SNCB / NMBS Smart-Home-Integration, kostenlos und Open Source
SNCB / NMBS-Integration für Gladys Assistant
Unofficial connector: next SNCB trains per station, delays, cancellations and disturbances.
Unofficial connector, not affiliated with SNCB/NMBS or iRail. It brings the Belgian trains into Gladys through iRail, the community API over the SNCB open data: no account, no key. SNCB/NMBS is a trademark of the Société nationale des chemins de fer belges.
SurfaceContent
One device per watched stationminutes before the next departure, delayed and canceled trains, and for each of the next departures (3 by default): the countdown, the delay and a text line "IC 2514 → Dinant · platform 6 · +4 min"
The SNCB network devicethe number of disturbances and planned works, the latest disturbance
Scene triggerstrain approaching (1 to 15 minutes before departure), train delayed, canceled or moved (delay of at least 5 to 30 minutes, cancellation, platform change), disturbance published
Scene actionsnext departures of a station (list, next train, destination, countdown, delay, platform), disturbances of the network
Dashboard widgetsSNCB departures (one station) and SNCB disturbances (the network, with the SNCB texts and links)
Setup​
  1. Install the integration. The stations closest to your house (the house location of Gladys) are suggested in Discovery right away: add the ones you use.
  2. To watch other stations, type them in Stations to watch, separated by commas: a name (Namur, Brussel-Centraal and Bruxelles-Central both work) or an iRail id (BE.NMBS.008863008). The Search stations button finds the exact names.
  3. Optional, per station: a destination filter after @ keeps only the trains going towards these places (Bruxelles-Central@Namur|Dinant), and a custom name after : names the device (...:Train home). Save, then open Discovery again and add the devices.
  4. Put the SNCB departures widget on a dashboard and pick a station.
Every watched station is read every 60 seconds (option Refresh interval), the disturbances every 5 minutes. The departures stop being shown once the train has left.
Scenes​
  • Train approaching: pick the station and the number of minutes; the scene runs when a train of that station reaches the mark. With a destination filter on the station, only your trains count. Variables: the train, the destination, the platform, the delay, the minutes left.
  • Train delayed, canceled or moved: pick the station and the event. For "Delayed", also the minimum delay: the scene runs once per train when its delay reaches it, not at every refresh.
  • Disturbance published: the SNCB published a new notice. Needs the SNCB network device. Variables: the title, the description, the link.
The action next departures gives {{list}} (one line per train) and {{next_train}}, {{next_destination}}, {{next_minutes}}, {{next_delay}}, {{next_platform}} for a message or a condition; disturbances gives {{count}}, {{titles}} and {{latest}}.
  • A station is not found: iRail knows the stations by their official names in each language; use Search stations with a part of the name.
  • "iRail is unreachable": iRail is a volunteer-run service; it comes back by itself, the integration keeps trying every refresh.
  • No departure in the next hour: iRail lists about an hour of departures; small stations may show nothing in the evening.
  • Logs: the integration's log level is set with the LOG_LEVEL variable.
Privacy​
The integration sends iRail only the station ids it reads. The house location is used inside the integration to pick the nearest stations and never leaves it.
Diese Einstellungen fragt SNCB / NMBS in seinem Konfigurationsbildschirm in Gladys ab.
Belgian trains in GladyssectionNeinUnofficial connector, not affiliated with SNCB/NMBS or iRail. It reads the public iRail API (no account, no key): one device per watched station with its next departures (train, destination, platform, delay, cancellation), a network device with the current disturbances, scene triggers when a train approaches, is delayed, canceled or changes platform, and two dashboard widgets. The stations closest to your house are suggested in Discovery; add others below.
Stations near my home (suggested in Discovery)numberNein
Stations to watchstringNeinStation names or iRail ids, separated by commas. Optional destination filter after @ (several with |) and custom name after : — e.g. "Namur, Bruxelles-Central@Namur|Dinant:Train home".
Departures per stationnumberNeinHow many upcoming departures each station device exposes as features.
Refresh interval (s)numberNeinHow often each watched station is read. iRail is a community service: 60 s is plenty.
Language of the station and disturbance namesselectNein
Offer the "SNCB network" device (disturbances)booleanNein
So installierst du SNCB / NMBS in Gladys​
  1. Öffne in Gladys Integrationen: SNCB / NMBS erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/lm1lc3n7/gladys-sncb:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-sncb.
SNCB / NMBS benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
SNCB / NMBS ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
