Sure Petcare Smart-Home-Integration, kostenlos und Open Source
Sure Petcare-Integration für Gladys Assistant
SureFlap pet doors and cat flaps, SureFeed feeders, Felaqua: pets in or out, lock modes.
This integration brings the connected Sure Petcare devices into Gladys: SureFlap cat flaps and pet doors, SureFeed feeders and Felaqua water stations, linked to the Sure Petcare cloud by their hub. It uses the account of the Sure Petcare app. Unofficial, not affiliated with Sure Petcare.
Development version (0.1). Built from the community clients of the Sure Petcare API (surepy, used by Home Assistant, ioBroker.sureflap) and tested with simulated answers, not with a real account yet. Feedback is welcome on the GitHub repository.
One Gladys device per Sure Petcare device, and one per pet:
DeviceIn Gladys
Hubonline (yes/no)
Cat flap, pet doorlock mode (settable), battery %, online
SureFeed feeder (Connect)weight of each bowl (g), last meal (g) and the pet that ate it, battery %, online
Felaquawater left (mL), water level %, battery %, online
Each petinside or not, for how many minutes, last meal (g), last drink (mL)
  • "Inside" is recorded at the time the pet went through the flap (or was set in the app), not at the time of the reading: the history shows the real times in and out. "Time since the last move" counts the minutes since then, handy for a scene like "the cat has been out for more than 6 hours".
  • The last meal and the last drink are dated with the time of the meal. The grams are generic sensors (Gladys has no mass unit), hence the "(g)" in their names.
  • The battery comes from the Sure Petcare app when it gives one, otherwise from the voltage of the four AA cells (1.25 V empty, 1.6 V full, like Home Assistant).
  • The badge of each device shows cloud; unreachable with an orange dot when the hub reports the device offline, plain unreachable when Sure Petcare does not answer.
  2. In the Configuration tab, enter the e-mail and password of your Sure Petcare account (the ones of the app), then save.
  3. The status says "Connected to Sure Petcare: 5 devices, 2 pets" and the end date of the session the integration opened.
  4. Open the Discovery tab and add the devices and pets you want to follow. Their values arrive as soon as they are added.
The Test the connection button reads the account and summarizes what it holds and where each pet is.
Lock mode and curfew​
The mode of each flap can be set from Gladys (dashboard, scenes):
ModeEffect
Unlockedpets go in and out freely
Keep pets inpets can come in but not go out
Keep pets outpets can go out but not come in
Lockedneither in nor out
Curfewthe curfew times of the flap apply
The curfew uses the times set in the Sure Petcare app: set them there once. Choosing another mode turns the curfew off, and going back to curfew turns the same times back on. The hub takes a few seconds to apply a mode: Gladys shows the mode asked for, and the next reading confirms it.
Scenes​
Three scene triggers, for one pet or for all:
  • Pet went out and Pet came in: variables pet_name, flap_name (the flap used, empty when the change was made by hand in the app), by_hand and since (the time, UTC). The filter can target a pet and a flap.
  • Pet ate: a feeder saw the pet eat at least 1 g; variables pet_name, feeder_name, amount (grams) and at. The filter can target a pet and a feeder.
A reading only sees the last move of each pet: a cat that went out and came back between two readings gives one "Pet came in". Changes older than 15 minutes found at start-up or after an outage fire nothing: they are only recorded.
The other values work with the usual "Device state changed" trigger (bowl almost empty, water below 20 %, low battery, hub offline…).
How often it reads​
Everything is read in a single request (me/start), every 60 seconds by default (30 to 600). Home Assistant reads every 3 minutes, the Sure Petcare app more often. On errors the integration waits 1, 2, 5, 10 then 15 minutes; when Sure Petcare asks to slow down, it waits as long as asked (15 minutes otherwise).
Options​
OptionDefaultPurpose
E-mail, password—the account of the Sure Petcare app
Refresh interval (s)60how often the account is read
Language of the feature namesFrenchnames of the features and modes of the devices added later
  • "Sure Petcare refused the e-mail or password": check them in the app, then in the configuration. The integration does not retry by itself (repeated refusals may lock an account): it waits for a change or a click on Test the connection.
  • "Sure Petcare cannot be reached": the Sure Petcare cloud or your Internet access is down (service status: https://status.surepetcare.io).
  • A device is unreachable with an orange dot: the hub no longer sees it (batteries, range). Check it in the app.
  • The bowl weights stay empty: your feeder may not give its weights in the answer read yet (older firmware). Open an issue on the GitHub repository.
  • Repeaters and programmers are not supported yet.
Privacy​
The e-mail and password are stored by Gladys as a secret (never sent back to the browser). The integration only sends them to app-api.production.surehub.io, the cloud of the Sure Petcare app, to open a session; it keeps the session token and a client id in its /data folder. Sure Petcare, SureFlap, SureFeed and Felaqua are trademarks of their owner; this integration is not affiliated with Sure Petcare.
Diese Einstellungen fragt Sure Petcare in seinem Konfigurationsbildschirm in Gladys ab.
Your Sure Petcare accountsectionNeinBrings your Sure Petcare devices into Gladys through the Sure Petcare cloud (the hub is required): whether each pet is inside or outside and since when, the lock mode of the SureFlap pet doors and cat flaps (unlocked, keep in, keep out, locked, curfew), the bowl weights and last meal of the SureFeed feeders, the water left in the Felaqua, batteries and online states, plus scene triggers when a pet goes out, comes in or eats. Enter the e-mail and password of the Sure Petcare app, then add the devices and pets from the Discovery tab. Everything is read once a minute by default. Unofficial, not affiliated with Sure Petcare.
Sure Petcare e-mailstringJa
Sure Petcare passwordsecretJa
Refresh interval (s)numberNeinHow often the account is read, in seconds (30 to 600). One request per read.
Language of the feature namesselectNeinUsed for the names of the features and of the lock modes of the devices added from now on.
So installierst du Sure Petcare in Gladys​
  1. Öffne in Gladys Integrationen: Sure Petcare erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/lm1lc3n7/gladys-surepetcare:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-surepetcare.
Sure Petcare benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Sure Petcare ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
