STIEBEL ELTRON Smart-Home-Integration, kostenlos und Open Source
STIEBEL ELTRON-Integration für Gladys Assistant
STIEBEL ELTRON heat pumps via the ISG, local Modbus: temperatures, energy, optional commands.
Shows your STIEBEL ELTRON heat pump in Gladys through the ISG (Internet Service Gateway, "ISG web") and its Modbus TCP interface: no cloud, no account, straight on your network.
Never tested with a real ISG. Not affiliated with STIEBEL ELTRON. It reads the Modbus registers of the ISG as the pystiebeleltron library (used by Home Assistant) does.
Security: Modbus has neither password nor encryption. Any machine on your network can read the ISG and change the settings of the heat pump. Keep the ISG on a trusted network (never exposed to the Internet, ideally on a separate network for connected devices).
Supported controllers​
The integration reads the controller identification and picks its registers:
  • WPM: WPM 3, WPM 3i, WPMsystem (WPL, WPF, WPE heat pumps…);
  • LWZ / LWA: integral units LWZ 304/404/504, LWZ x04 SOL;
  • LWZ R290 (THZ with ISG Connect): it serves the WPM registers and is read as a WPM (WPM modes, setpoints and addresses).
Another controller is named in the configuration screen ("Unknown controller") and read again every 30 minutes.
One device, "STIEBEL ELTRON heat pump". Each feature appears only once the ISG gives its value:
FeatureContent
Operating modeList (commands allowed only), see below
Operating mode (read)Text: the real mode, emergency and manual included
Heating setpoint (comfort)Thermostat, heating circuit 1, in °C (command)
Heating setpoint (eco)In °C, read only (WPM: eco; LWZ: night)
Hot water setpoint (comfort)Water heater, in °C (command, capped)
Hot water setpoint (eco)In °C, read only (WPM: eco; LWZ: night)
Hot water target nowIn °C, the setpoint the controller applies now
TemperaturesOutside, flow, return, hot water, room (FE7, FEK, FET or LWZ), in °C
Room humidityIn % (FEK remote control, LWZ)
Compressor running0 or 1
Electric booster running0 or 1 (electric heater, "NHZ")
Fault0 or 1
Electricity used, heat producedIn kWh, today and total, heating and hot water; heat from the booster
Water temperatures, the outside temperature and the setpoints are "probes": they do not count as the room temperature in Gladys. Read every 30 seconds by default (10 s to 10 min, configurable).
Energy: plain values, not a billed meter​
For heating and hot water, the ISG gives a counter of the day and a total. According to the documentation, the total does not include the day and moves around midnight; nothing guarantees it never jumps or goes back. Gladys would count every rise of an index as billed consumption: the values are therefore published as plain sensors (the unit is in their name), never as an energy index. They do not show in the energy monitoring of Gladys.
  1. Have the Modbus module of your ISG enabled (STIEBEL ELTRON support does it, often for free).
  2. Give the ISG a fixed IP address in your router.
  3. Install the integration from the Gladys store.
  4. In its configuration, enter the IP address of the ISG (port 502 by default; add :port when it differs).
  5. Save, then add the heat pump from the Discovery tab.
The Test the connection button reads the ISG once (at most every 10 seconds).
Commands (off by default)​
While Allow the commands is off, every command is refused. Once on, Gladys may change:
  • the operating mode: WPM: program (automatic), comfort, eco, hot water only, standby; LWZ: automatic, day, setback (night), hot water only, standby;
  • the heating setpoint (comfort) of heating circuit 1: 5 to 30 °C (WPM) or 10 to 30 °C (LWZ), to a tenth of a degree;
  • the hot water setpoint (comfort): whole degrees, from 10 °C up to the ceiling.
Hot water ceiling: 65 °C by default​
Water at 60 °C already scalds in a few seconds: Gladys never sets the hot water above 65 °C, and you can lower this ceiling. The Hot water ceiling setting lowers it, from 40 to 65 °C (65 °C by default); going above 65 °C is never possible, whatever is typed. The range of the controller still applies when lower: 60 °C at most on a WPM (its manual), 65 °C on an LWZ. A setpoint above the ceiling is refused unsent, and the ceiling is checked again right before sending (a ceiling lowered during a command stops it). The eco setpoint and the anti-legionella program of the controller are never changed.
