PJLink Projectors Smart-Home-Integration, kostenlos und Open Source
PJLink projectors on the local network: power, standby, input, A/V mute, lamp, errors.
Control your PJLink projectors from Gladys, locally, without any cloud: power on, standby, input, A/V mute, the lamp hours and the error report. PJLink is the network control standard of many projectors and some flat screens (Epson, Panasonic, NEC / Sharp, Sony, BenQ, Canon, Hitachi / Maxell, Optoma, Ricoh, Christie...), class 1 and class 2.
Important. This integration has never been tested with a real device: it was written from the public PJLink specification, cross-checked with the
pypjlink2library (the one Home Assistant uses), and tested against a fake projector only. Your feedback is welcome. Unofficial integration, not affiliated with JBMIA (the association behind PJLink) nor with any projector maker.
Setup
- On the projector, enable PJLink (depending on the maker: Network > Network control, PJLink, Control...) and the network standby (for example Standby mode: Network on). Without it, the projector leaves the network in standby and cannot be turned on from Gladys.
- Give each projector a fixed IP address in your router (reserved DHCP lease).
- In Gladys, install the PJLink Projectors integration, then open its configuration.
- Type the IP addresses, separated by commas (for example
192.168.1.60, 192.168.1.61, 10 at most). Add:portonly if the projector does not use the PJLink port, 4352. - If a PJLink password protects your projectors, type it (32 characters at most, without accents, the same for all of them).
- Open the Discovery tab and scan: the projectors appear, create them.
The integration talks to the projector with PJLink (TCP port 4352): one connection at a time (a projector accepts only one), closed after 3 s of silence. It reads the state at the refresh interval of the configuration (60 s by default, 30 s at least).
| Feature | Gladys type | Note |
| Power | binary state (read only) | 1 on or warming up, 0 in standby or cooling down |
| Power on | button | sent only from standby |
| Standby | button | the protective command, see below |
| Status | text (read only) | Standby, Warming up, On, Cooling down, Unreachable... |
| Input | dropdown | the inputs the projector lists, with their names |
| A/V mute | button (mute) | each press reads the state, then sets the opposite |
| Lamp hours | duration in hours | the first lamp; absent on models that do not give it |
| Errors | text (read only) | OK, or for example Lamp: warning, Filter: error |
On purpose, no switch: an "everything off" or "everything on" from a voice assistant or a scene neither turns your projector on nor cuts it.
Input and A/V mute are read and set only while the projector is on. The input
names come from the projector (class 2: HDMI 1...); on a class 1 projector
they are named by type (Digital 1, RGB 1...). They are read when you scan
in the Discovery tab.
Each projector is known by its serial number (class 2), or by its address (class 1, or a projector that gives none). Before anything is published or sent (Standby aside), the integration checks once per connection that it talks to the same projector: the serial number, or the maker and model for a projector known by its address. Another serial number at the address: the projector is marked "Another projector at this address" and nothing is sent to it; type its new address and scan again. Unreadable: its status shows "Identity not confirmed" and nothing is sent to it but Standby.
Commands
Power on, input and A/V mute read the power state just before, then the current value, and are decided on what they read. A command is a success only once the projector shows the requested value when read back; Gladys gives a command 5 seconds, so every command is answered within 3.5 s, with exactly what is known:
- "nothing sent": the projector did not answer, a password is missing or refused, the identity is not confirmed, a Standby was asked meanwhile or is not confirmed yet (input and A/V mute), or no time was left;
- "sent, without confirmation" or "not applied yet": the command left; the projector is read again 5 s and 20 s later;
- "refused by the projector (ERR3)": the projector answered with an error (ERR3 means "not now", for example while warming up).
Commands to one projector go one at a time.
Standby, the protective command
Standby is never held back by a reading or a command in progress, the commands waiting, the configuration not read yet, or a state not read yet:
- it goes before everything waiting for that projector; the commands asked before it and still waiting are cancelled ("nothing sent"), so nothing asked before a Standby is sent after it;
- a reading stuck for 1 s (no byte from the projector) is cut, and the standby leaves on a new connection once the old one is closed;
POWR 0is sent without reading anything first, then the power is read back: "Standby" or "Cooling down" confirms it;- when no connection can be made, it is tried again every 250 ms within its 3.2 s.
