbonmonoxide")CO (ppm), 0 to 1000
ppb whose name holds "voc"VOC (ppb), 0 to 100,000
boolean whose name holds "regen", or with a word starting with "rain"rain sensor
boolean whose name holds "beweg" or "motion", or with the word "pir"motion sensor
text (wind direction in letters…)text
A "word of the name" is a part between two _, whatever the case (regen_tag: "regen" and "tag"); "holds" means anywhere in the name (w_luftfeuchte holds "feucht"). So stage or montag_regen do not say the day, cooling or a_coil are no CO, w_drain is no rain and w_expired no motion. An exclusion ("abs", yesterday) applies anywhere in the name.
The rules on the names (rain of the day or of the hour, the gases) are a guess: the variable names of each model were not read in the manufacturer's documentation. An ambiguous name (day and hour both; co_2, CO2 or a second CO probe) and another gas in ppm (formaldehyde…) are not published, only listed. To confirm with real devices: feedback is welcome.
Nothing is made up:
  • an empty value, nan, a text, a comma decimal ("1,5") or a value outside the range of its kind is not published (never a 0 instead);
  • another unit (g/m3…), a mm whose name says neither the day nor the hour (or says yesterday: "gestern", "vortag", "yesterday"), or another boolean is not published: the status lists these variables (the first 20), so they can be added. W/m2 (radiation) has no category in Gladys: never published;
  • a Wiffi is kept (and offered in the Discovery) only once it sent at least one value it can publish;
  • the network details of the Wiffi (IP address, SSID, Wi-Fi signal) are not published;
  • when the unit of a variable changes, the existing feature is no longer fed and the status says so.
A value received more than a minute ago (kept by the receiver while the integration restarted, for example) is published with its date; beyond 2 h, it is not published. A telegram older than the last one applied is ignored.
Limits of the receiver​
So that a faulty or hostile device of the network cannot flood Gladys: an address not allowed is closed before anything is read; a telegram is cut beyond 64 KB; 16 connections at most (4 per address, the oldest of the address makes room); a connection is closed after 5 s without a byte and 15 s in all, after 4 telegrams (an empty one counts) and beyond 129 KB; 60 telegrams a minute per address (240 in all, empty ones count), the rest is ignored. Each refusal is counted in the status for an hour. The number of connections a second from one address is not capped: each one stays bounded as above. When Docker shows every Wiffi under one address (its gateway), they share the 60 a minute of that address: enough for Wiffis sending every few seconds, not for dozens of them.
The MAC address of a telegram is not a proof of who sent it: any machine allowed to send can claim one. List your Wiffis in "Allowed senders". The table holds 32 Wiffis: when it is full, the Wiffi not created in Gladys heard the longest ago makes room (a Wiffi created in Gladys never does), and a Wiffi never created and not heard for a day is forgotten.
Security​
The telegrams travel in clear: never expose the port to the Internet. The integration sends nothing to the Wiffis and never commands them.
Data kept​
/data/wiffi.json keeps the list of the Wiffis, their features and the time of their last telegram (32 Wiffis and 150 features per Wiffi at most), never a value. When it cannot be read, it is never written over and it is read again every 10 s.
Diese Einstellungen fragt Wiffi (stall.biz) in seinem Konfigurationsbildschirm in Gladys ab.
Your Wiffis, on your local networksectionNeinWeather, rain, air and temperature sensors of stall.biz Wiffi devices (weatherman, rainyman, airsniffer, wiffi-wz…), without any cloud and read only. Each Wiffi sends its values to Gladys by itself, as JSON telegrams (a small receiver started by Gladys next to this integration). A Wiffi appears in the Discovery tab after its first telegram. Never tested with a real device. Unofficial integration, not affiliated with stall.biz.
Set up each WiffisectionNeinIn the web page of the Wiffi: set the CCU address ("CCU-IP") to the IP address of the Gladys machine on your network ({{gladys_host}} is how your browser reaches Gladys, it may differ), set the port of the JSON telegrams (parameter "send_json") to {{port:wiffi_json}} (chosen by Gladys), and choose JSON without header. The port appears once this configuration was saved once: save, then reload this screen. Allow this port in the firewall of the Gladys machine if it has one.
Allowed sendersstringNeinThe IP addresses of your Wiffis (or a network such as 192.168.1.0/24), separated by commas. Empty: any address of your local network (private addresses) may send telegrams. Give your Wiffis a fixed IP address in your router and list them here.
Silent after (minutes)numberNeinA Wiffi that sends nothing for this long is shown unreachable and named in the status; a sensor without a valid value for this long is named too. 2 to 60 minutes.
So installierst du Wiffi (stall.biz) in Gladys​
  1. Öffne in Gladys Integrationen: Wiffi (stall.biz) erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/lm1lc3n7/gladys-wiffi:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-wiffi.
Wiffi (stall.biz) benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Wiffi (stall.biz) ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
