School holidays Europe Smart-Home-Integration, kostenlos und Open Source
School holidays Europe-Integration für Gladys Assistant
School holidays by region (Land, canton, community) in Europe, outside France.
Unofficial integration. It adds the school holidays of your region in several European countries (France excluded) to Gladys: German Land, Austrian Bundesland, Swiss canton, Belgian community, Dutch region, Polish voivodeship… as a calendar. The data comes from the OpenHolidays API (https://www.openholidaysapi.org), public, no account, no key.
France is not offered: its school holidays (zones A, B, C) are in the gladys-holidays integration.
It was tried with the real OpenHolidays API and a test Gladys 5.3 (calendar filled, scenes not tried); please report any wrong date.
Setup​
  1. Install the integration (Gladys 5.3.0 or later). Nothing to fill in on its configuration screen.
  2. Every user who wants it opens the integration page, "My calendars" block, and enables it:
    • Country: from the list.
    • Regions (up to 3, separated by commas): the code (DE-BY, AT-WI or AT-9, CH-ZH, BE-FR), the code without the country (BY) or the name in a language of the API (Bayern, Bavaria, Zürich). Accents and case do not matter. Leave it empty for a country without regions (Luxembourg, Estonia, Lithuania, Andorra, Liechtenstein…).
  3. A "School holidays – <region>" calendar appears for each region, filled with the holidays from the 1st of the current month to 13 months later.
A name matching several regions, or an unknown region, changes nothing to the calendars already there: the integration status (seen by the administrator) says what to fix. The "List the regions" button (configuration screen, administrator) gives the codes and names of a country.
Depending on the country, the API also knows groups: Belgian communities (BE-FR, BE-NL, BE-DE), Dutch regions (NL-NO, NL-MI, NL-ZU), school types in Mecklenburg (DE-MV-ABS, DE-MV-BBS), Swiss school regions. A region also gets the national holidays and those of the region above it (a town inherits its canton's).
Scenes: "on holiday today"​
A pushed calendar is private at first. To use it in scenes, share it (Shared toggle in "My calendars"): the whole household then sees it and the scenes read it, for example:
  • trigger "A calendar event is coming" (the day before school starts again, the first day of the holidays);
  • condition "An event is running" on that calendar: true on a holiday (to skip the children's alarm).
There is no device: the calendar is enough.
What the integration does​
  • Reads: once a day at most per region (once a week for the lists of regions), however many restarts or clicks. The date of the data and of the last attempt are kept in /data.
  • An empty answer for a region that had holidays: the holidays read before are kept (and said in the status) until the third empty answer in a row, a day apart (the API answers "nothing" to what it does not know).
  • Unreadable answer (maintenance page, not a list, cut): treated as an outage, paused like below. More than 500 holidays for a region: refused and said in the status.
  • API down: every request is paused 60 s, then 2 min, 4 min… up to 6 h, honouring the Retry-After header; the holidays already read stay in the calendar. Answers are limited to 1 MB (2 MB for the lists of regions) and 20 s.
  • Writes to Gladys: 25 a minute at most (Gladys accepts 30); nothing is resent when nothing changed. 200 users at most (beyond, said in the status).
  • The past is kept: only the current window (from the 1st of the month, 13 months) is replaced; past holidays stay in the calendar.
  • Calendar not synced (Sync toggle off): it receives nothing more; turned back on, it is filled again.
  • The "back to school" and "end of lessons" days of the API are not holidays: they are left out. A half day is noted in the event description. A holiday given once per school type (Zürich: CH-ZH-VS Volksschulen, CH-ZH-MS Mittelschulen…) with the same dates shows once; for the dates of one school type only, give its group code. The description of an event names the school types it is for: two events of the same name that overlap (Mecklenburg: "Sommerferien" for ABS and for BBS) are two school types, and the scene condition "an event is running" is true on both.
  • Holidays are full-day events, stored at the midnights of the Gladys timezone (timezones from UTC-11 to UTC+11).
Countries​
Offered: Albania, Andorra, Austria, Belarus, Belgium, Bulgaria, Croatia, Czechia, Estonia, Germany, Hungary, Ireland, Italy, Latvia, Liechtenstein, Lithuania, Luxembourg, Malta, Moldova, Monaco, Netherlands, Poland, Portugal, Romania, San Marino, Serbia, Slovakia, Slovenia, Spain, Switzerland.
The Gladys catalog lists an integration in 20 countries at most: here the 14 whose school holidays 2026-2027 are in the API (Andorra, Austria, Belgium, Czechia, Estonia, Germany, Liechtenstein, Lithuania, Luxembourg, the Netherlands, Poland, Portugal, Slovakia, Switzerland), then the 6 most populous EU members still waiting for theirs (Italy, Spain, Romania, Hungary, Bulgaria, Ireland). The other 10 (Albania, Belarus, Croatia, Latvia, Malta, Moldova, Monaco, San Marino, Serbia, Slovenia) are offered all the same: the catalog search finds the integration from any country.
Coverage depends on the API: some countries publish their school year late (on 14 November 2026, nothing yet for 2026-2027 in Albania, Belarus, Bulgaria, Croatia, Hungary, Ireland, Italy, Latvia, Malta, Moldova, Monaco, Romania, San Marino, Serbia, Slovenia and Spain). An empty calendar fills as soon as the API has the dates.
Data and licence​
Contains information from the OpenHolidays API (https://www.openholidaysapi.org), made available under the Open Database License (ODbL-1.0, https://github.com/openpotato/openholidaysapi.data/blob/main/LICENSE). The integration calls the API and embeds none of its data; the API server (AGPL-3.0) is neither copied nor ported. Every calendar and every event cites the source. The integration itself is licensed under Apache-2.0.
Diese Einstellungen fragt School holidays Europe in seinem Konfigurationsbildschirm in Gladys ab.
How it workssectionNeinEach user enables the integration in "My calendars" below and chooses a country and up to 3 regions: one calendar per region, filled with its school holidays (13 months ahead, read once a day from the public OpenHolidays API, no account, no key). France is not offered (see gladys-holidays). The "List the regions" button gives the codes of a country. Data: OpenHolidays API, Open Database License (ODbL-1.0).
So installierst du School holidays Europe in Gladys​
  1. Öffne in Gladys Integrationen: School holidays Europe erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/lm1lc3n7/gladys-vacances-scolaires-europe:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-vacances-scolaires-europe.
School holidays Europe benötigt Gladys >=5.3.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
School holidays Europe ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
