Thermorossi WiNET Smart-Home-Integration, kostenlos und Open Source
Thermorossi WiNET-Integration für Gladys Assistant
Control Thermorossi (and other WiNET/NetSoftware) pellet stoves in Gladys Assistant.
The integration talks directly to the stove's WiNET module (configurable LAN IP): full state, fire level 0-5, fan speed 1-6, flue temperature, pellets low, weekly program, alarms with explicit messages. Automatic cloud fallback when the module is unreachable. This integration brings WiNET Wi-Fi pellet stoves (Thermorossi, and other brands on the thermorossi.cloudwinet.it / cloudwinet.it portal) into Gladys Assistant.
What it does​
One device per stove, with the features the stove has: on/off (thermostat mode), air setpoint (5 to 40 °C), heating state, room temperature sensor, state in words (standby, ignition, working, cleaning, alarm…), an alarm binary sensor and the power level select (1 to 5). Scenes can also trigger on the stove_alarm event, once per alarm.
Prerequisites​
Setup​
  1. Install the integration from Integrations in Gladys.
  2. In the Configuration tab, enter the WiNET portal e-mail and password, then click Test the connection: the stove state is shown.
  3. Open the Discovery tab and create the stove.
The integration talks to the WiNET cloud over the Internet, never to the stove directly: the stove must be online in the app. Credentials stay in the Gladys configuration (secret field); the device API key, scraped from the portal like the app does, is kept in the integration data volume and re-scraped automatically when the cloud refuses it.
  • “WiNET portal login failed”: check the credentials; a new attempt is retried automatically every 15 minutes.
  • The cloud returns 0 °C temperatures while the stove is off: the integration then publishes the mode and state only, never a fake temperature.
  • The WiNET module keeps a single active session: if the official app is open at the same time, command conflicts are possible.
Unofficial community integration, not affiliated with Thermorossi or NetSoftware.
Diese Einstellungen fragt Thermorossi WiNET in seinem Konfigurationsbildschirm in Gladys ab.
Getting startedsectionNeinUse the e-mail and password of the Thermorossi WiNET portal (the same account as the Thermorossi Connector app). The integration reads your device's API key from the portal, exactly like the app does, then talks to the WiNET cloud. Unofficial integration, no affiliation with Thermorossi or NetSoftware.
Portal e-mailstringJa
Portal passwordsecretJa
Stove name (optional)stringNeinName shown in Gladys. Leave empty to use the name declared on the portal.
Stove WiNET module IP (LAN)stringNeinDirect local read/write on the stove's WiNET module — exposes everything (fan speed, flame level, flue temperature, detailed alarms). Leave empty to use only the WiNET cloud (reduced data).
Labels languageselectNein
Refresh interval (s)numberNeinHow often the stove is read, in seconds (one minute minimum, to stay courteous with the cloud).
So installierst du Thermorossi WiNET in Gladys​
  1. Öffne in Gladys Integrationen: Thermorossi WiNET erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/tchoinard38/gladys-winet:1.2.2) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/tchoinard38/gladys-winet.
Thermorossi WiNET benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Thermorossi WiNET ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von tchoinard38 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
