Shark IQ Smart-Home-Integration, kostenlos und Open Source
Shark IQ-Integration für Gladys Assistant
Shark robot vacuums via the Shark cloud: state, battery, suction power, start, dock.
Unofficial integration, not affiliated with SharkNinja. It brings the Shark robot vacuums of the SharkClean app into Gladys, through the Shark cloud (the SharkNinja sign-in service and Ayla Networks), the one the app uses.
Warning: unofficial API, this integration has never been tested with a real robot or account. It was written from the sharkiq library and tested against a fake Shark cloud only. SharkNinja may change its API at any time. Feedback is welcome.
For each robot of the account:
FeatureDetails
StateRead only: cleaning, paused, returning, charging, docked, stopped, error.
BatteryIn %.
Suction powerA list: Eco, Normal, Max.
ErrorA text, for example "Brushroll stuck (4)" or "No error".
Start cleaningButton.
PauseButton.
StopButton.
Return to the dockButton.
Locate (beep)Button: the robot beeps.
The badge of each robot shows "cloud", or "unreachable" (with an orange dot) when the cloud says the robot is offline or it cannot be read.
  1. Your robots must work in the SharkClean app.
  2. In Gladys, install the Shark IQ integration, choose the region of the account (Europe, or North America), enter the e-mail and the password of the SharkClean app, and save.
  3. Add the robots from the Discovery tab.
Signing in: never without your click​
The SharkNinja sign-in service blocks an account after a few refused attempts, and may ask for a verification (a code, a check against robots). So the integration sends the password only when you ask:
  • once when you save the e-mail and the password (or at the first start with them);
  • then only when you click Sign in to Shark.
The sign-in allowance is used up, and saved to /data, before the password leaves: when /data cannot be written, nothing is sent. Only a failure proved to come before the password left (unknown host name, no connection) is tried again, twice at most.
A refused password, a verification asked, a blocked account, an interrupted sign-in (no answer, a server error or "too many requests" from SharkNinja after the password was sent), an unfinished sign-in (password accepted, but the next step failed), an unreadable /data or an expired session stop the integration, and the stop is kept across restarts: it never tries the password again by itself. After an accepted password, only the Ayla exchange (without the password) is tried again, three times at most, spaced. Fix what the status says (in the SharkClean app if needed), then click Sign in to Shark. Test the connection reads the robots with the current session and never uses the password.
Meanwhile, the session (about 24 hours) is renewed by a timer, 10 minutes before it ends (at half its life for a short session), with the refresh token: without the password, and never twice within a minute.
Password, tokens and privacy​
  • The password is kept by Gladys in its database, never shown again, and sent only to the SharkNinja sign-in service (Auth0), in the cases above.
  • The Ayla tokens are kept in the /data volume of the integration so that a restart does not sign in again. On the Gladys host, this volume is the folder <Gladys base folder>/external-integrations/<selector>: readable by root and uid 1000 (the container user), not in the Gladys backups, removed when the integration is uninstalled. The refresh token gives control of the robots while it is valid: protect this host. The e-mail and the password are never written there.
  • Nothing reaches the logs: no password, token, e-mail, nor whole serial number (its last 4 characters only).
  • Everything goes over HTTPS to logineu.sharkninja.com (or login.sharkninja.com), then user-field-eu.aylanetworks.com and ads-eu.aylanetworks.com (or user-sharkue1 and ads-sharkue1 in North America).
Commands​
  • No switch: the state is read only and the commands are buttons. An "everything on" or "everything off" of a scene or a voice assistant never starts nor stops a robot.
  • Start, Pause, Return to the dock and the suction power read the robot again in the cloud right before acting: the command is refused when that read fails or lacks the mode of the robot. "Already done" sends nothing (a start on a cleaning robot, a pause on a docked one), unless another order just left (within a minute): the cloud may still show the state from before.
  • Stop and Locate decide nothing: they leave without a read.
  • The commands of one robot run one at a time. Stop never waits behind them, only behind a start already on its way, so it lands after it. A waiting start is cancelled when a stop, a pause or a return to the dock arrives meanwhile.
  • A command that cannot leave within 3.5 seconds of its arrival is refused: Gladys shows a failure after 5 seconds, and nothing leaves after that failure.
  • When Shark does not confirm a command that left, Gladys shows "sent, without a confirmation": check the state of the robot, read again in the next seconds.
Refresh and errors​
  • The robots are read every 60 seconds by default (30 to 900), one request per robot, plus the account list every 10 minutes and three reads in the minute after a command.
  • Shark asks to slow down (HTTP 429): a pause of at least 1 minute (Retry-After when given, 6 h at most), for every path, commands included, kept across restarts.
  • Server error (5xx): a pause of 1, 2, 5, 10 then 15 minutes, never shorter than the interval, kept across restarts.
  • Network: new try after 1, 2, 5, 10 then every 15 minutes.
  • An unreadable robot (404, error) marks only itself; the others are read.
Limits​
  • Never tested with a real robot or account: the property names, their values and the sign-in come from sharkiq 1.5.1.
  • European accounts: the sign-in is the direct Auth0 "password grant" (e-mail and password in one request). The Auth0 bot detection (requires_verification, CAPTCHA) may refuse it, with no way around it: the integration then stops ("verification"). sharkiq left this flow in the United States for that reason.
  • The North American sign-in goes through an Auth0 consent page read automatically: if SharkNinja changes it, the sign-in fails (a stop, no new try).
  • No room cleaning, no map, no mopping for now.
Credits​
  • sharkiq 1.5.1 (MIT): the sign-in, the Ayla API, the properties and the commands are ported to JavaScript. See THIRD_PARTY_NOTICES.md.
Shark, Shark IQ and SharkClean are trademarks of SharkNinja; this project is not affiliated with SharkNinja.
Diese Einstellungen fragt Shark IQ in seinem Konfigurationsbildschirm in Gladys ab.
Your Shark accountsectionNeinBrings the Shark robot vacuums of your SharkClean account into Gladys: state (cleaning, paused, returning, charging, error), battery, suction power, error, and the Start, Pause, Stop, Return to the dock and Locate buttons. Read every minute through the Shark cloud (SharkNinja and Ayla Networks). Enter the e-mail and the password of the SharkClean app, choose the region of the account, save, then add the robots from the Discovery tab. The password is sent once after you save, then only when you click "Sign in to Shark": a failed sign-in never sends it again by itself. In Europe the sign-in is the direct Auth0 password grant, which the SharkNinja bot detection may refuse. Unofficial API, never tested with a real robot or account. Not affiliated with SharkNinja.
Region of the Shark accountselectNeinEurope for an account created in Europe or the United Kingdom; North America otherwise.
Shark e-mailstringJaThe one you sign in to the SharkClean app with.
Shark passwordsecretJaKept by Gladys in its database, never shown again, sent only to the SharkNinja sign-in service (Auth0): once after you save, then only when you click "Sign in to Shark". A sign-in that fails (refused, interrupted, unfinished) never sends it again by itself.
Refresh interval (s)numberNeinSeconds between two reads of the robots (30 to 900).
Language of the feature namesselectNeinUsed for the feature names of the robots added from now on, and for the error texts.
So installierst du Shark IQ in Gladys​
  1. Öffne in Gladys Integrationen: Shark IQ erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/lm1lc3n7/gladys-sharkiq:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-sharkiq.
Shark IQ benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Shark IQ ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
