Nextcloud Talk Community-Integration, kostenlos und Open Source
Nextcloud Talk-Integration für Gladys Assistant
Chat with Gladys from Nextcloud Talk: ask questions, receive alerts and images.
Chat with Gladys from Nextcloud Talk: ask questions about your home, start scenes, and receive the notifications and camera images Gladys sends you, in a private conversation with a bot account.
How it works​
The integration logs into your Nextcloud with one account dedicated to Gladys (the bot). Each Gladys user opens a private (one-to-one) conversation with that account in Talk, and links it to their Gladys account with a short code. From then on, what they write in this conversation reaches Gladys with their authority, and Gladys answers there.
Only one-to-one conversations are taken into account: in a group conversation, every member would speak in the name of the user who linked it. Group conversations of the bot account are simply ignored.
1. Create the bot account (Nextcloud admin)​
  1. In Nextcloud, create a user for Gladys, for example gladys, with a display name such as "Gladys". Make sure the Talk app is enabled for it.
  2. Log in as this user, open Settings → Security, and under Devices & sessions create an app password (name it "Gladys"). Copy it: it is only shown once. An app password can be revoked at any time without changing the account password, and it keeps working with two-factor authentication.
2. Configure the integration (Gladys admin)​
  1. Open the Configuration tab of the Nextcloud Talk integration.
  2. Fill in:
    • Nextcloud URL: the address of your instance as Gladys can reach it, for example https://cloud.example.com (add the sub-path if Nextcloud is not at the root, e.g. https://example.com/nextcloud);
    • Bot login: the login of the account created above;
    • Bot app password: the app password created above.
  3. Save, then click Test the connection: it shows the account Gladys is logged in with and how many private conversations it can see.
  1. In Nextcloud Talk, start a private conversation with the bot account (search for its name in "Start a new conversation").
  2. In Gladys, open the Nextcloud Talk integration and click Link my account: Gladys shows a short code, valid for 15 minutes.
  3. Send this code in the Talk conversation. The bot answers that the conversation is now linked to your account.
You can now write to Gladys in this conversation ("what is the temperature in the living room?"), and select Nextcloud Talk in the scenes that send you messages. You can revoke the link at any time from the same screen.
Good to know​
  • The bot answers within a few seconds: it listens to each conversation continuously. A new conversation is noticed within 30 seconds.
  • Messages written while the integration is stopped are not executed when it starts again, so that an old command (opening a door…) never runs late.
  • Images sent by Gladys (camera snapshots) are uploaded to the Talk folder of the bot account, then shared in the conversation.
  • "Nextcloud refused the bot credentials": check the login, and create a new app password if needed. The login is the user id, not the e-mail.
  • "Nextcloud is unreachable": check that the URL is reachable from the machine running Gladys (not only from your browser) and that its HTTPS certificate is valid.
  • The bot does not answer: make sure the conversation is a one-to-one conversation with the bot account, and look at the integration logs in Gladys.
  • "This is not a valid linking code, or it expired": generate a new code in Gladys and send it within 15 minutes; each code can only be used once.
Diese Einstellungen fragt Nextcloud Talk in seinem Konfigurationsbildschirm in Gladys ab.
Getting startedsectionNeinCreate a Nextcloud account dedicated to Gladys (the bot) and an app password for it in Settings → Security. Each Gladys user then opens a private conversation with this account in Talk and sends the code given by "Link my account".
Nextcloud URLstringJaAddress of your Nextcloud instance, as reachable from Gladys.
Bot loginstringJaLogin of the Nextcloud account Gladys speaks with.
Bot app passwordsecretJaAn app password of that account rather than its main password.
So installierst du Nextcloud Talk in Gladys​
  1. Öffne in Gladys Integrationen: Nextcloud Talk erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/bertrandda/gladys-nextcloud-talk:2.0.2) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/bertrandda/gladys-nextcloud-talk.
Nextcloud Talk benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Nextcloud Talk ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von bertrandda veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