What Gladys never does​
  • Select the emergency mode (set by the installer when the compressor is out of order) or the manual mode of the LWZ (a service mode).
  • Leave one of these modes, or an unknown mode: the command is refused, the controller keeps control.
  • Offer a switch: the mode is a list, the setpoints are thermostats; a "turn everything off" (Gladys, Google Home, Alexa, HomeKit) does not reach the heat pump. A scene may change the mode or a setpoint, only through an explicit action and when the commands are allowed. Beware: the AI chat of Gladys (MCP) can create and run such a scene.
When the heat pump is in emergency, manual or an unknown mode, the list keeps its last value (those modes are not in it): look at "Operating mode (read)", which always shows the real mode.
How a command leaves​
Before each command, the integration reads the settings of the heat pump again and decides on that read only; no other request runs between that read and the write, and the option (and the ceiling) is checked again right before sending. A value already in place is not sent again. A command that cannot leave within 3.5 seconds is refused unsent; Gladys gets the answer within its 5 seconds. The ISG confirms a write by echoing it; without that confirmation (silence, a dropped connection, another answer, a Modbus error that does not say the write was rejected), Gladys shows "Command sent, without confirmation": check the value, read again 5 and 20 seconds later (the ISG takes a few seconds to show it). Only a clear Modbus error (function, address or value refused, ISG busy) gives "The ISG refused the command". One command at a time, and at least 3 seconds between two writes (otherwise "still running").
Errors and limits​
  • ISG unreachable: "Operating mode (read)" shows "ISG unreachable", the device turns unreachable, the other values keep their last one. Tried again after 30 s, 1, 2, then 5 minutes, never faster than the interval.
  • Missing registers: a block the controller does not serve (energy on some models, for example) is not asked again until a restart; a block failing now and then is reported in the configuration screen, the other values are still published.
  • One ISG per integration; the device is keyed by the controller family (WPM or LWZ): Modbus gives neither a serial number nor a MAC address.
  • Modbus requests go one at a time; every answer is checked (transaction id, unit, function, size).
  • Not yet: heating circuits 2 to 5, cooling, LWZ ventilation, SG Ready, the individual heat pumps of a WPMsystem.
  • The logs never carry register values.
Credits​
Ported from pystiebeleltron (Martin Fuchs and contributors, MIT, version 0.9.2), the library of Home Assistant's STIEBEL ELTRON integration. Apache-2.0 license.
Diese Einstellungen fragt STIEBEL ELTRON in seinem Konfigurationsbildschirm in Gladys ab.
Your ISGsectionNeinShows your STIEBEL ELTRON heat pump (WPM 3, WPM 3i, WPMsystem or LWZ/LWA controller) in Gladys through the Modbus TCP interface of its ISG (Internet Service Gateway), without any cloud: temperatures, setpoints, operating mode, compressor and booster, energy. The Modbus module of the ISG must be enabled (ask STIEBEL ELTRON support). Enter the IP address of the ISG (give it a fixed address in your router), save, then add the heat pump from the Discovery tab. Modbus has no password: keep the ISG on a trusted network. Never tested with a real ISG. Not affiliated with STIEBEL ELTRON.
IP address of the ISGstringJaAn IPv4 address or a host name (Modbus port 502 unless you add one, for example 192.168.1.70:5020).
Allow the commandsbooleanNeinOff by default. On: Gladys may change the operating mode, the heating setpoint (comfort, heating circuit 1) and the hot water setpoint (comfort), up to the ceiling below. Off: every command is refused.
Hot water ceiling (°C)numberNeinScalding risk: Gladys never sets the hot water above this temperature. 65 °C by default, from 40 to 65 °C (never more than 65 °C, whatever is typed; 60 °C at most on a WPM).
Refresh interval (s)numberNeinHow often the ISG is read, in seconds.
Language of the feature namesselectNeinUsed for the names of the device and features added from now on, for the mode texts and for the command errors.
So installierst du STIEBEL ELTRON in Gladys​
  1. Öffne in Gladys Integrationen: STIEBEL ELTRON erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/lm1lc3n7/gladys-stiebel-eltron:0.1.3) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-stiebel-eltron.
STIEBEL ELTRON benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
STIEBEL ELTRON ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
