Visual Crossing Smart-Home-Integration, kostenlos und Open Source
Unofficial connector: Visual Crossing weather, 15-day forecasts and alerts, with your API key.
Unofficial connector, not affiliated with Visual Crossing Corporation. It makes Visual Crossing the weather provider of Gladys: current conditions, 24-hour and 8-day forecasts (Visual Crossing gives 15 days, Gladys keeps 8), and the active alerts of the location. The weather widget, the assistant and the weather-alert scene triggers of Gladys use it directly.
This integration was never tested with a real account: it is written from the official documentation of the Visual Crossing Timeline Weather API. Feedback is welcome.
What you need
- A Visual Crossing account of your own and its API key (sign up at visualcrossing.com, the key is on the Account page).
- Gladys 5.1 or later.
Costs
Visual Crossing counts records. A forecast query (what this integration sends) costs 1 record, whatever its
days, hours and alerts; the integration reads the queryCost of each answer and counts it.
- Free plan: 1,000 records a day. Above that, Visual Crossing answers 429 until the next day.
- Pay-as-you-go plan: the records beyond the free ones are billed by Visual Crossing (0.0001 USD per record at the time of writing, see the plans).
- Other plans: see your account.
The integration has its own daily cap (500 records by default), counted before each call and kept in /data
across restarts: once reached, nothing is sent before midnight UTC. A call that may have been billed is not
retried: after a timeout, a network error or a 5xx, the location waits 15 minutes; after a 401, the key is no
longer used. With the default refresh of
60 minutes, one location costs at most 24 records a day.
| Field | Purpose |
| API key | Kept by Gladys in its database, never shown again, sent only to Visual Crossing. It never appears in the logs, the status, the error messages or /data. |
| Weather alerts | On by default. Same cost (the alerts come in the same answer). |
| Refresh interval | 60 minutes by default (60 to 180). A location is read from Visual Crossing at most once per interval; Gladys gets the kept copy in between. |
| Daily cap | 500 records by default (10 to 100,000), per day in UTC. Visual Crossing counts all the uses of your key in the same account: keep room for your other uses. |
Test Visual Crossing makes one call (the current conditions at Greenwich, 1 record, no personal data): it says whether the key is accepted and the records counted today. It runs at most once a minute, and not during a pause (after a 429, an error or a timeout) nor once the daily cap is reached.
Pacing, pauses and errors
- Gladys asks for the weather when a dashboard shows it, when the assistant answers, and every 30 minutes for the alerts when a scene uses the weather-alert trigger. The integration answers from its kept copy while it is younger than the interval.
- One call at a time to Visual Crossing, whatever the number of locations.
- HTTP 429: paused as long as
Retry-Aftersays (compared with the server'sDateheader), between 60 s and 6 hours; without the header, 60 s then doubled up to 6 hours. - Timeout (10 s), network error, server error, 403, unreadable or oversized (over 1 MB) answer: a 60 s pause
for every location (or the
Retry-Afterof the answer, 60 s to 1 hour), doubled at each failure up to 1 hour (the step survives a restart and is reset by a success), and this location is not asked again for 15 minutes (the failed call may have been billed). - HTTP 400 or 404: the location is not served; only that location is held back for one refresh interval.
- Gladys waits 15 s for an answer: a call that cannot end in time does not leave.
- A clock that jumps forward then back never freezes the cap: a count filed under a day further than tomorrow is kept, on the safe side, but filed under today and reset at the next midnight UTC.
- A request that could not even be prepared (a local error before it leaves) counts no record, holds nothing and pauses nothing.
- If the count of a call cannot be written to
/datawithin 1 s, the call does not leave (the cap must survive a restart). - During a pause or an outage, Gladys gets the last copy if it is under 4 hours old, with its own date (never presented as new); otherwise an error, and Gladys moves on to its next provider.
- The pause, the holds, the counter and the copies are kept in
/data: a restart or a reconnection does not trigger a call. A saved configuration asks Gladys to read the weather again, answered from the copy while it is younger than the interval.
Refused key
An HTTP 401 is a refusal of the key (Visual Crossing: key, account or subscription problem): no request leaves
with it any more, and it is not retried. /data keeps only one byte of a salted hash of the key: nothing a
reader could check a guess against (one guess in 256 matches). Saving another key while the integration runs
lifts the refusal at once. After a restart only that byte is known: a new key whose byte happens to be the same
(1 chance in 256) stays held back until a success of Test Visual Crossing, which tries even a refused key. A 403
is not taken as a refusal (it can come from a proxy or a firewall): it pauses.
