USGS Water Data Smart-Home-Integration, kostenlos und Open Source
USGS Water Data-Integration für Gladys Assistant
Unofficial. U.S. rivers and wells: discharge, level and temperature (USGS).
Unofficial integration, not affiliated with the U.S. Geological Survey (USGS). It reads the latest values of the USGS monitoring stations you choose, in the United States, from the new USGS Water Data APIs (api.waterdata.usgs.gov, public domain): no account, no key. Read-only: nothing is ever sent to the USGS but GET requests.
Tried against the real USGS Water Data API on 30 October 2026 (six stations: rivers, a dry well, a groundwater well); never tested with a real Gladys installation yet: tell us what you see.
This is not a warning system. Most values are provisional (the USGS may revise them), measured every 15 minutes and sent about every hour. For floods, follow the National Weather Service and your local authorities.
Setup​
  1. Find the station numbers: the Search stations button of the configuration (words of the name, e.g. potomac dc), or the map at https://waterdata.usgs.gov/.
  2. Type them in Stations (8 to 15 digits, separated by commas or spaces, 20 at most). A station of another agency: its full id, such as AR008-343826091361301.
  3. Pick the units, the language of the texts, the read interval (15 to 120 minutes, 15 by default) and the maximum age (1 to 48 hours, 3 by default), then save.
  4. After the first read, open the Discovery tab: one device per station, with the features of what the station measured recently. Create the ones you want.
FeatureU.S. unitsMetric unitsUSGS parameter
Dischargeft³/sm³/s00060, 30208
Gage heightftm00065
Water temperature°F°C00010
Depth to water below land surfaceftm72019
Statustexttext
  • A feature is offered only once the station gave a current value of it. A kind that shows up later (a well no longer dry, a gauge after the ice) is added to the device in the Discovery tab: its Update button gives the device the new feature, keeping the others and their history. So a device created while its station is dry, iced or out of service has only its Status feature until you click Update once the value is back.
  • Parameter 30208 is the discharge in m³/s that a few stations publish instead of (or beside) 00060; it fills the same feature. Not read: the measured discharge 00061 (no continuous series on the service on 30 October 2026) and the elevation of lakes and reservoirs (62614).
  • Conversions are exact (1 ft = 0.3048 m, 1 ft³/s = 0.028316846592 m³/s, °F = °C × 9/5 + 32), then rounded (0.001 for ft, ft³/s and m, 0.0001 for m³/s, 0.01 for degrees).
  • The unit is part of the feature: a device keeps the units it was created with, even when the form changes them. To change units, delete the device and create it again from Discovery, or use Update in Discovery: either way the features of the old units, and their history, go.
  • Gladys has no unit for a flow: the discharge is a plain number, its unit in its name.
  • The Status gives the time of the measurement in the time zone of the station ("Measured Oct 30, 1:50 AM EDT"), then what the USGS says of the values published: when they are all provisional (the usual case), "provisional" once, then each kind with its codes ("Measured Oct 30, 1:50 AM EDT, provisional; discharge: estimated"); otherwise each kind once, the provisional ones first ("Measured Oct 30, 1:50 AM EDT; discharge: provisional, estimated; gage height: revised"); then the kinds late with their reason ("late: temperature (equipment fault)"; the text is cut at 120 characters, from the end), or why there is no value: "No value (dry)", "No value (ice)", "No value (below the minimum measurable)", "Unreadable value at the source", "No current value; last one …", "No continuous data at this station", "Station unknown to the USGS". The connection status says how many stations have qualified values.
  • The time zone of a station comes from the USGS (its abbreviation). Its daylight saving flag is wrong for many stations (most of Florida says "no daylight saving"): it is only used to tell Arizona from the rest of the Mountain zone; every other station follows the daylight saving time of its zone. American Samoa (ZP-11) shows its own time; an unknown zone, UTC.
Freshness​
  • Each measurement is published once (deduplicated on its time, kept in /data), without a creation date: a scene "gage height above X" fires on a new measurement, not at every read. The point in the Gladys history is dated when it is published, not when it was measured: later by the transmission delay of the station plus up to one read interval (at most the maximum age). The SDK can date a state, but a dated state does not fire scenes.
  • A measurement older than the maximum age of the form is not current: it is not published, the status says when it was measured. The age is counted from the Date of the USGS answer (from our clock when that header is missing or more than a day away from it), plus the time since the read.
  • A value dated more than 15 minutes in the future, a value that is not a plain number (a text, an empty value), out of the plausible range of its kind (for example a "-999999") or in an unknown unit is unreadable: never published.
  • Qualifiers. The USGS sends codes with a value. Those that only nuance it (ESTIMATED, REVISED, BACKWATER, REGULATED, DEBRIS, DIFFDATUM, RATINGDEV, TIDE, URBAN, OTHERAGENCY, OPPORTUNISTIC, FORCEINTERPOLATION): the value is published, the status says the code. Every other code (DRY, ICE, EQUIP, MAINT, UNAVAIL, TEST, DISCONTINUED, SEASONAL, FLOOD, DAMFAILURE, ZEROFLOW, LESSTHAN, GREATERTHAN, BLWMIN, GHNOTASSCPKQ, and any code not in these lists) means the number is not a measurement of the water: it is not published, even when the USGS gives one (a dry well's number is the depth of its sensor; a dry or zero-flow stream gauge's 0.00 is not published either; "less than" is a bound), and the status gives the reason. The list is the one the real service sent on 30 October 2026.