A Standby the projector accepted (OK) is never sent again blindly: if
the power read back still shows it on, it is sent again only by a reading
that still shows it on, with no failed reading in between; a reading that
fails, or one showing it warming up (a power on started since, by the remote
or by Gladys), drops it. Accepted but not read back (many projectors leave
the network while cooling down): it is not sent again.
A Standby not accepted (refused with ERR3 while warming up, or no connection, or no answer) is kept (in the data of the integration, so a restart keeps it too) and sent again by the next readings that show the projector on: its own power readings every 12 s (whatever the refresh interval, stopped once it is confirmed or dropped) and the usual readings, 3 times at most (a refusal with ERR3, warming up or cooling down, is not counted), for 2 minutes at most (counted on a monotonic clock while the integration runs). While the projector is still warming up, it waits. It is dropped once a reading shows the projector in standby or cooling down, or when a Power on sent from Gladys after it is accepted.
At a restart, a kept standby not accepted is decided on a power read first, before the configuration is read and before any reading: sent only if the projector is still on. An accepted one is dropped at a restart.
The cases where a Standby does not leave ("nothing sent", kept and sent again as above):
- the address of the projector is unknown (another projector proved to answer there);
- the projector asks for a password and none is typed, or the typed one was refused (a refused password is not sent again by a Standby; right after a restart, a projector asking for a password gets the standby once the configuration is read);
- no connection within its 3.2 s (unreachable).
Passwords
A missing or refused password blocks its projector: no reading, no command, no automatic retry, a reconnection or a restart included. The status says so. The block is lifted when you change the password in the configuration, or when the Check the projectors button succeeds (each press tries once; after a restart, a new password is recognized by its mark, see below, and in 1 case out of 64 it is taken for the old one: press the button then). The password is kept by Gladys in its database, never shown again, sent only to the projectors as the MD5 digest PJLink uses, never written in the logs nor in the data of the integration. To know after a restart whether the password changed, the integration keeps only a 6-bit mark of a refused password (one value among 64, which identifies nothing), erased once a password is accepted.
The Check the projectors button shows the state of each projector. A projector read less than one refresh interval ago is shown as read, not asked again; a scan, a reconnection or a saved configuration does not make the projectors read sooner either.
Not supported yet
Volume, freeze, filter hours, the notifications of class 2 (search by UDP broadcast, status pushed by the projector), one password per projector. See the project's TODO.md.
Diese Einstellungen fragt PJLink Projectors in seinem Konfigurationsbildschirm in Gladys ab.
| Your PJLink projectors, on your local network | section | Nein | PJLink is the network control standard of many projectors (Epson, Panasonic, NEC, Sony, BenQ, Canon, Hitachi, Optoma...): TCP port 4352, without any cloud. On the projector, enable PJLink (often under Network > Network control or PJLink) and the network standby, otherwise it leaves the network in standby. Give each projector a fixed IP address in your router, type the addresses below, then scan in the Discovery tab. Unofficial integration, not affiliated with JBMIA nor with any projector maker. |
| IP addresses of the projectors | string | Nein | Separated by commas, for example 192.168.1.60, 192.168.1.61 (10 at most). Add :port only if your projector does not use 4352. |
| PJLink password (optional) | secret | Nein | Only if a PJLink password protects your projectors (32 characters at most, the same for all of them). Kept by Gladys in its database, never shown again, sent only to the projectors over your local network (as the MD5 digest PJLink uses), never written in the logs. A refused password is not tried again until you change it here or press "Check the projectors". |
| Refresh interval (s) | number | Nein | How often the state of the projectors is read, in seconds (30 to 600). |
So installierst du PJLink Projectors in Gladys
- Öffne in Gladys Integrationen: PJLink Projectors erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
ghcr.io/lm1lc3n7/gladys-pjlink:0.1.2) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration). - Öffne den Bildschirm Konfiguration der Integration, fülle die Einstellungen aus und speichere.
- Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-pjlink.
PJLink Projectors benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
PJLink Projectors ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
