Nobø Hub Smart-Home-Integration, kostenlos und Open Source
Nobø Hub-Integration für Gladys Assistant
Nobø electric heaters through the Nobø Hub (Ecohub): zones, modes, temperatures.
Brings the zones of a Nobø Hub (Nobø Energy Control, also sold as Ecohub) into Gladys, over your local network, through the local API that Glen Dimplex published for the hub (version 1.1). No account, no cloud.
Never tested with a real device: written from the official API document only. Not affiliated with Glen Dimplex Nordic, not officially supported nor endorsed by it. Please report what works and what does not.
One device per zone of the hub:
FeatureWhat it is
TemperatureThe temperature of the zone (its Nobø Switch or sensor), when the hub has one
Comfort temperatureThe comfort temperature of the zone (°C, whole numbers, 7 to 30)
Eco temperatureThe eco temperature of the zone
ModeWeek profile, comfort, eco or away: the standing choice of the zone
Mode in forceComfort, eco, away or off: what the zone does now (read only)
And one device for the hub, with the mode of the whole house.
The "mode in force" is worked out here from the overrides and the week profile of the zone, at the local time of the configured time zone: the hub does not send it. Week profiles are read with Monday first (to be checked on a real hub). A temperature the hub does not know (N/A) publishes nothing.
Setup​
  1. Read the serial number of the hub on its label (12 digits) and enter it. The hub asks for it at every connection. It is kept by Gladys in its database, never shown again, sent only to your hub.
  2. Leave the IP address empty: Gladys listens for the hub, which announces itself every 2 s on UDP port 10000 (Gladys asks for this permission at the install). If your network blocks that announcement, give the hub a fixed address in your router and enter it.
  3. Check the time zone (Europe/Oslo by default): the local time is sent to the hub at each connection, as the Nobø app does.
  4. Open Discover, add the zones you want.
The hub accepts two local clients at once: the Nobø app on the same network counts as one.
Commands (off by default)​
Without any option, Gladys only reads, and can set the away mode (anti-frost), which is always allowed. No command goes through a switch: a "turn everything off" never reaches the heating.
  • Allow mode commands: comfort, eco or back to the week profile, for a zone or the whole house. Gladys writes a constant override, as the hub defines it.
  • Allow temperature commands: the comfort and eco temperatures of a zone, whole numbers from 7 to 30 °C, comfort never below eco.
Each command is decided on the state of the live session (the hub pushes every change to its clients) and confirmed by the answer of the hub. Without an answer within 3.5 s, Gladys shows "sent, without confirmation"; if the hub answers other values, "not applied"; without a downloaded session, "nothing sent". Commands are written one at a time (a scene setting several zones waits its turn).
The away mode​
The away mode (anti-frost) of a zone or of the whole house is the protective command: no option, no missing session, no full queue refuses it. It goes before the commands waiting, and those of its target (all of them, for the whole house) are dropped. Until the hub shows it applied, it is kept in /data and written again: when the hub does not answer within 3.5 s, the connection is taken as frozen, closed, and the away mode written on the next one, after its download, or 3 s at most after the handshake if the download does not end (6 times at most within 15 minutes). After a restart, it leaves once Gladys has given the configuration back (the hub asks for the serial number, which is never written to /data). It is not sent again once a newer mode of the same target has left from Gladys, or once the hub shows another mode set on it later (from the app, a switch); a temperature change does not stop it.
This is deliberate, as the away mode is the protective command: when the hub answers slowly after a reconnection, a pending away mode leaves 3 s after the handshake without waiting for the download, and can then overwrite a choice made in the Nobø app while the connection was down. An away mode that ran out while Gladys or the integration was stopped is told at the next start (log and status), as below.
The away mode of the whole house does not reach the zones that do not allow overrides (a setting of the zone in the Nobø app): set those zones one by one.
It can still fail, and Gladys says so: when the hub refuses it (an E00 answer, its message shown), or when the hub does not show it within 15 minutes or 6 sends: then a warning is logged and the status names the zone (or the whole house), until an away mode is confirmed or another command is clicked.
A hub that sends nothing for 75 s is asked for its data again; without an answer within 20 s the connection is closed and opened again.
Status and troubleshooting​
  • "Enter the 12-digit serial number": the field is empty or not 12 digits.
  • "The hub refused this serial number": check the label. Nothing is sent again by itself; save a new serial number, or press Test the connection to try once more.
  • "No hub with this serial number heard": enter the IP address of the hub.
  • "The hub does not answer": new tries after 5 s, 10 s, 20 s… up to 5 minutes.
Privacy​
The serial number never appears in logs, statuses, /data, nor device ids: only its first 9 digits, which the hub announces itself on your network, name the hub. /data holds the away commands waiting, the time of the last connection attempt and, after a refusal, 8 bits of a salted hash of the refused serial number.
Diese Einstellungen fragt Nobø Hub in seinem Konfigurationsbildschirm in Gladys ab.
Your Nobø HubsectionNeinBrings the zones of a Nobø Hub (Nobø Energy Control, Ecohub) into Gladys over your local network, through the local API published by Glen Dimplex: the temperature, the comfort and eco temperatures and the mode of each zone, and the mode of the whole house. Modes and temperatures can be changed from Gladys only once allowed below; the away mode (anti-frost) is always allowed. Never tested with a real device. Not affiliated with Glen Dimplex Nordic, not supported nor endorsed by it.
Serial number of the hub (12 digits)secretJaOn the label under the hub. The hub asks for it at every connection. Kept by Gladys in its database, never shown again, sent only to your hub on your local network.
IP address of the hub (optional)stringNeinEmpty: Gladys listens for the hub on the network (it announces itself every 2 s). Fill it in when the network blocks this announcement; give the hub a fixed address in your router then.
Time zone of the housestringNeinThe local time sent to the hub at each connection, and used to tell which slot of the week profile is in force (IANA name).
Commands (off by default)sectionNeinWithout these options, Gladys only reads, and sets the away mode (anti-frost), which is always allowed. No command goes through a switch: a "turn everything off" never reaches the heating.
Allow mode commandsbooleanNeinThe dashboard, the scenes and the voice assistants may set a zone or the whole house to comfort, eco, or back to its week profile.
Allow temperature commandsbooleanNeinThe comfort and eco temperatures of a zone may be changed from Gladys (whole numbers, 7 to 30 °C, comfort never below eco).
Language of the namesselectNeinUsed for the names of the devices, features and options added from now on.
So installierst du Nobø Hub in Gladys​
  1. Öffne in Gladys Integrationen: Nobø Hub erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/lm1lc3n7/gladys-nobo:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-nobo.
Nobø Hub benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Nobø Hub ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