  • Most values are provisional (not yet approved by the USGS): the status says "provisional".
  • A station with several series of one kind (two sensors, a series stopped in 2019): among the current ones, the one of smallest series id (the same one from read to read while it stays current).
  • Gladys keeps the last value published: when a value is no longer current, the Status says it; the value shown keeps its own date in Gladys.
  • The status texts follow the ages at each read, and at every interval during a long pause.
Flood thresholds and scenes​
The USGS API gives no flood stage (the flood categories belong to the National Weather Service). Use the thresholds you know for your river in a scene: the Device state change trigger on the gage height or the discharge, with the condition "greater than X". It fires on the first current measurement above X.
Pace and requests​
  • One request for all the stations at every read (latest-continuous), followed by at most 2 more pages if the answer has some (never another address), then, once a week, one request for the names and time zones of the stations (monitoring-locations). One request at a time, the search button included.
  • One read per interval, whatever asks: saving the form unchanged, a reconnection, the Discovery tab, a device created or a restart read nothing sooner (the time of the read is written to /data before the request). Exceptions:
    • the first start (no /data file yet) reads at once;
    • a new station list is read a minute after the last read at the earliest;
    • a read cut before its values came (the form saved, a reconnection) is read again a minute after it;
    • when /data cannot be read, or holds a date that is invalid or in the future, the first read comes one interval after the start;
    • an interval shortened in the form brings the next read closer (the new interval after the last read).
  • Each request is bounded: 20 seconds, 2 MB for a page of values, 512 KB for the names or a search.
  • User-Agent: gladys-usgs-eau/<version> (+repository address); Accept application/geo+json. The USGS answers no-cache without ETag nor Last-Modified: no conditional request.
  • 429 (too many requests): every request to the USGS is paused, 5 minutes doubled at each new one, Retry-After honoured, between 60 seconds and 6 hours, kept across a restart; the next read comes at the end of the pause, not a round later. A 5xx of the values pauses the reads the same way; a 5xx of the names or of a search pauses nothing.
  • A failure of the names and time zones never stops the values (a 429 is the limit of the whole service: it pauses every request, as above): the station number is then the name, the times are in UTC, they are tried again an hour later.
  • Gladys accepts 300 states a minute: the module sends 250 at most over a rolling minute; beyond, the rest comes first at the next read, in turn.
Search stations​
The button asks the USGS for the stations whose name holds every word typed (letters and digits only, 2 to 30 characters, 4 words at most) and lists 15 of them with the number to copy. One search every 10 seconds at most, none during a pause; a search waiting more than 45 seconds behind a read gives up.
Status of the integration​
"Connected" only when the last read succeeded and at least one station has a current value. Otherwise the message says why: the USGS answers but no station has a current value, the last read failed (network, no answer in time, refused, answer too large, incomplete or unexpected), paused until a time (UTC); and also stations typed that are not station numbers, a value of the form replaced, stations unknown to the USGS, names not read, /data unreadable (set aside under another name) or not writable, values put off to the next read. Before the first read: "Waiting for the first read".
Data and licence​
  • USGS data, in the public domain. Most real-time values are provisional.
  • No personal data is read nor kept. /data keeps the time of the last read, the pause, the names, time zones and kinds of the stations, and the time of the last measurement published per feature.
  • /data is only read and written as a regular file: a FIFO, a link or a device in place of the file is unreadable (set aside) and in place of its temporary file makes /data not writable (said in the status); it is never waited on.
  • When Gladys stops the integration, it waits 3 seconds at most for the read running, 5 seconds at most for /data, and exits 9 seconds after the stop at the latest. Docker, which Gladys asks for the stop, ends it after 10 seconds whatever holds it (a /data frozen by the system). Nothing is ever run outside its process.
Diese Einstellungen fragt USGS Water Data in seinem Konfigurationsbildschirm in Gladys ab.
U.S. rivers and groundwatersectionNeinOpen data of the U.S. Geological Survey (Water Data APIs), public domain, no account, no key. Unofficial integration, not affiliated with the USGS; not a warning system: follow the National Weather Service for floods. For each station you choose: discharge, gage height, water temperature and depth to groundwater, as the station measures them (most values are provisional). A value older than the maximum age is never published. After saving and the first read, open the Discovery tab and create the stations: one device per station.
StationsstringNeinUSGS station numbers (8 to 15 digits), separated by commas or spaces, 20 at most. Another agency: its id, such as AR008-343826091361301. The "Search stations" button finds the numbers.
UnitsselectNeinU.S. units (ft³/s, ft, °F, as the USGS gives them) or metric (m³/s, m, °C, converted exactly). A device keeps the units it was created with; to change them, delete it and create it again from Discovery.
Language of the textsselectNeinLanguage of the feature names given in Discovery and of the status texts. The station names come from the USGS, in English.
Read every (minutes)numberNeinTime between two reads, from 15 to 120 minutes. All the stations are read in one request. Most stations measure every 15 minutes and send their data every hour.
Maximum age (hours)numberNeinA measurement older than this is not current: never published, the status says so. From 1 to 48 hours; raise it for a well that sends once a day.
So installierst du USGS Water Data in Gladys​
  1. Öffne in Gladys Integrationen: USGS Water Data erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/lm1lc3n7/gladys-usgs-eau:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-usgs-eau.
USGS Water Data benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
USGS Water Data ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
