Rainforest Eagle Smart-Home-Integration, kostenlos und Open Source
Rainforest Eagle-Integration für Gladys Assistant
Unofficial: Rainforest Eagle-200/Eagle-3 on your network: smart meter power and index.
Unofficial integration, not affiliated with Rainforest Automation. It reads your Rainforest Eagle-200 or Eagle-3 energy gateway (the Zigbee gateway that reads the smart electricity meter of many utilities in the United States and Canada) on your local network, through its local API (HTTP), with the Cloud ID and the install code printed on its label, without any cloud.
Never tested with a real device: the integration was written from the aioeagle library (the one of Home Assistant), without an Eagle at hand. The Eagle-3 is expected to answer like the Eagle-200 (same local API), this is not verified. The old Eagle-100 (another API) is not supported. Your feedback is welcome.
Read-only​
The integration only reads (the device_list and device_query commands of the local API). It never changes anything on the gateway nor on the meter (no price, no message confirmation, no setting).
One device per electricity meter the Eagle reads (named "Eagle meter" and its hardware address, e.g. 0x00abcd123):
  • power (W): the instantaneous demand of the meter, negative when the home sends power to the grid (solar);
  • consumption index (kWh): the energy the meter delivered to the home, for the Gladys energy monitoring (Gladys computes the consumption and its cost from it);
  • energy sent to the grid (kWh, total): a plain sensor, never counted as consumption. It is never sent at 0: without solar panels (nothing ever sent to the grid), it stays empty, which is normal.
Energy monitoring​
The consumption index is the energy taken from the grid, as measured by the meter of your utility. If another integration already sends this same meter to Gladys (another gateway, a utility account), keep only one source, otherwise the consumption is counted twice. The integration never sends a daily consumption.
Requirements​
  • Gladys 5.2.0 or later.
  • The Eagle on the same network as Gladys, its local API reachable over HTTP (port 80), already joined to your meter (see its app).
  • The Cloud ID (6 characters) and the install code (16 characters): on the label under the gateway.
  2. Eagle IP address: its address on your network (with :port only if it is not 80). Preferably give it a fixed address in your router (the eagle-<cloud id>.local name usually does not resolve inside a container).
  3. Cloud ID: never logged.
  4. Install code: kept by Gladys in its database, never shown again; sent only to the Eagle (in the header of its requests), never logged.
  5. Reading interval: 30 s by default, 30 to 300 s (each read: the device list, then one small request per meter, one second apart: two requests for one meter).
  6. After the first read, create the meter device from the Discover tab.
The Test the connection button reads the Eagle once if the interval has passed; otherwise it shows the last read and when the next one can be.
Pace of the reads​
Nothing reads the Eagle faster than the interval: not the test button, not the Discover tab, not a reconnection to Gladys, not a save of an unchanged configuration, not a restart of the container (the instant of the last read is kept in /data, written at most once a minute: after a restart, the first read waits the interval plus one minute). A new address or new credentials are tried at once.
Held index​
Gladys counts each rise of an index in full. So that no fictive energy is ever counted, the consumption index goes through a guard:
  • a value of 0 is never sent;
  • a drop, or a rise faster than 100 kW on average, is held: the last accepted value is sent again, and the status of the integration shows it. Neither time nor repetition confirm it (it stays held after a restart);
  • if it is right, click Accept the held index twice: the first click lists what is held without accepting anything, the second, from 3 seconds to 5 minutes later, accepts exactly what was listed (a jump is then counted at once, a drop counts nothing). Saving the configuration accepts nothing.
Errors​
  • Credentials refused (HTTP 401/403 of the device list): the reads stop and never start again by themselves (a wrong install code is never tried in a loop); the stop is kept in /data across restarts. Saving other credentials tries them at once; Test the connection tries once per click. To recognize refused credentials after a restart, /data keeps a salted fingerprint of the refused pair only (never of a working one), erased by the first successful read.
  • An HTTP 429 answer (to any request) or a 5xx answer of the device list pauses the reads from 1 minute to 6 hours, kept in /data. Another error of the query of one meter only leaves that meter out: the others are published.
  • Devices of the Eagle that are not electricity meters, or whose hardware address cannot be read, are left out; the status gives their number.
  • An unreachable Eagle is tried again after 1 minute, then 2, up to 15 minutes, never faster than the interval.
  • Every read starts with the device list, with the credentials of the label: another Eagle that takes the address (DHCP) refuses them and gives nothing; another device answers something that is not an Eagle answer, nothing is published.
  • A meter the Eagle no longer reaches (not "Connected") publishes nothing (its values would be stale); the status says so.
Privacy​
Nothing leaves your network: the integration only talks to the Eagle, over local HTTP, and follows no redirect. The install code travels in clear text on your local network (HTTP Basic), as for any client of this local API.
Diese Einstellungen fragt Rainforest Eagle in seinem Konfigurationsbildschirm in Gladys ab.
Rainforest EaglesectionNeinUnofficial connector, not affiliated with Rainforest Automation. It reads your Rainforest Eagle-200 or Eagle-3 energy gateway (US and Canada smart meters) through its local API (HTTP on your network, no cloud), with the Cloud ID and the install code printed on its label, every 30 seconds: the power of the home and the energy index of the smart meter for the Gladys energy monitoring, and the energy sent to the grid. Read-only: it never changes anything on the gateway nor on the meter. Never tested with a real Eagle.
Eagle IP addressstringJaThe address of the Eagle on your network, with :port only if it is not 80. Preferably give it a fixed address in your router.
Cloud IDstringJaPrinted on the label under the Eagle (6 characters). It is the user name of the local API; never logged.
Install codesecretJaPrinted on the label under the Eagle (16 characters). It is the password of the local API. Kept by Gladys in its database, never shown again; sent only to the Eagle, in the header of its read requests, never logged.
Reading interval (s)numberNeinHow often the Eagle is read (the device list, then one small request per meter, one second apart): 30 s by default, more if you wish. Nothing reads it faster, not even the test button.
So installierst du Rainforest Eagle in Gladys​
  1. Öffne in Gladys Integrationen: Rainforest Eagle erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/lm1lc3n7/gladys-rainforest-eagle:0.1.2) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-rainforest-eagle.
Rainforest Eagle benötigt Gladys >=5.2.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Rainforest Eagle ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
