Nginx Proxy Manager Smart-Home-Integration, kostenlos und Open Source
Install and run Nginx Proxy Manager from Gladys, with direct access to its admin portal.
This integration installs and runs Nginx Proxy Manager (NPM) directly on the Gladys machine: nothing to install by hand, no docker-compose to write. Gladys creates the container, supervises it, keeps its data and gives you direct access to its web portal. (The image is a very lightly adapted build of the official one, required to run inside the Gladys security sandbox — same features.)
What the integration does
- Automatic install: when the integration is installed, Gladys pulls the official NPM image and starts the container (the docker-compose equivalent, inside the Gladys sandbox).
- Supervision: the container state is visible in Gladys; the configuration screen shows whether the NPM API answers, and a Check Nginx Proxy Manager button displays the running version.
- Portal access: an Open link in Gladys leads to the NPM admin portal. Management (proxy hosts, redirections, SSL certificates) happens in that portal, as usual.
- Persistent data: the NPM database (
/data) and its certificates (/etc/letsencrypt) are kept by Gladys across restarts and updates.
Install
- Install the integration from the Gladys catalog. The install screen shows the container that will be created (image, published ports, limits); confirm.
- Wait for the status to turn green (the first start initializes the NPM database, allow one to two minutes).
- Open the portal through the Open link (or the URL shown in the "Access the portal" section).
- On your first visit, Nginx Proxy Manager asks you to create the administrator account (email + password of your choice).
Expose your services on the internet
Gladys picks the ports published on the machine (they are shown in the configuration screen, "Expose your services" section):
- the HTTP port maps to NPM's internal port 80;
- the HTTPS port maps to the internal port 443.
On your router:
Forward port 443 (to the assigned HTTPS port): the only essential one. Your sites are served encrypted, nobody can read the traffic.
Port 80 is optional (to the assigned HTTP port) and must never serve your sites in clear text. It has only two legitimate uses:
- letting Let's Encrypt verify your domain to issue and renew your certificates (its default method);
- automatically redirecting visitors typing
http://tohttps://.
If you open it, enable Force SSL on each of your proxy hosts in NPM: anything arriving over HTTP is immediately redirected to HTTPS, nothing is served in clear.
If you prefer not to open port 80 at all: in NPM, request your certificates with a DNS challenge ("Use a DNS Challenge" when requesting the certificate) — Let's Encrypt then verifies your domain without going through port 80.
Where is my data?
The Nginx Proxy Manager data lives on the machine hosting Gladys, inside the integration data folder:
/var/lib/gladysassistant/external-integrations/<identifier>/containers/npm/
├─ data/ # SQLite database (proxy hosts, accounts, settings),
│ # generated nginx configurations, logs
└─ etc/letsencrypt/ # Let's Encrypt certificates and account keys
(<identifier> depends on your install — visible with docker inspect on
the npm container, mounts column.)
These folders survive restarts and updates. However, uninstalling the integration may remove them: make a copy before any uninstall, and include this path in your usual backups:
sudo tar czf ~/backup-npm-$(date +%F).tar.gz \
/var/lib/gladysassistant/external-integrations/*/containers/npm
Good to know
- This integration creates no device in Gladys: NPM is managed from its own portal.
- Stopping the integration also stops the proxy; uninstalling the integration removes the container (volumes follow the Gladys data policy).
Diese Einstellungen fragt Nginx Proxy Manager in seinem Konfigurationsbildschirm in Gladys ab.
| How it works | section | Nein | This integration installs and runs Nginx Proxy Manager on your Gladys machine: nothing to install by hand, the container is created, supervised and updated by Gladys. Manage your proxy hosts, redirections and SSL certificates from its own web portal. |
| Access the portal | section | Nein | The admin portal is available at http://{{gladys_host}}:{{port:admin}} — also one click away via the "Open NPM admin portal" button on the Supervision screen. On your first visit, Nginx Proxy Manager asks you to create the administrator account. |
| Expose your services | section | Nein | To serve your domains from the internet, forward port 443 of your router to port {{port:https}} on the Gladys machine — that is the only essential one, your sites are served encrypted (HTTPS). Port 80 (to {{port:http}}) is optional and must never serve content: it is only used by Let's Encrypt to issue/renew your certificates (default method) and to redirect visitors typing http:// to https://. If you open it, enable "Force SSL" on your hosts in NPM; if you keep it closed, use the DNS challenge for your certificates. |
So installierst du Nginx Proxy Manager in Gladys
- Öffne in Gladys Integrationen: Nginx Proxy Manager erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
ghcr.io/jeremiemercier/gladys-nginx-proxy-manager:1.0.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration). - Öffne den Bildschirm Konfiguration der Integration, fülle die Einstellungen aus und speichere.
- Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/JeremieMercier/gladys-nginx-proxy-manager.
Nginx Proxy Manager benötigt Gladys >=4.86.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Nginx Proxy Manager ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von JeremieMercier veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