What is sent to Visual Crossing
The coordinates of the house rounded to 3 decimals (about 100 m) and the API key (in the address of the request,
as Visual Crossing asks; this address is never logged). Neither the language nor the unit system is sent: the
answer is asked in metric and converted here, so one call serves every user. /data/state.json holds the day
counter, the pause, the holds, one byte marking a refused key, and the last answers. The answers carry no
coordinates, but each is filed under a salted hash of the rounded location: with the salt beside it, the
location can be found back by brute force. /data stays on your Gladys.
Mappings
| Visual Crossing icon (icons2 set) | Gladys |
| clear-day, clear-night | clear |
| partly-cloudy-day/night / cloudy | partly-cloudy / cloud |
| fog / wind | fog / wind |
| rain, showers-day/night | rain; pouring from 7.6 mm in an hour; freezing-rain or sleet by the type |
| snow, snow-showers-day/night | snow; sleet when rain or ice is mixed in |
| thunder-rain, thunder-showers-day/night | thunderstorm (snow-thunderstorm with snow only) |
| any other icon | unknown |
Day or night comes from the sunrise and sunset times, else from the icon (-day/-night). Units: metric is
converted to m/s (wind) and km, or to °F, mph, inches and miles (US); pressure stays in hPa; humidity, cloud cover
and precipitation chance in percent. A missing value stays missing, never 0.
Alerts: Visual Crossing gives no level. It is read from the title: a "watch", yellow or moderate → moderate (even an "Extreme ... Watch"); red, extreme, emergency, tornado or hurricane warning → extreme; orange, severe or "warning" → severe; anything else → minor (the alert is kept). The phenomenon (storm, wind, snow...) is read from the title in English, French, German or Spanish. Alerts ended by the server's clock are removed.
Attribution
Weather data provided by Visual Crossing (https://www.visualcrossing.com/). The Gladys weather widget cannot show an attribution yet: it is on the configuration screen and here.
Statuses
- "Enter the API key...": nothing configured.
- "Invalid configuration: ...": names the wrong fields (never their value); nothing is sent.
- "Ready", then "Visual Crossing answers".
- "Visual Crossing refused this API key...", "asked to slow down...", "did not answer properly...", "Daily cap reached...".
- "/data/state.json is unreadable": read again every 10 s, nothing is sent meanwhile (an unreadable file is not taken as empty).
- "The configuration could not be read": new try after 5 s, then doubled up to 5 minutes.
Diese Einstellungen fragt Visual Crossing in seinem Konfigurationsbildschirm in Gladys ab.
| Visual Crossing in Gladys | section | Nein | Unofficial connector, not affiliated with Visual Crossing. It makes Visual Crossing the weather provider of Gladys: current conditions, 24 hours, 8 days and the alerts given for your area. It needs your own Visual Crossing account and API key. The free plan includes 1,000 records a day; a forecast costs 1 record. On the pay-as-you-go plan, records beyond the free ones are billed by Visual Crossing (0.0001 USD each at the time of writing): the daily cap below stops the calls first. Each location is read at most once per refresh interval (one hour by default). Weather data provided by Visual Crossing. |
| API key | secret | Ja | The key of your Visual Crossing account (Account page). Kept by Gladys in its database, never shown again, sent only to Visual Crossing. |
| Weather alerts | boolean | Nein | Asks Visual Crossing for the active alerts of the location (same cost), shown by the weather widget and used by the weather-alert scene triggers of Gladys. |
| Refresh interval (minutes) | number | Nein | A location is read from Visual Crossing at most once per interval; Gladys gets the kept copy in between. 60 minutes is at most 24 records a day per location. |
| Daily cap (records) | number | Nein | Records allowed per day (UTC), counted by this integration before each call and kept across restarts. Reached: no call until midnight UTC. Visual Crossing counts the records of all your uses of the key in the same account. |
So installierst du Visual Crossing in Gladys
- Öffne in Gladys Integrationen: Visual Crossing erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
ghcr.io/lm1lc3n7/gladys-visual-crossing:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration). - Öffne den Bildschirm Konfiguration der Integration, fülle die Einstellungen aus und speichere.
- Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-visual-crossing.
Visual Crossing benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Visual Crossing ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
