Orbit B-hyve Smart-Home-Integration, kostenlos und Open Source
Control Orbit B-hyve sprinkler timers: water a zone, set run time and rain delay.
Controls Orbit B-hyve Wi-Fi sprinkler timers through the B-hyve cloud, using the same API and event stream as the B-hyve app.
Features (per timer)
- <zone> watering — one switch per zone. On waters that zone for the current Run time; off stops watering.
- Run time — minutes a switched-on zone waters (1–120, default 10).
- Rain delay — hours to suspend scheduled programs (0–168; 0 cancels).
- Next watering — the next scheduled start and program, e.g.
Thu 1 Oct 09:00 · Bonsai. - Fault —
OK, or the zone faults the timer reports.
Scenes
- Triggers: watering started, watering finished (filter by zone name), zone fault, fault cleared.
- Actions: water a zone for N minutes, stop watering, set a rain delay.
Watering started by the timer's own schedule or from the B-hyve app is reflected live over the event stream.
Enter your B-hyve account email and password. Then open the Discovery tab and create the device.
- Login refused — check the credentials in the B-hyve app.
- States lag — the event stream reconnects automatically; the refresh interval is a safety net.
- Logs:
docker logson the integration container.
Diese Einstellungen fragt Orbit B-hyve in seinem Konfigurationsbildschirm in Gladys ab.
| B-hyve account | section | Nein | The same email and password you use in the B-hyve app. |
string | Ja | ||
| Password | secret | Ja | |
| Refresh interval (s) | number | Nein | Safety-net poll; live changes arrive instantly over the event stream. |
So installierst du Orbit B-hyve in Gladys
- Öffne in Gladys Integrationen: Orbit B-hyve erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
ghcr.io/plsoftware/gladys-bhyve:0.2.0) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration). - Öffne den Bildschirm Konfiguration der Integration, fülle die Einstellungen aus und speichere.
- Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/plsoftware/gladys-bhyve.
Orbit B-hyve benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Orbit B-hyve ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von plsoftware veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
